KDL-46v5100 T-CON or Panel?
  • cfm
    • Oct 2016
    • 5
    I have a chance to pick up this TV.
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: KDL-46v5100 T-CON or Panel?
    Take a look at the screen when you press menu button. See how it looks. Your 1st pic looks like there are horizontal lines all over, maybe just the pic. But I am thinking bad panel.
    If menu looks good, I would say bad main, maybe tcon. Stay tuned.....better answers to come.
    • ivtec
      • Dec 2008
      • 1967
      Re: Sony KDL-46v5100 T-CON or Panel?
      Yes All these are famous for Bad panel _
      i just trashed one KDL46S4100
      with good pic but one strip right in the middle;
      FX - Chassis
      KDL46S4100- LTY460HB10-001
      LTY[Z]460HB11-A02
      EX2R - Chassis
      KDL46S504- LTY[Z]460HB11-A02
      EX2R - Chassis
      KDL46S5100-- LTY[Z]460HB11-A02
      MA2F - Chassis
      KDL46SL140- LTZ460HB10-001
      LTY[Z]460HB11-A02
      KDL46V4100- LTZ460HB10-001
      • cfm
        • Oct 2016
        • 5
        Thank you for the reply's. Is this a problem with just these 46" Samsung panels as the 40" don't seem to suffer the fate?
        Chris
        • Georgop
          • May 2017
          • 3
          Sorry to be resurrecting an old thread... but I have the same model TV with the same problem as the second picture with the lady and all of the different colored vertical lines.
          Was it determined that the panel was bad? or Was a t-con board possibly tried with a positive resolution to this?
          • Georgop
            • May 2017
            • 3
            The lines as well seem to come and go. With the picture looking fine at times. Here are a few sample pics
            • Thrashbast
              • Oct 2018
              I have a Sony KDL-32" same problem and it was the T-Con Board which was goosed..
              • Georgop
                • May 2017
                • 3
                Thanks Thrashbast. I'll track one down and hope I get the same results as you.
                • albumleaf
                  • Dec 2018
                  • 4
                  Any luck on that tcon fix?
                    • 12146
                    • U.S.
                    Tcon service there for 30 bucks. https://www.ebay.com/itm/SONY-KDL-46...-/153149898784
                    • x_orange90_x
                      TCL 50S535 bad tcon or panel issue?
                      by x_orange90_x
                      Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                      03-29-2025, 11:02 PM
                    • advant
                      by advant
                      02-03-2020, 12:25 AM
                    • mmartell
                      General Questions on the Relationship Between Mainboard, TCON and Panel
                      by mmartell
                      My goal here is to be able to use boards on hand to swap into faulty sets when the faulty board is not obvious.
                      I will start by asking what is the format of the output from the mainboard and is it generic in any way or does it vary by manufacturer and/or model ?
                      And as far as I know a tcon and panel must be a matching pair because the timing of the signals and the voltages required to drive the panel are specific to the panel itself. (That may be a blanket statement that isn't true in some cases where the panel creates its own sub-voltages on its panel boards?)...
                      01-06-2024, 01:32 PM
                    • Lee M.
                      Amazon Fire TV Omni K24NE5 tcon or panel bad?
                      by Lee M.
                      TV came on with BL on but blank screen. Disconnected one of the ribbon cables from tcon to panel driver board and now I have half of the screen working normally. Any way to tell if the problem is with the tcon or the panel driver board or the panel itself? Should I just replace the tcon and see what happens?
                      05-12-2023, 05:47 PM
                    • rimwall
                      Sony KD-65x8500b - bad Tcon or panel?
                      by rimwall
                      Hi, hoping for some views on this one which I've not come across before. The TV generates an image that has 12 noticeable bands across it. The image is still there and accurate, but the colour (or perhaps the brightness) changes gradually across each band which creates a noticeable 'step change' at the edge of each band. Given it's a 4K TV with 2160 rows of pixels, I'm guessing the 12 bands correspond to 12 gate drivers of 180 rows each. If this guess is right, then perhaps:
                      a) all the gate drivers are malfunctioning the same way (which seems unlikely), or
                      b) the Tcon board is malfunctioning,...
                      10-24-2023, 07:58 PM
