LG/Optica 7074c / 42" SmartTV
  • badcaphunter
    • Jan 2016
    • 88
    • England
    Hello BadCaps Community my friend got this TV through Buy As You View, about 2 weeks ago the bottom half of the screen started going dark, i have reset it and checked energy saving and brightness settings but the problem still persists, when i turn the TV on it is fine but after 3-4 seconds the shadow appears. I have opened the set up and checked all the boards and reseated every cable. i suspect this is a panel issue. Any help would be appreciated.
    He has had the tv just over 18 months and his warranty has expired.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: LG/Optica 7074c / 42" SmartTV
    Looks like bad backlights to me.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Wheres Lg come from as well ? Nothing Lg about this I dont think. Also yes I agree with Andy Leds are out. Please post images of the boards.
      • badcaphunter
        • Jan 2016
        • 88
        • England
        Its an LG panel, the TV comes on full brightness when turned on from cold but 3-4 seconds then it goes dark, i will post pics soon
        • badcaphunter
          • Jan 2016
          • 88
          • England
          Sorry about the pics, i will post better ones tomorow
          • badcaphunter
            • Jan 2016
            • 88
            • England
            Hope these help
              https://www.badcaps.net/forum/attach...2&d=1471877937
              Check the DCV on the test points VR 1~VR 6 with ref. to the chassis GND.
              • badcaphunter
                • Jan 2016
                • 88
                • England
                Thanks Budm, when taking the readings the 2 coils on the inverter board were pretty hot, not sure if that is normal.
                VR1 - 0.8v
                VR2 - 0.7v
                VR3 - 0.9v
                VR4 - 1.1v
                VR5 - 1.1v
                VR6 - 1.0v
                • badcaphunter
                  • Jan 2016
                  • 88
                  • England
                  These are the LED strips that this panel uses
                  • badcaphunter
                    • Jan 2016
                    • 88
                    • England
                    The bottom LED's are failing but the top ones are still working, i took the screen apart and 1 of the strips is dying but is this defective LED's or something else?
                      The reason that most of the TV with LED backlights have failed LEDs is due to the LEDs are being driven too hard close to or at the maximum spec with no regard to the ambient temperature so they failed. When you are done fixing the TV you should turn down the backlights level to as low as you can to extend the life of the LEDs.
                      I am surprised that the protection circuit did not kick in due to bad LEDs, may be they just do not care.
                      This is the Notes from LG LED spec:
                      Operating the LED beyond the listed maximum ratings may affect device reliability and cause permanent damage.
                      These or any other conditions beyond those indicated under recommended operating conditions are not implied.
                      The exposure to the absolute maximum rated conditions may affect device reliability.
                      Example of bad design in LG:
                      https://www.badcaps.net/forum/showthread.php?t=54197
                      • badcaphunter
                        • Jan 2016
                        • 88
                        • England
                        I thought the TV had 2 banks of LED's but its only 1 strip with 60 LED's, they all light up from cold then most of them die and a few stay lit. as u can see in the picture 8 are lit then 1 is dead then the 10th 1 lit.
                        I have tested each individual LED with a battery and they all seem to work fine.
                        Thanks for your help
                        • badcaphunter
                          • Jan 2016
                          • 88
                          • England
                          It looks like LG are not renowned for there backlights :o
                          Could a problem with the inverter cause these symptoms or would it be worth buying a new LED strip and hoping for the best?
                            Each bank has three set of LED string, that why you have VR1~VR6.
                            • Diah
                              • Feb 2013
                              • 6370
                              from yours photos i can say the LED are less than 60 on one strips as there are 3 groups of LEDs on each strip please check again, this LEd edge one 6 Volts, its crazy to be if one groups will be 20 LEDs
                              • badcaphunter
                                • Jan 2016
                                • 88
                                • England
                                Hey Diah, i have double checked and there is 60 LEDs on the strip, it is numbered in 5s up to 60
                                • badcaphunter
                                  • Jan 2016
                                  • 88
                                  • England
                                  Pics
                                  • Diah
                                    • Feb 2013
                                    • 6370
                                    dear friends,, yours TV set look like DIY TV , i will never believe on what printed on.. when you have booting firmware on 2GB SD card, you would believe on what printed ? lol check with finger 1.2.3 .4 sorry mat
                                    • Diah
                                      • Feb 2013
                                      • 6370
                                      it would be nice if you dump the total of SD card as zip and posted here... very interesting one.. did yours SET android firmware?
                                      • badcaphunter
                                        • Jan 2016
                                        • 88
                                        • England
                                        No but i think this was TV on finance so they could disable the TV remotely, it can be flashed to android if you know how, it still works without the sd card.
                                        • AstutePauciloquent
                                          Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
                                          by AstutePauciloquent
                                          Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
                                          I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
                                          11-23-2023, 11:02 PM
                                        • survivalbloke
                                          Macbook A2289 - backlight problems - have checked a lot already - out of ideas
                                          by survivalbloke
                                          This is A2289, board 820-01987-A. It came in with the screen not working. We could not see any image on the screen, so we ruled out a backlight issue and instead replaced the panel. The display now comes up, but no backlight.
                                          I didn't see any signs of liquid damage, but there was some odd looking spots around U8400. F8400 has voltage on either side of it, and I have 5v present on R8444 and R8445. I did not have 3.2v at R8442 so I figured U8400 was bad, and I replaced it. After replacement, a brief probe to R8442 showed 3.2v so I assumed I had fixed the device. After reassembly however,...
                                          09-12-2023, 11:44 AM
                                        • letmealone
                                          Smart Tech LE-4048SA stuck at SMARTTV logo: problem solved.
                                          by letmealone
                                          I had this tv set, stuck at the 'SMARTTV' screen with coloured logo. Impossible to find the original Smart Tech firmware, so i searched in kazmielec.tech some firmware compatible with the tv-set hardware (CV338H-T42 card and Y400HJ6.PE1 screen). The firmware i tried was wrong and it bricked the TV, just showing a black screen and not entering stand by anymore. I supposed it needed special hardware to reflash the NAND, but i was wrong, it just needed a working compatible firmware. Still in the kazmielek page i tried ' CV338H-T42_1920x1080_Telefunken TF-LED43S81T2' and it finally worked. I wrote...
                                          09-16-2024, 10:03 AM
                                        • kalemaroni
                                          MAG274QRF-QD 27" gaming monitor half backlight shadow
                                          by kalemaroni
                                          A customer called me up and said that half the screen was like a shadow - presumably the backlight has partially gone. I've never done a repair like this on a monitor, only circuit board based repair on Macbooks etc - is it something that's doable or generally not?
                                          04-23-2024, 03:52 PM
                                        • Zilicon
                                          AHL50/ ABL52 LA-C701P Rev:1.0 Turns on but turned off after few seconds
                                          by Zilicon
                                          Hearty greetings to everyone, trust you all are doing excellently well.
                                          Please, I have the above problem, the laptop turned on after the switch was activated but it will turns off in less than 2 seconds.
                                          The power stables in very rare case. Once it was stabled, everything works fine.
                                          Once the power switched is pressed, 5V and 3V were present.
                                          The things i have done:
                                          1. I have check for shorts on the board, but nothing. The board is short free
                                          2. Not a power switch problem, it behaves the same without the switch ...
                                          06-10-2024, 05:05 AM
