Sony Bravia KDL-46W-5100 Vertical Lines
  • NickSteel
    • Sep 2016
    • 18
    • US
    Vertical lines. Most probable cause?
    I have unplugged and plugged T-Con cables.
    Thanks.
    Re: Sony Bravia KDL-46W-5100 Vertical Lines
    I say panel problem.
    • NickSteel
      • Sep 2016
      • 18
      • US
      Thanks.
      Even though I hate to "throw away" anything, I guess this has become a recycle candidate.
      • NickSteel
        • Sep 2016
        • 18
        • US
        I'm not very experienced with TV repair, but I did revive an LG last year with a couple new capacitors. So much satisfaction!
        • ivtec
          • Dec 2008
          • 1967
          Thanks.
          Bad Panel 100%
          • NickSteel
            • Sep 2016
            • 18
            • US
            Thanks, guys. Sending to BestBuy for recycle.
            • martino
              Not so "senior"
              • Aug 2013
              • 997
              • canada
              Bestbuy takes tv's in for recycle?
              You can also sell the boards on ebay? makes some cash on them...
              Proud owner of dozens of broken TV's and many,many,many boards.
              Our website and passion:http://hollenhundshepherds.com/
              • NickSteel
                • Sep 2016
                • 18
                • US
                Yeah. Best Buy takes, but for $25 fee. Where I live, there are no free recycle locations and I'm not into Ebay selling.
                If it had been a more simple part, I would have attempted it, just for the challenge, but........."A Man's Got to Know his Limitations".
                • budwich
                  • Jul 2015
                  • 3097
                  have you tried the "tape trick" on the tcon to panel connector (at the tcon)? there was some posts in the past whereby some have placed tape near the end of the ribbon such that it appears to stop some form of "connection issue" at the connector. Of course, this is a "hail mary"... but if you have time, potentially you might search and find some "comfort" there... if you are lucky.
                  • NickSteel
                    • Sep 2016
                    • 18
                    • US
                    Since the back is still off, I tried the tape on the top of the connectors to snug the fit.
                    No change.
                    Shame, as the picture is so bright and clear.
                    • budwich
                      • Jul 2015
                      • 3097
                      I don't think it was about snugging, I think it was more about contact "contamination" although that is more my read of the "fix".... as I do believe the tape was placed on the contact side of the ribbon. I do believe the link was originally posted by budm to some one else who was given the "bad panel diagnosis". Not sure of the details but perhaps budm might appear.
                      • NickSteel
                        • Sep 2016
                        • 18
                        • US
                        Yeah. And the lines are all across the screen, not just on half as one connector would result in.
                        I'm semi-retired and need a few small challenges anyway.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Panel dud, avoid at all costs. Guessing Shitsung aka Samsung panel seen them fail loads of times in the same way ?
                          • NickSteel
                            • Sep 2016
                            • 18
                            • US
                            Kinda late to avoid now.
                            • NickSteel
                              • Sep 2016
                              • 18
                              • US
                              Also, I think that if were a connection problem, only 1/2 of the screen would probably be affected, unlike my whole screen.
                              • NickSteel
                                • Sep 2016
                                • 18
                                • US
                                Curious.
                                Although I've accepted that the t-con should not be the problem and that the panel has failed, why do lines appear over the entire screen, not only on one side?
                                  https://www.badcaps.net/forum/attach...9&d=1475084407
                                  https://www.badcaps.net/forum/attach...7&d=1475189437
                                  I do not see the lines on the whole screen.
                                  • NickSteel
                                    • Sep 2016
                                    • 18
                                    • US
                                    These are better pictures. Hard to take with reflection.
                                      Are these new pictures taken after the ribbon cables between the T-CON and the panel were re-seated? Those coarse horizontal lines are usually due to improperly seated cables.
                                      • NickSteel
                                        • Sep 2016
                                        • 18
                                        • US
                                        After I reseated the cables.
                                        Just cleaned the cable ends with alcohol and reseated. No change.
                                        I can only access the cable ends that plug to the t-con board from the panel.
                                        • visionbluedemon
                                          Help. Sony kd-65x85dj vertical lines
                                          by visionbluedemon
                                          First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                                          Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                                          tried blocking LC lines too, but same results
                                          is it lcd panel issue or tcon board issue?...
                                          07-25-2025, 04:56 AM
                                        • gpo23
                                          Sony KDL-40V3000 - Vertical lines
                                          by gpo23
                                          i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                                          With the new t-con the color are good but there are vertical lines on all the screen :
                                          I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                                          Is there a way to fix the vertical lines on the new t-con ?
                                          Thank you for your help
                                          gpo23...
                                          10-04-2023, 09:11 AM
                                        • Stanley1843
                                          by Stanley1843
                                          06-29-2024, 11:54 AM
                                        • thstuff
                                          SONY BRAVIA XBR-55A8H - White horizontal lines / red LED flashes four times
                                          by thstuff
                                          This "free from a friend who was going to recycle it" SONY BRAVIA XBR-55A8H arrived with the bottom center RED LED repeating a four flash pattern. It was treated with kid gloves and was reported to have "just gone dead" and the OLED panel has no dents in the metal frame or cracks.
                                          Thread https://www.badcaps.net/forum/showthread.php?p=1091829 helped in proceeding as follows:
                                          1) Unplugged, then plugged set in while holding the remote VOL- and Power to factory reset.
                                          2) Waited 30 seconds, then pressed remote Power button and "Select language"...
                                          01-30-2023, 05:01 PM
                                        • dustman1747
                                          Sony XBR-65X900H vertical lines
                                          by dustman1747
                                          I have acquired a Sony XBR-65X900H to try and fix. It probably was a complete no power situation. The main board was replaced and the TV started turning on. I now have start sounds and backlights, but no image. I've replaced the t-con with no improvement. Cables all appear to be ok and seated properly. The TV took a firmware update and hard reset but neither helped.
                                          Using the tape trick I can get both side to display combinations of colored vertical lines. There is no change in the stripes and the pattern always appears the same. If I add additional tape strips I can get the screen...
                                          09-18-2023, 09:05 PM
