Flickering Horizontal Lines and other distortions on Samsung LN52A850S1FXZA LCD
  • SurrealMustard
    • Jan 2015
    • 487
    • The United States of America
    I'm looking at this Samsung LCD and am having a tough time tracking down what's causing this issue. It's a bit difficult to describe, but what happens is that after it has run for a little bit, horizontal lines start rapidly flickering everywhere. As time goes on, it gets a bit worse and the bottom of the image also starts getting a bit stretched out too. The problem transcends inputs, video sources, cables, and TV-generated menus.
    I tracked down a few other threads on this issue, but nobody ever nailed down a definitive diagnosis. The boards all look good, but there is a bit of brown stuff on the bottom of some capacitors; is that normal? Otherwise, does anyone know what could be causing this?
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Flickering Horizontal Lines and other distortions on Samsung LN52A850S1FXZA LCD
    Those capacitors look as though the electrolyte has leaked out from the negative pin. Looks similar to when a battery leaks.
    I would remove and test all of them for capacitance and ESR.
    • SurrealMustard
      • Jan 2015
      • 487
      No dice
      To expedite the process a bit, I subbed out the entire power supply board with a known-working unit, and the issue still persists. Any ideas for narrowing this down between the mainboard, TCON, panel, and such?
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        What make and model is the Tcon board?
        • vinceroger69
          • Mar 2012
          • 6714
          Does this model suffer with the bga soldering issue on the mainboard? like some other samsungs maybe try a little heat on the mainboard see if the fault appears quicker
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Could be bga but first replace all the secondary caps on the Psu, slim line lcds like this get very hot and I dare say all the output caps are near failure. Then let us know after that.
            • budwich
              • Jul 2015
              • 3097
              since you replaced the PS board with a known working one, have you tried looking / cleaning the lvds cable running between the main board and the tcon. have you looked under the tcon "can"?
              Is that your black tape on the lvds cable or some elses... :-)
              • SurrealMustard
                • Jan 2015
                • 487
                Samsung
                I'm not entirely sure. I was able to get the cover off of it, and it appears that there's definitely some big chips on there (at least one of which is a Samsung) though.
                I don't remember for sure, but there are definitely some sizable BGAs, both on the mainboard and TCON.
                Originally posted by budwich
                since you replaced the PS board with a known working one, have you tried looking / cleaning the lvds cable running between the main board and the tcon?
                Yes.
                The black stuff looks like black tape, but is actually some kind of vinyl stuff. I think it came like that from Samsung, but am not 100% sure.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  230X138mm/T1.2
                  https://www.shopjimmy.com/samsung-bn...-con-board.htm
                  • SurrealMustard
                    • Jan 2015
                    • 487
                    Tee con!
                    You're pretty sure that it's the culprit then?
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      No not sure but i linked the shopjimmy picture so other more experienced members can see what ics are used on it as they may of had issues with this type of tcon odd faults like you have maybe hard to fault find as you have swopped the psu already it leaves the tcon or the mainboard or the lcd panel pcb? (not sure this will cause the issues your having though) or a bad lcd panel, im sure more experienced members will have ideas as im still learning but as samsungs suffer bga solder issues if this was my set i would probably try a mainboard myself to rule it out but thats me wait and see what others think first.
                      • syaoran123
                        • Jun 2014
                        • 178
                        Do the lines appear on free to air tv?
                        • steviewonder
                          • Dec 2013
                          • 183
                          • england
                          I would suggest some freezer spray, and start with the Tcon, or alternatively, disconnect the tcon and run the the set for a while,and then switch off,quickly reconnect the Tcon,and try again.If the problems start again after a while,with the mainboard still hot,this would suggest the Tcon..Bit of fuzzy logic I know..A hairdrier can work wonders too, for time delayed issues such as yours...It's amazing how a hairdryer can narrow things down-and freeze spray.
                          • SurrealMustard
                            • Jan 2015
                            • 487
                            Feel like giving up!
                            I'd imagine so, since they appear everywhere else when the problem happens.
                            I don't have freezer spray, but what I do have is a room-temperature (65 degree) room, so I let the thing cool off overnight and then heated up just the mainboard with a dryer and then turned it on. No issues - neither immediately nor after some time. The next day, I did the opposite and heated up the T CON with the dryer, leaving everything else cold as I booted up the television. Still no issue.
                            This thing is just becoming too intermittent to effectively diagnose. I really don't know what to do anymore at this point.
                            • SurrealMustard
                              • Jan 2015
                              • 487
                              New strategy
                              I'm going to try a new approach. Since it takes close to 3-4 days to get the problem to come back, I'm going to leave it on until it starts acting up and then try applying additional heat to see if that makes any difference. Stay tuned!
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                Keep us updated
                                • SurrealMustard
                                  • Jan 2015
                                  • 487
                                  Symptom still elusive!
                                  Originally posted by ReeceyBurger123
                                  Keep us updated
                                  After leaving it running for about two days straight, the problem has not reemerged, so I heated up the mainboard and then the T Con board with a dryer to see if heat could coax the issue out of it, but this did not work and it appears to still be operating normally. The only difference between my trials and when it was originally showing the problem is that it is currently laying face down with the back cover off in a room temperature room instead of hanging on the wall with the back cover on.
                                  Any other ideas beside applying time and heat?
                                  • SurrealMustard
                                    • Jan 2015
                                    • 487
                                    Still working! What a novel problem to have...
                                    Four more days of nonstop operation with the television face-down have been unable to trigger the problem (ironic that we're talking about a working item on a repair forum ). I really don't know what to do at this point because I have the funny feeling that if I call it fixed and put it all back together, it'll just start doing the same thing again, but it looks like there's no other choice, unless somebody has any new ideas.
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      Seems like Bgs issue to me likely on the Tcon.
                                      • mrsith
                                        Samsung UE70TU7100 - flickering horizontal lines
                                        by mrsith
                                        Hello again good souls.
                                        Got an UE70TU7100. The TV starts up just fine, but right hand side of the screen is horizontal striped a bit, and there are some flickering horizontal lines on the whole length of the screen. I've seen similar static horizontal lines sometimes, when applying the cut tape method and covering wrong number of pins.
                                        I've cleaned every connector with ipa, tried cut tape method on main LVDS ribbon as well as small ribbons, connecting the panel boards at the bottom. Tried squeezing the bezel and playing around COFs, but no reaction at all. COFs and...
                                        02-13-2023, 05:36 AM
                                      • Ihandyrepair
                                        Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                                        by Ihandyrepair
                                        Hi guys
                                        I just started fixing 4k TV few months ago. so I am still learning a lot
                                        I got this tv from friend complaint is ghosting or horizontal lines on image.
                                        never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                                        then it started to show the ghosting white image.
                                        I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                                        it has 3 thin small boards at the bottom of the...
                                        12-05-2022, 04:18 PM
                                      • Rubenlily
                                        Samsung QE50Q67TAU - horizontal lines
                                        by Rubenlily
                                        First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
                                        I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
                                        I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
                                        I'm no expert but I've done the tape...
                                        08-16-2023, 01:12 PM
                                      • x_orange90_x
                                        Samsung UN46C8000XFXZA vertical bars/horizontal lines
                                        by x_orange90_x
                                        I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
                                        The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
                                        09-04-2023, 12:09 PM
                                      • arctor
                                        samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
                                        by arctor
                                        hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
                                        04-26-2025, 05:22 AM
