General panel/tcon troubleshooting question
  • jostewcrew
    • Mar 2020
    • 79
    when troubleshooting tcon vs panel issues, there are many guides and pictures showing issues of both. There is one question i have in the troubleshooting method that ive overlooked the answer to, or there isnt a direct enough answer for me to grasp so here it goes...
    when disconnecting the ribbon cables from the bottom of the tcon that lead to the panels (buffer?) boards, one at a time to see if any artifacts or image changes occur, i understand it to be that the act of an actual change itself is enough to point to the tcon board. except for a half black or white image caused by the lack of the feed from the tcon as expected, lets say there are vertical lines or blurred image or something, other than the blank screen (black or white) on the half with the ribbon disconnected, if the other side clears up its the tcon? or is it that if it stays the same its the tcon?
    on the scenario of it being a defective panel, if removing one ribbon from the tcon does not clear up any lines present on that side of the screen, or it actually presents lines after removing the ribbon cable...its the display unit itself i understand it to be right?
    thanks for some clarification, the posts ive read gave great details and examples, but these questions remain after my reading and i see many new posts trying to determine the answers even though they have the same info available on here...so perhaps this needed to be asked and or clarified not only for myself.... thank you all.
  • Diah
    • Feb 2013
    • 6614
    Re: General panel/tcon troubleshooting question
    Originally posted by jostewcrew
    on the scenario of it being a defective panel, if removing one ribbon from the tcon does not clear up any lines present on that side of the screen, or it actually presents lines after removing the ribbon cable...its the display unit itself i understand it to be right?.
    with yours vertical lines scenario ..you are right.. if didn't cleared after removing one side ribbon guide us to panel parts. specially at HD TVs sets or below..
    UHD sets need more testing to reach the right judgments.
    • jostewcrew
      • Mar 2020
      • 79
      diah, ty for clarifying the panel side of the understanding i had.
      id like to understand more of the cut tape method. any good reading? id like to understand what signals are being blocked and such that may lead me to further understanding and knowledge of the circuitry. ty
      • mmartell
        General Questions on the Relationship Between Mainboard, TCON and Panel
        by mmartell
        My goal here is to be able to use boards on hand to swap into faulty sets when the faulty board is not obvious.
        I will start by asking what is the format of the output from the mainboard and is it generic in any way or does it vary by manufacturer and/or model ?
        And as far as I know a tcon and panel must be a matching pair because the timing of the signals and the voltages required to drive the panel are specific to the panel itself. (That may be a blanket statement that isn't true in some cases where the panel creates its own sub-voltages on its panel boards?)...
        01-06-2024, 01:32 PM
      • NWArkGuy
        Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
        by NWArkGuy
        Well, I will be the first to admit that I screwed up...
        In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
        I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
        I have 2 that I have found and have in my possession. ...
        10-12-2023, 10:13 PM
      • advant
        by advant
        02-03-2020, 12:25 AM
      • iglitare
        Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
        by iglitare
        i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
        Backlight seems to work, Sound (Setup menu after reset) works.
        If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
        Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
        With my small knowledge i would think at least the cables are good.
        Can this happen because of a bad tcon board?
        Or is it always a bad/shorted...
        09-04-2025, 07:13 AM
      • AK_777
        Sony KD-65A1 Repair – 4 Red Blinks Error
        by AK_777
        Hi everyone!
        I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
        Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
        02-20-2025, 04:15 PM
