KDL-46v5100 T-CON or Panel?
  • cfm
    • Oct 2016
    • 5
    I have a chance to pick up this TV.
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: KDL-46v5100 T-CON or Panel?
    Take a look at the screen when you press menu button. See how it looks. Your 1st pic looks like there are horizontal lines all over, maybe just the pic. But I am thinking bad panel.
    If menu looks good, I would say bad main, maybe tcon. Stay tuned.....better answers to come.
    • ivtec
      • Dec 2008
      • 1967
      Re: Sony KDL-46v5100 T-CON or Panel?
      Yes All these are famous for Bad panel _
      i just trashed one KDL46S4100
      with good pic but one strip right in the middle;
      FX - Chassis
      KDL46S4100- LTY460HB10-001
      LTY[Z]460HB11-A02
      EX2R - Chassis
      KDL46S504- LTY[Z]460HB11-A02
      EX2R - Chassis
      KDL46S5100-- LTY[Z]460HB11-A02
      MA2F - Chassis
      KDL46SL140- LTZ460HB10-001
      LTY[Z]460HB11-A02
      KDL46V4100- LTZ460HB10-001
      • cfm
        • Oct 2016
        • 5
        Thank you for the reply's. Is this a problem with just these 46" Samsung panels as the 40" don't seem to suffer the fate?
        Chris
        • Georgop
          • May 2017
          • 3
          Sorry to be resurrecting an old thread... but I have the same model TV with the same problem as the second picture with the lady and all of the different colored vertical lines.
          Was it determined that the panel was bad? or Was a t-con board possibly tried with a positive resolution to this?
          • Georgop
            • May 2017
            • 3
            The lines as well seem to come and go. With the picture looking fine at times. Here are a few sample pics
            • Thrashbast
              • Oct 2018
              I have a Sony KDL-32" same problem and it was the T-Con Board which was goosed..
              • Georgop
                • May 2017
                • 3
                Thanks Thrashbast. I'll track one down and hope I get the same results as you.
                • albumleaf
                  • Dec 2018
                  • 4
                  Any luck on that tcon fix?
                    • 12268
                    • U.S.
                    Tcon service there for 30 bucks. https://www.ebay.com/itm/SONY-KDL-46...-/153149898784
                    • kca
                      by kca
                      Hello all ~
                      08-31-2025, 06:38 AM
                    • x_orange90_x
                      TCL 50S535 bad tcon or panel issue?
                      by x_orange90_x
                      Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                      03-29-2025, 11:02 PM
                    • netgearnetgear
                      TCL 43S423 TCON OR PANEL FAULTY???
                      by netgearnetgear
                      Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                      08-20-2025, 06:04 PM
                    • advant
                      by advant
                      02-03-2020, 12:25 AM
                    • iglitare
                      by iglitare
                      09-04-2025, 07:13 AM
