sharp LC-32SH130K / Vestel 17PW82-2 v.1 090511
  • dooosuk
    • May 2016
    • 24
    • United Kingdom
    #41
    Re: sharp LC-32SH130K / Vestel 17PW82-2 v.1 090511
    Yep, numbers match on that board.
    How confident are we based on the info I've provided? I know it's only £25 but I don't want to tell them to buy it if it doesn't solve the issue.
    Thanks again for the help.
    • vinceroger69
      • Mar 2012
      • 6714
      #42
      well see what the others think too first ive never used that ebay seller there quite new looking at the feed back but do offer a returns policy.
      but usually a missing bl-on voltage is a mainboard issue.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        #43
        What Lcd panel is it ? You have to match the board to the panel but if the Psu connector is the same it will work but you need to match the panel first.
        • dooosuk
          • May 2016
          • 24
          • United Kingdom
          #44
          Is the panel the LG board: LC320WXN?
          All the numbers on the main board match the board Vince listed and it was listed for the same model Sharp.
          How do I match the panel to it?
          • vinceroger69
            • Mar 2012
            • 6714
            #45
            Maybe ask the ebay seller did they note the panel number from the set that the mainboard comes from failing that its a chance you take really when buying it but as its listed for the same set i would personaly take the risk and buy it.
            • selldoor
              Slow Learner
              • 7870
              #46
              Hi all, long time no visit I am dragging up this old thread as I have a question regarding the board. Vince mentions socket PL804 as not being in use on this set BUT I was wondering if anyone knows what it was used for ( Maybe on on other sets) I have looked
              at a range of sets with this Vestel Board and havent spotted anything.
              It is 6 pins 12v 12v Gd Gd 5v 5v and is on the schematic.
              Have added a pic (not my Board) to show position of PL804
              • vinceroger69
                • Mar 2012
                • 6714
                #47
                please ignore wrong thread
                • sordids999
                  • May 2013
                  • 2161
                  #48
                  OK, so I'm still alive.
                  The filter cap read 399v when plugged into the mains. I was surprised here that I needed the mains cable plugged in and the black power cable from the logic (?) board plugged in and switched on, but that's just my lack of understanding I guess.
                  The voltages below were all read when plugged into the mains and with the rocker power switch on the back of the TV 'on'. The TV will not switch in and out of standby so these are the only readings I could get.
                  PL802 - do the two readings for pins 11 and 12 look ok?
                  PL816 - Pin 13, 20 and 26 don't look quiet right according to schematic?
                  Thanks for all the pointers so far. Your help is appreciated.
                  On my TV I have exactly the same fault and the same voltages on PL816 except for no 12v and no 5v bl_on still a main board fault?
                  • 90Ninety
                    Crappy Vestel/Sharp LC-40FG3141K Set Backlight going off randomly
                    by 90Ninety
                    Hello
                    Model Code Sharp LC-40FG3141K
                    Firstly perhaps I should save myself the agony and throw this set out ? Then again I hate E-waste , or giving a person further headace in the far east or Agbogbloshie . So I digress to my last hope of fixing this pile of shite , with the dash of hope from your combined experiences
                    So this set is randomly turning off its backlight ( could be days, hours, minutes or seconds ) , my research suggests this maybe an over current protection , or leaky/faulty LEDS , or a bad LED driver circuit . So I opened it up , stabbed my Multi...
                    07-06-2022, 07:09 AM
                  • Jaime Morillo
                    Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                    by Jaime Morillo
                    Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                    The TV was stuck on the logo and I couldn't access the update menu.
                    I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                    The image result was good, but the image is inverted.
                    The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                    Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                    08-18-2025, 11:38 AM
                  • France_53
                    Vestel tv, how to flip the image?
                    by France_53
                    Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
                    05-12-2024, 05:22 AM
                  • FlailingEngineer
                    Help with Bush Tv (Vestel 17mb95m Mainboard)
                    by FlailingEngineer
                    Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
                    Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
                    05-31-2023, 06:52 AM
                  • hazi12
                    Vestel main board 17MB140TC
                    by hazi12
                    Hello, board 17MB140TC, I need to change the remote control in Vestel tool box 1.1. The original is there
                    Rc48xx_2D and I want to install TOSHIBA-Rc481xx, but the program says that a maximum of 9 characters can be entered. I only entered Rc481xx and the program does not accept the driver I have in the original. Does anyone know how to do this? Other Vestel codes work.
                    I can send a dump....
                    10-01-2025, 01:28 PM
