Isolation Transformer
  • tech2014
    • Aug 2014
    • 807
    Re: Isolation Transformer
    Originally posted by budm
    Are you sure you received the GIS-1000 as shown in the web site and matched the PDF spec I provided? 1000VA is a BIG transformer.
    Show us the EBAY seller web page and the picture of the unit you bought.
    I see some on EBAY:
    http://www.ebay.com/itm/Stancor-GIS-...oAAOSwd2xXP~t-
    It is the same transformer, same as in the link you provided.
    • R_J
      • 9633
      That link http://www.ebay.ca/itm/222226718872#ht_166wt_1319 shows a picture of a 220 volt to 110 volt step down transformer. which is what you got
      I suspect it is a GISD-1000
      So if you connect it to a 220 volt outlet you will get your isolated 110 volts
      • tech2014
        • Aug 2014
        • 807
        The eBay seller lied in his listing as it says its an isolation transformer. Opened a return request since its useless to me.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          The ebay picture above may well be an Isolation transformer but the spec says:
          Input 230V 50/60 HZ
          Output 115V 1000VA 8.7A
          To check if it is an isolation transformer measure resistance between the input and output terminals which should be open circuit between Live In /Live Out, Neutral In / Neutral Out.
            GISD-1000 IS isolation and also a step-down transformer as shown in his description and also in the spec. sheet.
            'Stancor GISD-1000 Isolation Transformer Used.
            Plugged in and works.
            Mounting brackets are slightly bent (see pics). Device shows some wear and tear.
            Input 230V 50/60 HZ
            Sold as is no returns'
            See attached spec sheet for GISD-1000.
            You should have bought GIS-1000
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              #26
              +1 Agree with Budm and it looks like non returns.
                • 31303
                sellers description is crystal clear.
                makes a nice change!
                • tech2014
                  • Aug 2014
                  • 807
                  I did a resistance check and there is no continuity between the input and output so it is indeed isolated. Problem is I am only getting 60VAC since it is a step down. Is there a way to modify or some way i can still get it to output 120VAC.
                  • tech2014
                    • Aug 2014
                    • 807
                    Input 230V 50/60 HZ
                    Fuck sakes wasted over $120 on this useless piece of shit, just a big fucking paperweight. I may try and sell it on ebay to recoup.
                      • 31303
                      dont you have 230v at your panel like americans?
                      • tech2014
                        • Aug 2014
                        • 807
                        we use 120VAC here.
                          • 31303
                          not exactly my question,
                          in the u.s. the main fusebox is fed with 120-0-120
                          so you can use both phases to get 240v for big stuff like tumble-dryers
                          • tech2014
                            • Aug 2014
                            • 807
                            oh ok I get you now. I will have to check my fusebox,
                            • mockingbird
                              • Dec 2008
                              • 5488
                              #34
                              If you plug it into the dryer or oven outlet, you'll get 240v.
                              • learnmore
                                Help choosing replacement transformer for Levoit 600S SMPS
                                by learnmore
                                Hello Community,
                                I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
                                Peace
                                LM...
                                11-04-2025, 09:35 AM
                              • harp
                                isolation transformer from two 240/12, wiring?
                                by harp
                                When is talk about making isolation transformer on poor-man way, always I see schematic 240/12-12/240.
                                So, I wonder, is this wiring from my attachment it work, bringing some good feature or it is bad idea and why?...
                                11-25-2022, 05:11 PM
                              • Briesmith
                                Can High Side damage on an SMPS get across the Transformer to the Low Side?
                                by Briesmith
                                I have a blown smps and I am looking for some reassurance as to the amount of diagnosis I have to do. It blew the instant I plugged it in not under any load.
                                As you can see from the attached pix, the damage is located around the main or bulk capacitor (since removed for testing) and the resistor array/network that drives it (the bunch of SMD components to the left of the YAMAHA YC775 AMPS logo). The burn mark on the frame clearly shows the pins of the capacitor. And, for the avoidance of doubt, there is no way the board could have contacted the frame, it was correctly mounted on...
                                05-06-2023, 09:36 AM
                              • repair-it
                                Need advice testing a samsung power supply board with scope
                                by repair-it
                                I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                                07-12-2025, 11:00 AM
                              • mikey5791
                                Is it possible for transformer substitution?
                                by mikey5791
                                Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                                Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                                My questions are
                                1. How do i test to see if the transformer is in good working condition?
                                2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                                Hope you guys understand what i was asking. My intention is...
                                11-03-2022, 02:11 AM
