Vizio E500i-B1
  • jhrsmail
    • Jan 2017
    • 36
    Re: Vizio E500i-B1
    How in the world did you get the heatsink off!! Solder braid and solder sucker not doing it..!!
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8204
      Re: Vizio E500i-B1
      bigger soldering iron / gun. You may also preheat the heat sink with a hair dryer etc.
      • jhrsmail
        • Jan 2017
        • 36
        Re: Vizio E500i-B1
        Ok..good and bad news... bad news, this didn't fix the power issue..good news , my soldering skills suck. I'm taking the board to a qualified solderer, I'll update if I fubbed the job.
        • capwizard
          • Jun 2016
          • 1991
          Re: Vizio E500i-B1
          Hay pal, I took out that IC use this Poorman's T12, it cost me $ 2.22.................
          https://www.badcaps.net/forum/showthread.php?t=59103
          • jhrsmail
            • Jan 2017
            • 36
            Re: Vizio E500i-B1
            Alright folks! With magnification at work found solder holes n my work. Fixed those, and BOOM! , TV has been on for 30 mins, I can switch inputs, turn of and on..no problems. Fingers crossed, thanks to CAPWIZARD!! , AKA D MAN! if it stays on all night..it's definitely fixed. I will update
            • jhrsmail
              • Jan 2017
              • 36
              Re: Vizio E500i-B1
              Edit* BOOOOO!! just turned off. Sorry for the rushed update. Lol
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8204
                Re: Vizio E500i-B1
                what turned off? the whole TV or just the back light?
                • jhrsmail
                  • Jan 2017
                  • 36
                  Re: Vizio E500i-B1
                  Whole tv. No audio. Video, or backlights. Won't turn back on with remote or button .
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8204
                    Re: Vizio E500i-B1
                    check stby voltage and PSon pin.
                    • Studio270
                      • Jun 2016
                      Re: Vizio E500i-B1
                      Any update on this? I'm having the same problem.
                        Re: Vizio E500i-B1
                        So did you do any Voltages checking?
                        • capwizard
                          • Jun 2016
                          • 1991
                          Re: Vizio E500i-B1
                          Oo....Yaaa......YYYYes, I don't need to be castrated...........................
                          I do fix it by first change IC9301 then IC9101............
                          PS: I have parts to fix 14 more Vizio E500i-B1 TVs
                          • jhrsmail
                            • Jan 2017
                            • 36
                            Re: Vizio E500i-B1
                            Well.. u shoulda told me wizard! �� Do I need to get another 9101? I replaced it and it worked fine for a while then went out again..
                            • capwizard
                              • Jun 2016
                              • 1991
                              Re: Vizio E500i-B1
                              Did you change IC9301 (STR-A6069)? you need to do that first !
                              PS: Vizio E500i-B1 80% problems are STR-A6069 only 10 % problems are IC9101....the other 10% is A DOG........
                              • jhrsmail
                                • Jan 2017
                                • 36
                                Re: Vizio E500i-B1
                                Well I didn't do that. But I will now. So, I probably need another 9101, right?
                                • capwizard
                                  • Jun 2016
                                  • 1991
                                  Re: Vizio E500i-B1
                                  No, You dont need it anymore! order STR-A6069 asap. This will fix your DOG.
                                  • jhrsmail
                                    • Jan 2017
                                    • 36
                                    Re: Vizio E500i-B1
                                    Gracious senior Wizard
                                    • capwizard
                                      • Jun 2016
                                      • 1991
                                      Re: Vizio E500i-B1
                                      De nada.....................
                                      • jhrsmail
                                        • Jan 2017
                                        • 36
                                        Re: Vizio E500i-B1
                                        Well..here we go. I've replaced IC9301, TV turns on, we'll see how long it lasts. I still have 15.3 on the 24v legs.....
                                        • Agent24
                                          I see dead caps
                                          • Oct 2007
                                          • 4975
                                          • New Zealand
                                          #60
                                          Re: Vizio E500i-B1
                                          That sounds far too low. There must be something wrong for it to be 9 volts less than it should be!
                                          -David VanHorn
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • SS454
                                            vizio e650i-a2 backlight flashes then turns off
                                            by SS454
                                            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                            panel: au optronics T650HVN05.4
                                            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                            https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                            08-20-2020, 03:57 PM
                                          • mrtek
                                            Vizio M65-C1
                                            by mrtek
                                            Hi.
                                            picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                            When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                            This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                            07-14-2025, 07:28 PM
                                          • mecha1166
                                            Anyone here fix a tv and customer cracks panel when they get it home?
                                            by mecha1166
                                            About 2 times a year, a customer will do this. We fix the tv, put it on test play, and customer sees it working. They see me pull power and video wire. Sometimes I pick up tv, right in front of them, and carry it out to their vehicle while they are next to me. I set it in their tv gently, and tell them the tv is very fragile, be careful with it. I let them close the door/trunk. That day, or a few days later, they tell me there is a crack inside the tv. Normally I tell them transportation is their responsibility and normally that is the end of it. Has anyone had a customer that was not buying this...
                                            03-29-2024, 11:27 AM
                                          • howardc64
                                            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                            by howardc64
                                            Failure Symptom
                                            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                            Where is the short?
                                            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                            05-27-2025, 02:56 PM
