Help finding replacement LED's for TV backlight
  • Johndill
    • Aug 2015
    • 314
    Hi, I have a PENDO 48" TV, Model "PNDLFHU48" with an LED back light, it has 3 blown LED's on the strip that I need to replace but I don't know the exact specs or type of LED, is someone able to link me a web site where I can them please? I've tested them all and the rest of the strips are still working :-) I'm capable of replacing them on the PCB I just can't find them online :-( I've attached pictures of the LED's.
    In the first picture, positive is on the left end and neutral is on the right end of the LED.
  • ivtec
    • Dec 2008
    • 1967
    Re: Help finding replacement LED's for TV backlight
    John;nobody knows who makes that brand,your best bet is to order some of these and try to replace the burned led on your strips and wish for the best,
    in your case those strips should have printed on the the info if not your out of luck.
    you also could contact jimmys.com and give them all the tv info and see if they can find out which led strips are good for that Modle #.
    http://www.ebay.com/itm/15-pcs-Diode...-/252304716100
      Is it using SAMSUNG LCD panel or?
      • Diah
        • Feb 2013
        • 6614
        you can use 3528 SMD LED 3.6V forward voltage, also buy this and cut them to use one by one over yours old one aliexpress
        • Johndill
          • Aug 2015
          • 314
          Yes, I plan to replace the burnt LED not the hole strip that would be hard to find, a TV repair tech friend here in Australia said he thinks it's an LG panel and that each strip runs on 24V, so will those LED's on ebay be the correct voltage?
          A TV repair tech friend said he thinks it's an LG panel, I'll attach a picture.
          • Johndill
            • Aug 2015
            • 314
            The one you found on aliexpress is the same type but for a 32inch, each strip on mine is made up of 2 halves connected together, one with 5 LED's and the other with 6, picture attached.
            • Johndill
              • Aug 2015
              • 314
              I tested the LED power connector and it was giveing a reading around 55V, does that sound right to you?
              • Johndill
                • Aug 2015
                • 314
                bump
                • vinceroger69
                  • Mar 2012
                  • 6714
                  have you saw this video that reece has done.
                  https://www.youtube.com/watch?v=RxwdC7V5Ue0
                  https://www.youtube.com/watch?v=EZVQKEp6jxk
                  http://www.shopjimmy.com/replacement...-set-of-12.htm
                  • bhatti76
                    • Jun 2014
                    • 7
                    • australia
                    Hi john
                    What finally you used to fix it?
                    • Johndill
                      • Aug 2015
                      • 314
                      Originally posted by bhatti76
                      Hi john
                      Hi bhatti76,
                      I haven't gotten around to my repair lately as I've been away for the holidays.
                      I plan to try the LED's in the eBay link below however they'll take a while to arrive before I can say there're a good replacement or not :-)
                      http://www.ebay.com.au/itm/222254264811?ul_noapp=true
                      • Johndill
                        • Aug 2015
                        • 314
                        Hi john
                        The repair was successful so far, hopefully it lasts, just remember to get the polarity right, I used a 2x AA battery holder to test the leds and polarity :-) forgot to take a picture of the replaced leds sorry :-)
                        • Johndill
                          • Aug 2015
                          • 314
                          Well, that didn't last long, the top row has gone but the rest still work? Too busy to try again atm
                          • srhofmann
                            • Aug 2016
                            • 135
                            • usa
                            Next time you have it apart post a picture of the tcon board with the label. That will make it a lot easier to determine who made the panel.
                            • lmcancu
                              RCA RLDED 4331B: 43 inch LED TV: Backlight issue
                              by lmcancu
                              Hi I am having an issue with the LED backlight of this TV. I can see the picture with a flash light, so I determined it was a backlight issue.
                              Initially, after opening it I found 2 shorted and 1 open LED on 2 strips (total of 4). I removed the LEDs and shorted the pads together to verify if the backlight would work.
                              Testing it, I found the backlight turned on and I measured 54V when TV was in standby (off), and 100v when TV was turned on. The 4 strips each contain 9 LEDs, so 36 in all minus 3.
                              Instead of putting it back together I decided to replace...
                              04-01-2023, 01:11 PM
                            • pni
                              Backlight panel diffuser melt by backlight leds broken
                              by pni
                              Hi guys, I changed my backlight to a 5g in Samsung but the broken leds burned the thick plastic panel . I give the photo. Do you think if I try to rotate the panel, with the botton on the top I have a good image? Becacause now how u can see, on the light color I sse the leds because of the burned on the plastic diffuser....
                              10-12-2025, 12:08 AM
                            • smort
                              Backlight Polkadarks
                              by smort
                              Soooo, I found someone giving away their 70" Vizio TV because it wouldn't turn on. Hoping it would be just some bad caps, I snapped it up. No dice. No bulging caps. TV would start consuming about 7W immediately after plugging it in, but no response from the remote or power button. Thermal showed the main chip on the mobo getting warm and nothing else. Power supply appeared to deliver stable 12V to the mainboard.
                              I ordered a replacement mobo(actually both mobo and PSU just to be sure) and popped it in. Picture! Sound! Endorphins! Then I noticed three long dark strips. Hmmm, had...
                              03-11-2025, 12:33 AM
                            • mc900fthanna
                              Visio M70-C3 LED replacement strips
                              by mc900fthanna
                              So... I have the patchy back light issue with my Visio M70, meaning some light up, others do not. I finally got around to testing the LED driver board and found that was not the issue (swapped another one in and the same issue persisted) and I am considering if i dare dive deeper into this TV and go after the LED strips.
                              Right away i see that they don't seem to stock them anywhere out there (E700DLB0016-002) is a part number that i see a you tube / seller guy list out. He has a nice video of how to get into my exact TV out there: https://www.youtube.com/watch?v=0AcUPiN83Tg
                              11-28-2022, 03:03 PM
