LG/Optica 7074c / 42" SmartTV
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    #41
    Re: LG/Optica 7074c / 42" SmartTV
    Maybe your soldering ? Or polarity ? Its easy to mess it up lol good work
    • Diah
      • Feb 2013
      • 6599
      Originally posted by badcaphunter
      Problem solved, must have been dodgy LED's or a bad connection. TV is back up and running... after killing 20 LED's
      now you have the mood and ability to change any total edge LED strips in short time as i learned too..
      • badcaphunter
        • Jan 2016
        • 88
        • England
        #43
        Thanks for the help everyone.
        I should have got some solder paste really, one thing to note if you heat the strip from underneath it is easier to work and causes less stress on the LEDs and i would not try
        this without a rework heat gun.
        • AstutePauciloquent
          Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
          by AstutePauciloquent
          Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
          I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
          11-23-2023, 11:02 PM
        • survivalbloke
          Macbook A2289 - backlight problems - have checked a lot already - out of ideas
          by survivalbloke
          This is A2289, board 820-01987-A. It came in with the screen not working. We could not see any image on the screen, so we ruled out a backlight issue and instead replaced the panel. The display now comes up, but no backlight.
          I didn't see any signs of liquid damage, but there was some odd looking spots around U8400. F8400 has voltage on either side of it, and I have 5v present on R8444 and R8445. I did not have 3.2v at R8442 so I figured U8400 was bad, and I replaced it. After replacement, a brief probe to R8442 showed 3.2v so I assumed I had fixed the device. After reassembly however,...
          09-12-2023, 11:44 AM
        • letmealone
          Smart Tech LE-4048SA stuck at SMARTTV logo: problem solved.
          by letmealone
          I had this tv set, stuck at the 'SMARTTV' screen with coloured logo. Impossible to find the original Smart Tech firmware, so i searched in kazmielec.tech some firmware compatible with the tv-set hardware (CV338H-T42 card and Y400HJ6.PE1 screen). The firmware i tried was wrong and it bricked the TV, just showing a black screen and not entering stand by anymore. I supposed it needed special hardware to reflash the NAND, but i was wrong, it just needed a working compatible firmware. Still in the kazmielek page i tried ' CV338H-T42_1920x1080_Telefunken TF-LED43S81T2' and it finally worked. I wrote...
          09-16-2024, 10:03 AM
        • kalemaroni
          MAG274QRF-QD 27" gaming monitor half backlight shadow
          by kalemaroni
          A customer called me up and said that half the screen was like a shadow - presumably the backlight has partially gone. I've never done a repair like this on a monitor, only circuit board based repair on Macbooks etc - is it something that's doable or generally not?
          04-23-2024, 03:52 PM
        • N3Star
          ASUS ROG G15 G513QY random freezes
          by N3Star
          My laptop recently started freezing randomly - it usually freezes after a few minutes, sometimes after 2, other times 10 minutes.
          So far I kind of ruled out software problems, as the problem persists on live booted Linux, installed Windows and also while installing Windows. My first thought was that it was overheating, so I checked the temps and they are fine, as You can see on the screenshot, never the less I opened it up and reapplied LM on both cores, also using some more thermal putty on the VRM, obviously didn't help.
          While live booting Linux it usually freezes...
          11-16-2025, 02:48 PM
