Tv Inverter works without Output caps but why?
  • reessi
    • Jan 2016
    • 326
    On the following PSU/Invert board -> 17IPS02-2
    The fault is that the tv backlights do not turn on, there are 4 backlights, wired in pairs together. Each pair has a ceramic cap across the outputs. I have a small diy meter off ebay that can recognise components, it didn't recognise them. My multimeter said they were open circuit. After removal the backlights work so I bought new ones which the diy meter correctly reads. But the backlights do not work when I put them in circuit
    So I would like to know can I just leave them out as the tv now works?
    But I would like to know what they are there for and why the lights will not work with the new ones? Are the lights failing and this could cause this to happen?
    Many thanks- Simon.
  • chrismurphy
    • May 2014
    • 251
    • australia
    Re: Tv Inverter works without Output caps but why?
    simple answer NO
    • dick_barton
      • Aug 2015
      • 6642
      • Wales
      Do you have photo's of what you removed and what you replaced them with showing their markings.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Dont run it ! The caps are used to stabilise the ripple on the input of the fets with out them the fets will blow shortly !
        • CapLeaker
          Leaking Member
          • 8116
          Just think man... they are there for a reason.
          • Alastair E
            Chief Womble
            • Mar 2013
            • 1963
            • U.K.
            You're driving a gas/mercury discharge-lamp. those disc ceramics are there for hash supression, nothing more.
            I have been known to hack 'em out with no negative effects--Who these days listens to long-wave radio after all!
            TELEFIX
            • reessi
              • Jan 2016
              • 326
              Thanks for replys. Some conflicting replies though, so some clarfication, I replaced with:
              Blue ceramic cap:
              3KV 4.7nF
              From ebay:
              http://www.ebay.co.uk/itm/2312562422...%3AMEBIDX%3AIT
              The same as original.
              They were connected right next to the lamp sockets so paralleled on the output.
              See attached pic. Only 2 caps were connected one on each pair. See arrows showing one for one of the pairs. The spaces on the board for more were not populated.
              Thanks.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Ahh my bad I thought he removed the input caps lol
                • reessi
                  • Jan 2016
                  • 326
                  Looks like we're in agreement that they're to stop interference, but any idea's why replacing with good ones stops the backlights coming on? The picture still comes on and can be seen with a flashlight.
                  Thanks.
                  • rievax_60
                    • May 2012
                    • 897
                    • australia
                    Usually capacitors in that area are there to tune the resonant frequency of the secondary circuit. 4.7nf doesnt sound right. Are you certain that the originals are this value?
                    Take a photo of the other side of the PCB if you get an opportunity.
                    Did the back lights not work at all originally or did they light for a short time?
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      Yes, no way 4.7nF is the right value there. I think it was 4.7pF
                      A working TV? How boring!
                      • reessi
                        • Jan 2016
                        • 326
                        Ah, looks like I ordered the wrong value then, I'll try and find the originals and check the markings. The new ones are def nF.
                        Cheers.
                        • reessi
                          • Jan 2016
                          • 326
                          Oh and to answer rievax_60, the backlights did not light even for a second when I first looked at the tv.
                          Cheers.
                          • dick_barton
                            • Aug 2015
                            • 6642
                            • Wales
                            Cheers.
                            That's why I asked for photo's of the old and new with their markings shown in just this event.
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              • Romania
                              You are lucky that your inverter works like that. Usually that capacitor has the purpose of making a LC resonator circuit with the inductance of the transformer. This generates the high voltage necessary to strike the CCFLs. If that capacitor is burned or missing the result is usually the same - no backlight at all, not even a flash, as the voltage cannot get high enough to strike the lamp.
                              • culcuhain
                                • May 2016
                                • 186
                                • U$@
                                Some of us do... and Shortwave too...
                                • x_orange90_x
                                  by x_orange90_x
                                  01-29-2025, 09:24 PM
                                • lostone
                                  Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                                  by lostone
                                  Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                                  First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                                  When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                                  05-19-2024, 11:40 AM
                                • kamiewtype
                                  MPG Z590 No display output with known working GTX 1060/RTX 3070, works fine with GTX 1030
                                  by kamiewtype
                                  I have a customer machine on my bench right now that's stumped all the techs, so I decided to come here for help.
                                  The specs are:
                                  MPG Z590 Gaming Carbon Wi-Fi (MS-7D06)
                                  Intel core i9-10900kf
                                  2x16gb Corsair Vengeance kit
                                  BIOS ver is E7D06IMS.1B0, from 6/12/2023
                                  The machine was brought in because it would not POST after a GPU upgrade from a GTX 1030 to an RTX 3070. The customer also brought in the original GTX 1030, as well as a GTX 1060 that the machine also wouldn't POST with.
                                  I tested the 1060 and 3070 on my bench (ASRock X570 Phantom Gaming...
                                  11-01-2024, 10:52 AM
                                  NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                                  by sam_sam_sam
                                  I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                                  I bought this from an eBay seller but unfortunately they only had one
                                  I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                                  I bought three of from them to also make battery packs with this output power limit in mind
                                  I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                                  04-23-2025, 05:50 AM
                                  Corsair CX750M [Model 75-002019] - burned output toroid inductor
                                  by momaka
                                  Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
                                  So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
                                  09-19-2021, 08:44 PM
