Samsung UE32F500 no power, no standby light
  • Bbb_bhavesh
    • Aug 2016
    • 7
    • Uk
    Hi.
    I got problem samsung ue32f5000 led tv. Last night it was working perfect, suddenly when i start today there is no power light or stand by light. I check the forum and do some test with power board. Its BN44-00605A. I check with voltage and i am getting 109v reading at Led connection without Led connection. Also when i unplug the main board cable from power board all Led light is glow. So i am confused is it problem with Power Board or Main board. Any one have step by step to check list for foult finding.
    Thanks for valuble time.
  • thoma
    • Sep 2012
    • 268
    Re: Samsung UE32F500 no power, no standby light
    Read LCD TV and Monitor basic troubleshooting guides in this forum!
    https://www.badcaps.net/forum/showth...=25810&page=14
    https://www.badcaps.net/forum/showth...hlight=samsung
    Go to search and put in samsung there are a lot of threads!!!
    regards thoma!
      Report the DCV readings of all the pins of the connector CNM803, make sure to put pin names and pin number in front of the DCV readings so we can see what we are missing.
      Pictures provided by shopjimmy.
      • Bbb_bhavesh
        • Aug 2016
        • 7
        • Uk
        Thanks for your reply budm & thoma..
        I have checked DCV readings of all the pins of the connector CNM803 as below:
        Without Main board connection
        4.70v 1
        0 3
        4.70v 5
        0 7
        0 9
        5.24v 11
        3.12v 13
        2 12.86v
        4 12.86v
        6 12.86v
        8 12.86v
        10 0
        12 5.24v
        14 5.24v
        When i Connecting Main board with power board and checked the same connection i got reading 0 (zero) for all pins.
        Also i notice some burn mark on PCB at CM801 capacitor. When i checked capacitor its looks it working all right.
          It will be nice if you put the name of each pin.
          You must have count the pin wrong.
          For example:
          2 12.86v
          4 12.86v
          6 12.86v
          8 12.86v
          If you list the name of each pin the you would have known that pin 8 is GND so you cannot have 12.86VDC at pin 8.
          Pin 8, 9, 10 are GND.
          Post #3 request ' make sure to put pin names and pin number in front of the DCV readings '
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            Main Bd issue I think, as the LED Backlights come on with the Jack to the Mn Bd disconnected.
              Is he talking about LED backlights?
              "Also when i unplug the main board cable from power board all Led light is glow."
              If that is the case, then I agree that he has problem some where on the main board.
              • Bbb_bhavesh
                • Aug 2016
                • 7
                • Uk
                Thank you for your reply..
                I have checked DCV readings of all the pins of the connector CNM803.
                Pin no
                2 4.70v
                4 0v
                6 4.70v
                8 0v
                10 0v
                12 5.24v
                14 3.12v
                1 12.86v
                3 12.86v
                5 12.86v
                7 12.86v
                9 0v
                11 5.24v
                13 5.24v
                I think i wrote down in wrong pin number first time.
                Why its showing 0 voltage when main board connecting with power board and power supply is switch on? As soon as i disconnect with main board from power supply board i got ALL LED light lit and shows voltage reading. How do i checked main board is working or not?
                  The power supply board has pull-up resistors to pull up PS-ON and BL-ON pin high so you can do the self test to find out if the Power supply, LED driver, and the LED backlitghts are OK or not.
                  When you have the board connected to the main board, if the main board is bad it will not allow the control pins to go high (they should if the main board is OK). Another tip that shows the main board is the problem is that you do not have any indicator lights.
                  • Bbb_bhavesh
                    • Aug 2016
                    • 7
                    • Uk
                    Hi. Thanks for reply.
                    I follow with your above post and check the power board. And tcon board. Also i did search into forum to fault findung. I can not figure out how to find problem in LED driver board. How do i test that.
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      im pretty sure by reading your posts you have a mainboard fault what is the part number of the mainboard
                        As I indicated, if you disconnect the cable between the power supply and the main board and then you apply the power to the TV and the backlights come on and stay on then your power supply/LED driver board and the LEDs are OK, simple as that.
                        • CapLeaker
                          Leaking Member
                          • 8215
                          Don't get ahead of yourself, just do that what budm already said. If it makes you feel better, I think the problem is the main board, same as already others have mentioned.
                          • Bbb_bhavesh
                            • Aug 2016
                            • 7
                            • Uk
                            Re: Samsung UE32F500 no power, no standby light**** solved
                            Thanks you very much guys..
                            I got main board from ebay and changed. Its work.
                            Thanks a lot budm, Capleaker & vinceroger69.
                            • Bbb_bhavesh
                              • Aug 2016
                              • 7
                              • Uk
                              Is there any way i canfind where its problem in main boad? Its just for curiosity.
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                Glad you managed to fix your set and thanks for the update. mainboard problems are hard to trace and repair imo unless its something like a fuse/capacitor/resistor or voltage regulator etc the main processor seems to be a common failure with bad bga soldering etc.
                                  Thanks for follow-up, please make sure to turn down the backlights level as low as you can so the LEDs will last much longer.
                                  • shh-phd
                                    • Mar 2016
                                    • 20
                                    • iran
                                    hi
                                    please help me
                                    i need schematic for BN44-00605A
                                    thankyou
                                    • dskall
                                      • Oct 2016
                                      • 2905
                                      • usa
                                      Wait for get manual
                                      • stylishconsultant
                                        un60j620dafxza - Samsung No Display Problem
                                        by stylishconsultant
                                        Hi All,
                                        Need help.
                                        I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                                        So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                                        problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                                        might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                                        09-04-2024, 03:26 AM
                                      • Destroyer-Br
                                        [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                                        by Destroyer-Br
                                        I'm working on an Acer Nitro 5 unit with the following specs:
                                        • Motherboard: LA-J871P Rev: 1B
                                        • Model: Acer AN515-55-59MT
                                        • S/N: NHQ7JAL00403906A973400
                                        • SNID: 03902728734
                                        Initial Issue
                                        The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                                        After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                                        04-17-2025, 08:18 PM
                                      • repair-it
                                        Need advice testing a samsung power supply board with scope
                                        by repair-it
                                        I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                                        07-12-2025, 11:00 AM
                                        by sam_sam_sam
                                        After all of...
                                        07-13-2024, 08:14 PM
