I have a chance to pick up this TV.
KDL-46v5100 T-CON or Panel?
Re: KDL-46v5100 T-CON or Panel?
Take a look at the screen when you press menu button. See how it looks. Your 1st pic looks like there are horizontal lines all over, maybe just the pic. But I am thinking bad panel.
If menu looks good, I would say bad main, maybe tcon. Stay tuned.....better answers to come. -
Re: Sony KDL-46v5100 T-CON or Panel?
Yes All these are famous for Bad panel _
i just trashed one KDL46S4100
with good pic but one strip right in the middle;
FX - Chassis
KDL46S4100- LTY460HB10-001
LTY[Z]460HB11-A02
EX2R - Chassis
KDL46S504- LTY[Z]460HB11-A02
EX2R - Chassis
KDL46S5100-- LTY[Z]460HB11-A02
MA2F - Chassis
KDL46SL140- LTZ460HB10-001
LTY[Z]460HB11-A02
KDL46V4100- LTZ460HB10-001Last edited by ivtec; 10-26-2016, 06:09 PM.Comment
Sorry to be resurrecting an old thread... but I have the same model TV with the same problem as the second picture with the lady and all of the different colored vertical lines.
Was it determined that the panel was bad? or Was a t-con board possibly tried with a positive resolution to this?
ThanksComment
I have a Sony KDL-32" same problem and it was the T-Con Board which was goosed..Comment
Tcon service there for 30 bucks. https://www.ebay.com/itm/SONY-KDL-46...-/153149898784Comment
by kcaHello all ~
I got the display to work by taping off several traces of the right-hand side ribbon cable on the TCON that leads from TCON to PANEL. However, despite dozens and dozens of attempts to find the right combination / range of traces taped... -
by x_orange90_xJust bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
by advantThis thread is about trying to get an Universal Main Board to work with a Sharp TCON and panel.
I have a Sharp LC-46D85UN TV that has had a main board issue. Since this model is from 2009, I am not able to find an exact replacement of the main board. Instead, I decided to see if I can future proof this tv by getting a Universal Main Board (T53U21.2) from China to work with the Sharp TCON (CPWBX4291TPZA) and panel. The universal main board supports a 8 bit dual channel LVDS interface whereas the TCON requires a 10 bit dual channel LVDS input. I have modded the LVDS connector to match... -
by iglitareHi,
Or is it always a bad/shorted... - Loading...
