LG 47LN5790 badly burnt out LEDs
    Got this one in today, the backlights flashed on for seconds.
    It looks like bad design to allow that much damages.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: LG 47LN5790 badly burnt out LEDs
    Wow thats mental ! Wonder if they seen it set fire ? Does it smell bad ? Also what you think caused it to burn that bad ?
    • fredaelsadany
      • Jan 2016
      • 66
      • EGYPT
      hallo
      thank you MR budm
      what happened to the LCD ITSELF can have photo for any bad damage for it.
      it is concentrated in certain place can be some water came inside .. strange .
      thank you MR budm for inf
        More cheap LEDs from China failing at high temperature.
        The most likely cause was a resistive device failure. The LED failed in such a way that its power dissipation increased massively (Vdrop increased.) Controller did not detect a fault because usually it only detects open circuit LEDs. This probably didn't start a fire because the set will use flame retardant plastics, however it could cause a fire if next to curtains or something similarly flammable. Not to mention the toxic fumes from burning plastic.
        The fact that so many LG "LN" series sets use the same LEDs as Vestel crap ought to say something about LG's supplier standards.
        • Diah
          • Feb 2013
          • 6435
          no way, this is never being LED failure , as it LG , with LN and LM series with this 2 row LED backlight had protection level at power powered, this why its blink now just once, this is out side house burning, would be nice to see if the back cover from the top was in touch
            The damage is only inide the panel, when the backlights flashed on I can see the images, black soot inside, the traces on PCB the LED in that section burnt.
            It has more than one set of the strings so the good string still lit up before going into shutdown, the burnt LEDs has open circuit now, so basically it burnt open.
            It smells bad inside the panel but I did not smell anything until I open up the panel.
            The person that drops the TV said no the images on the screen, but still has sound, no sign of damage from the outside or inside.
            • Diah
              • Feb 2013
              • 6435
              maybe he brought it direct from Alberta fire ?? i wounder now did you take look on the reflection plastic board which sitting over led, it had burning or not ????
                https://www.badcaps.net/forum/attach...2&d=1462647571
                The white sheet burnt, the thick diffuse burnt, the 3/4" dia white sheet under the LED LENS also burnt.
                https://www.badcaps.net/forum/showth...604#post655604
                • Diah
                  • Feb 2013
                  • 6435
                  if this set not from Alberta Fire disaster , then tequila or higher drops on, Good that PCB still on
                    I'm 90% sure this is LED chip failure. This is what happens when a lot of power is dissipated in a small device with very limited protection circuits.
                    I have seen similar things with poorly designed LED lamps. I have ten small LED lamps that have all failed in the same way, small LED chip failure usually with a small burn mark but sometimes causing a little more damage.
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8320
                      that's pretty bad.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Its the Led for sure, no way does the trace randomly burn like that. Agree with what Tom says the Led acted as a resistor basically and dropped too much power getting very hot and catching the plastic next to it. Dont know if anyone else has done this but that plastic burns very well and fast, only need a small flame or alot of heat before it starts burning and melting. Seems common on these Lgs for the Leds to fail like that never seen it on Vestels though.
                        • Diah
                          • Feb 2013
                          • 6435
                          Tom, with all respect you should know what kind of material built on LED, this LED in set of LG LN are 3.2 V forward voltage at 50 Lm with may 0.450 mA,
                          All LED made in china, and consider 0.450 mA what it can burn...
                          • Diah
                            • Feb 2013
                            • 6435
                            by the way, why you put the fault on LED and not on PCB which fail to turn off its protection..if as you said LED will be resistors, ... what about its zener diode ? and why now now PCB protection working ?
                              Yes, under normal operation the LED operates at 3.2V @ 450mA so power dissipation is ~1.44W. Approximately 20% of input power is emitted as light; the rest is dissipated as heat in the chip. 1.2W is a lot of power, but not enough to cause this damage. (Normally these LEDs run at 85C in an ambient of 35C, so 1.2W ~ 50C or 42C/W thermal resistance.)
                              It is possible that the LED has an internal failure where it becomes very resistive. Still conducting current and may still emit light but no longer dropping just 3.2V. Failure modes can include, but are not limited to: loose bond wires, one or more bond wires failing open circuit, parasitic structure short, or a crack in the LED die.
                              Hypothetical example: Say one of these faults leads the LED to still work but with additional 50 ohm series resistance. Additional ~25V dropped across LED is not noticed by controller circuit as over voltage threshold is set quite high. Power dissipation in the LED chip is now >15 watts. This power raises temperature to >500C quickly causing LED silicon to fuse into a short circuit, and further increasing power dissipation and the resulting damage seen here.
                              This is the end result if the LEDs do not have protection/monitor circuits attached to every single LED, usually in simple constant current ballasts like this. (Inexpensive devices exist that can be added to individual LED chips, but most manufacturers do not bother to include them.)
                                Where did the heat come from?
                                • pgram
                                  • Apr 2016
                                  • 37
                                  I had a similar LED failure on the LG 39LN5700 I'm working on although not quite this extreme. The LED in my TV also looked to have caught the white backing on fire and produced a strong burnt smell. I tried to contact LG about it, but they never responded to my email.
                                    Ahh, thanks! I was looking for that link to show the same failure mode.
                                    Looks like LG needs to own up to this failure mode.
                                      Interestingly, the power appears to be dissipated almost entirely along the thin bottom traces, and hardly any power is dissipated in the large copper sections either side of the LED. I had thought these sections were supposed to be heatsinks, but clearly they do not function well.
                                      • SLK001
                                        • May 2014
                                        • 264
                                        Is it possible that an LED reflowed and slid down to short the pad out? That might account for the burning of the narrow traces. However, I would have thought that the protection circuit would have jump in somewhere along the line.
                                        • electomech-fixer
                                          First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
                                          by electomech-fixer
                                          I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
                                          I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
                                          09-15-2025, 01:42 AM
                                        • Pipolups
                                          Corsair K70 LUX RGB dying LEDs
                                          by Pipolups
                                          Hi there !
                                          I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                                          Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                                          10-08-2024, 11:58 AM
                                        • dicky96
                                          Zotac GTX 260 burnt component - can anyone identify?
                                          by dicky96
                                          Hi guys
                                          This Zotac GTX 260 had a high side MOFET on one Vcore VRM phase short circuit Drain to Gate (Not short Drain to Source)
                                          This has burnt out the drive IC L3E (ADP3110A) and also an SOT-23 device very close to the driver IC. According to the PCB markings 'Dxxx' this is likely to be a diode.
                                          Basically the VRM has 4 phases, two powered from one 6 way connector and two powered from the other 6 way
                                          I would assume each pair of phases are basically identical, the burnt out phase has SOT-23 devices WW1 plus the burnt one.
                                          The good phase...
                                          12-01-2021, 01:02 PM
                                        • THE GTC
                                          Insignia NS-37D20SNA14 intermittent LEDs
                                          by THE GTC
                                          So I use this TV daily as a second monitor for my PC or my Playstation - at one point a few months back I tried to fix the problem - but in the process, I figured out something that works so I haven't posted this for awhile. It is an annoying trick to have to do though, so I decided to post about it to see if anyone could spot what's wrong. It baffles me because it works on it's own half the time.
                                          When I first got this TV, I was told it wouldn't turn on, and of course I did the flashlight test, and the image was there. Also, the red LED on the front indicated that it had power (it...
                                          11-03-2020, 02:40 AM
                                        • swimllamaswim
                                          Precision 5550 LA-J191P No Power, Burnt ISL9538
                                          by swimllamaswim
                                          I picked up this Precision 5550 to fix up recently, and found that the ISL9538 chip was burnt on pin 14 (CSIN). The two left side Type C ports negotiate at 20v, and the right side one only negotiates at 5v. I also found the EMI protection diode, DT35, was burnt on that side. I pulled the ISL9538 off, checked for any other obvious shorts, repaired the pad, and put a new one on. Now, I still do not get power, and there is a rapid clicking sound from somewhere on the board that I can't pinpoint.
                                          Here are the voltages measured at that chip:
                                          To note, DCIN at Pin 17 is low,...
                                          09-21-2025, 12:26 PM
