LG 47LV5500 Troubleshooting
  • DivingRhino
    • Oct 2016
    • 10
    I was just given a non-functional LG 47LV5500.
    The power button light will respond to being turned on (from the remote or touch), and light up white, but nothing else happens, it does not appear as the backlight even comes on.
    I have tried a meter on a fuse on the TCON (I know very little, but have read some posts here) and I get zero. Image attached of what I tested and how the meter was set... again, I am a noob with this kind of stuff, but can follow instructions
    Does this mean I'm not getting power beyond the initial board, and should get a TCON (that what this board is called?) or am I doing something wrong.
    Thanks!
    Ryan
  • CapLeaker
    Leaking Member
    • 8352
    Re: LG 47LV5500 Troubleshooting
    No, you don't measure voltage on the fuse like that. I see you need a crash course in how electronics work.
    But before we get to that, I do have to ask for some high resolution, straight shot pictures of your power supply, main board and tcon. Maybe an extra pic of the PSU area where the ribbon cable goes to the main board. So we can see the pin out names.
    • DivingRhino
      • Oct 2016
      • 10
      Well, thanks for helping a noob out!
      Here are some pics...
      • DivingRhino
        • Oct 2016
        • 10
        Disregard this pic... got it in the prior post.
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          You have a Main Bd problem. Since the Power light comes on but no other response, you should be getting 5V-Stby but no PS-ON signal to the Pwr Bd.
          • CapLeaker
            Leaking Member
            • 8352
            could we have another picture of the top right of the power supply, showing the 2 connectors and the pin outs? I can't read it.
            • DivingRhino
              • Oct 2016
              • 10
              Here's another shot...
              • CapLeaker
                Leaking Member
                • 8352
                On connector P201: check the DC voltages on the PWR on pin and the DRV on pin, while the tv is on.
                • DivingRhino
                  • Oct 2016
                  • 10
                  • DivingRhino
                    • Oct 2016
                    • 10
                    Pwr gets me 3.44v
                    and DRV gets me 11.91
                      "and DRV gets me 11.91" Are you sure you are on the right pin? The DRVON has to be measured from the bottom side of the board or at the back side of the female connector. The exposed pins you see on the top side of the board are for the LEFT column pins (odd number) of the pinout chart.
                      BTW, what DCV do you have on the ERROR pin?
                      LG Power supply-LED driver board EAY62169801
                      http://www.shopjimmy.com/catalogsear...?q=EAY62169801
                      Pictures provided by SJ.
                      • DivingRhino
                        • Oct 2016
                        • 10
                        Ok, doing it from the back (hey look at that, they're labeled there... )
                        PRV ON - 24.46
                        DRV ON - 0.033
                        Error - .000
                        • CapLeaker
                          Leaking Member
                          • 8352
                          That measurement isn't right either. Those pins have usually something in between 2v and 5v. There are some weird TV that do things a bis different, but none have 12v or 24v on the PSON/BLOn pins.
                          How about you turn on the tv and measure each pin and use the pin out name.
                            PRV ON - 24.46
                            DRV ON - 0.033
                            Error - .000
                            What did you use for ref. GND for the meter? Those readings are wrong.
                            • DivingRhino
                              • Oct 2016
                              • 10
                              Sorry, haven't been back to this for a couple of days.
                              I used the chassis of the TV for ground.
                              Image of where and how I was testing as well as a reading for each pin (left and right) provided in the attached chart image as well.
                              Note, as far as the TV being "ON", I click the on button on the remote and the lower right light goes steady white. I presume that's on, but given no sound or picture, I don't know.
                                PRV ON - 24.46
                                DRV ON - 0.033
                                Error - .000
                                https://www.badcaps.net/forum/attach...1&d=1476247393
                                So the PWR ON is NOT 24.46V after all, it is 3.37VDC.
                                DRV ON = BL-ON which you are not getting from the main board to turn on the backlights circuits.
                                • pott0120
                                  • Mar 2018
                                  Originally posted by budm
                                  PRV ON - 24.46
                                  DRV ON - 0.033
                                  Error - .000
                                  I am having the same exact problem with my TV, I even got 3V when I measured the power on which should be 24V. How do I correct this? My friend recommended replacing capacitors. Thoughts?
                                    The PWR_ON is the control signal and will never be 24V there, please report what Voltages you are getting on ALL the pin as shown in post #15 chart.
                                      • 12330
                                      • U.S.
                                      There's a legend/map near top of board for connector P201, there are TWO rows of pins for testing, in this case 24 pins. Here's a video of powerboard testing, HEED ALL HIGH VOLTAGE CAN BE DEADLY WARNINGS. https://www.youtube.com/watch?v=4v8DcqCNG4A
                                      • kca
                                        by kca
                                        Hello all ~
                                        08-31-2025, 06:38 AM
                                      • x_orange90_x
                                        TCL 50S535 bad tcon or panel issue?
                                        by x_orange90_x
                                        Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                        03-29-2025, 11:02 PM
                                      • jostewcrew
                                        General panel/tcon troubleshooting question
                                        by jostewcrew
                                        when troubleshooting tcon vs panel issues, there are many guides and pictures showing issues of both. There is one question i have in the troubleshooting method that ive overlooked the answer to, or there isnt a direct enough answer for me to grasp so here it goes...
                                        when disconnecting the ribbon cables from the bottom of the tcon that lead to the panels (buffer?) boards, one at a time to see if any artifacts or image changes occur, i understand it to be that the act of an actual change itself is enough to point to the tcon board. except for a half black or white image caused by the...
                                        07-04-2020, 10:42 AM
                                      • advant
                                        by advant
                                        02-03-2020, 12:25 AM
                                      • chth96
                                        Is it possible to test small ceramic disc capacitor with analogue meter?
                                        by chth96
                                        I read EBOOK of Testing Electronic Component and found that
                                        "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                        Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                        It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                        Is it really possible to test small ceramic disc capacitor with analogue...
                                        03-09-2024, 10:03 PM
