Visio M70-C3 LED replacement strips
  • mc900fthanna
    Noob of Fixing.
    So... I have the patchy back light issue with my Visio M70, meaning some light up, others do not. I finally got around to testing the LED driver board and found that was not the issue (swapped another one in and the same issue persisted) and I am considering if i dare dive deeper into this TV and go after the LED strips.
    Right away i see that they don't seem to stock them anywhere out there (E700DLB0016-002) is a part number that i see a you tube / seller guy list out. He has a nice video of how to get into my exact TV out there: https://www.youtube.com/watch?v=0AcUPiN83Tg
    But as i was saying, seems like nobody has replacement LED strips in stock, so my questions to the forum:
    Are there any places you might recommend that might sell strips that would fit this TV?
    Do folks ever buy a buncha replacement LED's and fix those strips?
    Before i scrap this almost perfectly working 4k 70 inch TV (save parts of the back light), it would be cool to know if anything can be done.
    My thanks in advance!
    MC900ftHanna
  • alfatv
    • Sep 2020
    • 353
    Re: Visio M70-C3 LED replacement strips
    If nothing on aliexpress, that guy on ebay may be the only option. Had similar issue with E60-C3.
    I don't recommend used strips or fixing unless you change every LED.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • ezenia
      PS4 controller left stick potentiometer replacement issue
      by ezenia
      Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
      So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
      I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
      09-30-2023, 02:19 PM
    • ScHAmPi
      Samsung UE48JU7000 screen issue after backlight replacement
      by ScHAmPi
      Because of two bright spots and a couple of dark spots I decided to replace the backlights in my Samsung UE48JU7000. See attached photos:
      I thought all went well, but after full assembly and testing it out it turns out not all is fine. The backlights are completely fine but I have some weird issues on the right half of the screen. Since I didn't really touch the T-CON board (apart from taking out the ribbons of the display and reconnecting them on assembly) it would be weird that the issue is with the T-CON board... But based on the behavior of the service...
      07-15-2024, 05:41 AM
    • anupkg1985
      Insignia NS-50DF710NA21 Replacement LED strips
      by anupkg1985
      I have this Insignia tv with most of the led's damaged. I'm not able to find the replacement LED strips for the same. The numbers marked on LED strips are -
      LB-GM3030-GJBETTY504XBBB19. Please find the photo for the same. Can somebody help finding replacement/equivalent led strips for the same....
      05-02-2022, 04:59 PM
    • EvilSnowtech
      MacBook A1989 BT/WLAN Issue, Questions, or Replacement Requests
      by EvilSnowtech
      Hello members of the repair forum,
      I'm facing an issue with my MacBook A1989, where I encountered a short circuit on PP1V8_G3S for reasons unknown. After removing the audio amplifier and MIC, the resistance values returned to normal.
      However, during testing, I found that attempting to enable Bluetooth yields no response. Bluetooth cannot be activated, and the PP1V8_G3S-to-ground resistance value is approximately 285. I suspect that PP1V8_G3S_WLANBT_VDDIO may, under certain conditions, exceed 1.8v, potentially causing damage to the Bluetooth module. I am considering replacing...
      12-06-2023, 12:45 AM
