PSU with FAN8754 won't torn on
  • fejlong
    • Dec 2013
    • 55
    • United Kingdom
    Recently I got an LED TV Hannspree HSG1210 with no power symphtom.
    The power supply is a 40-P081C0-PWD1XG, I could not find a schematic for it other than from a similar TV, Philco PH32.
    The power board has a VIPER17L which makes 3.3V, and a FAN8754 which is not working or won't start.
    The VIPER17L is working and 3.3V is present. FAN8754 is making a rattling sound and does not operate the power mosfet.
    I have changed the FAN8754 and the power mosfet, thinking they are defective. But the 24V still does not appear.
    The four rectifier diodes I did change, still not working, I have 300V on the HV cap. there is near to 0V all the time on the power mosfet's gate. so the fan is not control it.
    Anyone knows where can I continue troubleshooting ?
    Any info whould be much apreciated
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: PSU with FAN8754 won't torn on
    First of all you need to make sure the motherboard is telling the Psu to come on, what is the Pson voltage at ?
    • CapLeaker
      Leaking Member
      • 8005
      no boosted voltage on the primary filter cap(s) = no 24V.
      • fejlong
        • Dec 2013
        • 55
        • United Kingdom
        Pson it is labeled P-ON, and it is about 3.2V
          Did you find the spec sheet for the 'FAN8754'? Need to find out if you have VCC to run the IC or not, I expect around 15 VDC.
          R112 is less than 1 Ohm?
          • fejlong
            • Dec 2013
            • 55
            • United Kingdom
            Sorry for that, It's a FAN6754. I am attaching the datasheet.
            Resistor R112 is labeld as 0.15 Ohm, with the multimeter it shows 0.2 Ohm.
            Supply Pin 7 of IC has 18.5V ,
            HV pin 4 should be at least 104V according to the datasheet page 5 high voltage section, and this has only 94.5V don't know what is causing this
            • dick_barton
              • Aug 2015
              • 6642
              • Wales
              Check the components connected to it. D101, R102 (563 = 56K), Rxxx (104 = 100K) in series with it.
              Edit
              18.5V for pin 7 (VCC) is above the spec for the chip to operate. Vcc min is stated as 15.5V, typical 16,5V, maximum 17.5V
              What's the voltage on the feedback pin 2 which should be <4.6V
              • dick_barton
                • Aug 2015
                • 6642
                • Wales
                The mosfet pin needs to be soldered and looking at your photo there appears to be a solder shard between pins 1 & 2 of the FAN chip although it could just be the lighting.
                • fejlong
                  • Dec 2013
                  • 55
                  • United Kingdom
                  I have did a check on those components, everything looks good.
                  initalIy I have changed the mosfet, the solder is good on the mosfet, may it stil has some flux on that area.
                  • dick_barton
                    • Aug 2015
                    • 6642
                    • Wales
                    And is that a small slither of solder between pins 1 & 2 of the IC or just a reflection of the light on the photo?
                    • fejlong
                      • Dec 2013
                      • 55
                      • United Kingdom
                      Between pins 1 and 2, It is flux wich remained after replacing the IC.
                      I will check the voltage on the feedback pin and be back to you.
                      Attached some close up pics of the IC
                      • fejlong
                        • Dec 2013
                        • 55
                        • United Kingdom
                        On feedback pin 2 is 2V
                        • fejlong
                          • Dec 2013
                          • 55
                          • United Kingdom
                          There is only 2V on the feedback pin, what does this means?
                          Where should I look for the problem?
                          • dick_barton
                            • Aug 2015
                            • 6642
                            • Wales
                            The datasheet says that if FB > 4.6V for more than 55mS then it latches off the PWM.
                            With 2V at this pin then that is not the problem.
                            • dick_barton
                              • Aug 2015
                              • 6642
                              • Wales
                              Was that with an identical part or substitute?
                              • dick_barton
                                • Aug 2015
                                • 6642
                                • Wales
                                You are correct regarding the HV pin input voltage being low. I would be tempted to replace the two resistors and diode feeding it and see if the voltage at the HV pin increases.
                                • fejlong
                                  • Dec 2013
                                  • 55
                                  • United Kingdom
                                  I tried that, no change
                                  • dick_barton
                                    • Aug 2015
                                    • 6642
                                    • Wales
                                    What is the voltage at the other end of the diode and resistors?
                                    • fejlong
                                      • Dec 2013
                                      • 55
                                      • United Kingdom
                                      Regarding wich ground ?
                                      • dick_barton
                                        • Aug 2015
                                        • 6642
                                        • Wales
                                        The same ground as you used to measure the 17.5V in post #6
                                        Edit
                                        What is your mains supply voltage to the set.
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • Thomas Smith
                                          Asus Tuf gaming fx506l no power, mosfet does not open
                                          by Thomas Smith
                                          Hello everyone, I have an ASUS FX506LI laptop that does not turn on, and I need help diagnosing the issue. Here is what I have checked so far:
                                          Initial Symptoms:
                                          • The laptop has no power at all (no LEDs, no fan spin).
                                          • No 3.3V or 5V present on the board.
                                          • The power button (NBSWON#) reacts but only changes from 0V to 0.5-0.11V.
                                          Power Rail Checks:
                                          1. Charger input (FETs PKCH2BB)
                                            • Drain: 20V, Source: 0V, Gate: 0V (FETs not switching).
                                          2. BQ24780S Charger IC:
                                            • VCC and ACDET are present.
                                            • ACN / ACP, ACDRV, BATDRV, LODRV, HIDRV, ACOK, SRN, SRP – all 0V.
                                            • Shunt resistor has 10Ω to ground.
                                          03-30-2025, 03:38 AM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
