VGA MOSfet permanently shorted and loss of MOSfet pad
  • Nooy
    • Hungary
    Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
    I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet is faulty? I can easily measure the Gate with an oscilloscope during operation, if I see a difference with the other MOSFETs, does this not cause a problem?​
    Another more serious problem is that when removing a Saphire Nitro+ RX4708G MOSfet (IR3553), the REFIN footpad was damaged on the panel and apparently cannot be repaired. There are two other free non-soldered MOSfet slots on the card. Do you think that the currently unused MOSfet space can also be used by transferring the R-C-L components of the damaged part? There is no prohibition on these PWM pins in the controller, this can also be measured with an oscilloscope, does it give PWM control?
    Since I'm still practicing SMD soldering and that's why I lost the micro-sized pad, what advice would you have for removing parts that are very difficult to solder with hot air? Even though I increased the air to 430 degrees, it was very difficult for the MOSFET to come down and the flux just smoked. What is the trick to easy hot air desoldering?
    Thanks,
  • harp
    • Jun 2022
    • 651
    • Planet Earth
    Generaly, put card on preheater plate on about 120-150 degree celsius. When you can, touch a legs with fresh solder63/37... This will make desoldering easier because of smaller difference in temperature.
    For videos chanell,
    northwestrepair is all about vga repair in depth
    Northridgefix is all about soldering and desoldering technique
    • McWhitePink
      • Apr 2023
      • 103
      Can you post a picture?
      usually even you lost the pad it should be still able to mount the part and wire it.
      • McWhitePink
        • Apr 2023
        • 103
        hot plate is necessary for this case.
        • Nooy
          • Hungary
          Yes, i tried to take a picture
          As I take a closer look at "2." he didn't even survive - but this is probably not a big problem, there are other legs with this function Could the next empty FET's place be used instead of the faulty one?
          Click image for larger version  Name:	ksnip_20240216-182041_2.png Views:	0 Size:	1.63 MB ID:	3217856
          • McWhitePink
            • Apr 2023
            • 103
            Pin 2 in your picture should be GND. you can check it.
            • chestercc
              Alienware M18x Shorted CPU Mosfet
              by chestercc
              I've got an old Alienware M18x R1 which shorted out the charger whenever it was connected. Tracked down the short to two shorted caps and burned CPU power controller caused by a shorted mosfet on the CPU's graphic power supply.
              I've replaced the faulty mosfet, two shorted caps and the CPU Power controller (NCP6151S52MNR2G).
              Issue is now whilst there is no short if I attempt to power the system on the fans spin for a couple seconds there are no lights and no further action - the PCH is heating up but there is no CPU power coming out but there is an enable signal...
              07-16-2022, 06:05 AM
            • mat2k
              iMac 2017 PSU - shorted PFC mosfet
              by mat2k
              I am trying to fix an iMac 2017 PSU, initially came with a blown fuse and shorted PFC MOSFET (6R199P). After visual inspection and some measurements I replaced the FET with a P20NM60 and tested with 100w series lamp, and it lasted 1 second before going into dead short. The PFC controller chip (NCP1605BG) and its passives appear fine (passives measure OK), but I do not know if there is a simple way of testing the NCP1605 as I wouldn't like to blind-replace it.
              There was some slight blackening of the solder on the PFC controller passives so I reflowed them all with some flux. I am waiting...
              03-13-2025, 11:31 AM
            • daemon123
              MSI GTX-980ti shorted MOSFET on memory rail
              by daemon123
              Hi All,
              I have this MSI GTX-980ti Gaming Golden Edition. It had shorted mosfet on memory. Replaced the shorted i.e. Q47 PK616BA with 4C09N and the card ran fine for a month. Then suddenly again the same problem. This time when i replace it 4C09N or with replacement PK616BA (Aliexpress) it gets shorted. As soon as turn on the PC the PSU shuts down and the same mosfet Q47 gets short.
              What should be the next step. Kindly guide.
              The board view files for this gpu is available and attached. https://www.badcaps.net/forum/showthread.php?p=1237952...
              05-10-2023, 11:05 AM
            • Jane
              How do you test MOSFET in laptops ?
              by Jane
              I tried to use this method:
              Testing an N-channel MOSFET:
              Step 1: Discharge the Gate (turn off the MOSFET)
              Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
              Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
              Step 2: Charge the Gate (turn on the MOSFET)
              Now, place the red probe on the Gate (G) and the black probe on the
              09-27-2024, 03:31 AM
            • Reintar
              Dell Inspiron 15 7567 (LA-D993P) - No power after replacing blown inductor and shorted mosfet advice needed
              by Reintar
              First of all, I'd like to mention that I'm a novice when it comes to laptop repair, although I do have some experience with soldering.
              One day, my laptop experienced a severe stutter, and after rebooting, it failed to boot into Windows. I decided to disassemble it and found that the PL900 component was blown. Later, I came across a post (https://www.badcaps.net/forum/troubl...error%E2%80%99) with the same problem, where...
              08-30-2024, 06:13 AM
