Poorman's T12
  • capwizard
    • Jun 2016
    • 1991
    Poorman's T12
    Dirt cheap T12 soldering iron more power than TS 100!!!
    If TS100 needs 10 sec. to heat-up to 300c, this one only needs 8 sec. depend on what kind power supply you use.
    Ac adapter use 31v HP old printer AC adapter, more power than 24v, power cable solder right on the top of tips bit, switch use copper wire, simple and easy , long time usage please wear glove.
    PS: this is a prototype, more T12 tips are on the way, will built real one, very good for Pulse user, you use a while then set for long time...
  • capwizard
    • Jun 2016
    • 1991
    Re: Poorman's T12
    Keep going..................
    • capwizard
      • Jun 2016
      • 1991
      Re: Poorman's T12
      Work wounderful....
      only took 3 sec. to melt the solder!!! This is the best Christmas gift for myself
      31v 2.420A old HP printer ac adapter was used.
      • capwizard
        • Jun 2016
        • 1991
        Re: Poorman's T12
        Its fun, I need some practice to use this solder iron. kinda simulate PWM or relay, your fingertip push on and off, you will get used to it in no time. For me is better than TS100.... T12 tips I feel is not very good quality, instead of using cheap clone T12, we should support the original maker Hakko....at lease solder tips...
          • 31289
          Re: Poorman's T12
          lol
          • capwizard
            • Jun 2016
            • 1991
            Re: Poorman's T12
            Yes this is the Hakko, if not because I spread coca cola inside it will still working.
              • 31289
              Re: Poorman's T12
              it needs a new sponge!
              • capwizard
                • Jun 2016
                • 1991
                Re: Poorman's T12
                Here you are! The 3m Scotch Brite sponge is the must to take away the heart especially on this DIY solder iron.
                with this solder iron about 10 pushes total, I finished change dLEDs job very quickly, and I dont need to worry about the iron is hot when I have to talk to customer.
                • capwizard
                  • Jun 2016
                  • 1991
                  Re: Poorman's T12
                  UPDATE:
                  This is the most powerful iron I ever use, 3 sec ready, don't need to over power this iron tip, so I'm gonna change back to common smaller easy to access laptop AC adapter 19v- 23v 2A , is enough for it, because sometime I forgot and keep push the button until the whole tip is red hot.
                  YES, still work OK, so far, so good, I think this can light up your gas BBQ.
                  • capwizard
                    • Jun 2016
                    • 1991
                    Re: Poorman's T12
                    I dont understand this T12 tip, the more red hot it get the more clean the tip is? most tips will get oxidized and can not use anymore?
                    • capwizard
                      • Jun 2016
                      • 1991
                      Re: Poorman's T12
                      I swear, this is the best soldering iron I ever used, after one mouth abused, solder tips point still shiny.......
                      • capwizard
                        • Jun 2016
                        • 1991
                        Re: Poorman's T12
                        Update! I changed switch and redid the silicone handle, grab the iron with plastic bag fill with silicone. it is customer made right for your hand.
                        PS: After one month abuses the tips still shining...................
                        • capwizard
                          • Jun 2016
                          • 1991
                          Re: Poorman's T12
                          Finally T12 is no work, the iron tip heating element is open.
                          PS: The metal sheet was raised at base because I dipped it in the water occasionally.
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            Re: Poorman's T12
                            I can hear my t12 tips shaking with fear and crying as they look at those photos
                              Re: Poorman's T12
                              And I wondered why it failed, NOT!
                              • capwizard
                                • Jun 2016
                                • 1991
                                Re: Poorman's T12
                                PS: Poormans T12 No2 , I will let the iron tip air-cool all the time ( no more dip in the coffee).
                                  • Jul 2011
                                  • 6070
                                  Re: Poorman's T12
                                  You should get a motor speed controller and use that on it and you would not have this problem you can get them on eBay and they do not cost very much
                                  I have tried this myself and it work very well but I need to fix the soldiering station controller MOSFET first to get thing really working good
                                  If you want to get one of those motor speed controllers let me know and I will post the link where you can get one
                                    • Jul 2011
                                    • 6070
                                    Re: Poorman's T12
                                    I going to buy one of those iron from that company as well but I am going to use a Ryobi 18v battery pack to power it
                                    On another note but on the same thing
                                    I bought one of these sound bars from Kmart that is closing there doors for $45.00 and I am powering with a Ryobi 18v volt lithium battery pack works very well I ran it for two hours and still had 4 bars of power left
                                    One thing I still net to do is to put in a Polly type fuse in it in case a fault it trips the fuse and dose hurt the the battery pack
                                    • capwizard
                                      • Jun 2016
                                      • 1991
                                      Re: Poorman's T12
                                      Waiting to see your Ryobi T12.
