LG 55LX6500 Vertical bars
  • Twithers
    • May 2013
    • 69
    • U. S.
    Trying to resurrection an LG 55LX6500. Got it to power up, but I've got a vertical bar issue.
    I pulled and cleaned the 2 ribbon cables, with no change.
    I made some foam rubber spacers and put them between the frame support and both sides of the ribbon cables between the screen itself and the long boards that distribute the video signal (the actual name escapes me) along the panel. Put everything back together and got no change.
    Does that mean it's a bad tab bond on the display panel and ultimately a very expensive paper weight?
    This model retails for $3K, so if there's a way to fix it, that would be great.
    Thanks for the help.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: LG 55LX6500 Vertical bars
    Panel failure.
      Is the tab bonding on the top edge or on the bottom edge of the TV?
      • Twithers
        • May 2013
        • 69
        • U. S.
        Along the bottom.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          glass cleaner damage.
          see this often on bottom fed panels.
          • x_orange90_x
            Samsung UN46C8000XFXZA vertical bars/horizontal lines
            by x_orange90_x
            I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
            The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
            09-04-2023, 12:09 PM
          • x_orange90_x
            TCL 50S535 bad tcon or panel issue?
            by x_orange90_x
            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
            03-29-2025, 11:02 PM
          • Daren87
            Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
            by Daren87
            I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
            08-13-2023, 03:25 PM
          • zesko
            xps 9520 ribbon cable
            by zesko
            I have a XPS 9520 with broken daughter board and missing ribbon cable. I can fix the board by replacing the connector, but I can't find the correct ribbon.
            There is 2 models, idk which one is needed on my laptop.
            0xkvng
            00vpr2
            Daughter board is LS H822P. When I check for a palmrest, the board attached to have a 0xkvng ribbon. But when I check for LS h822p, it's 00vpr2 ribbon...
            Someone can help me with that please ? Idk the difference between these 2 ribbon but they definitely doesn't look the same..
            thanks...
            10-23-2025, 05:03 PM
          • Tr0ll
            by Tr0ll
            Original T-con:
            First replacement T-con:
            10-07-2023, 07:48 PM
