Sharp LC-60LE832U Burnt 5v Standyby... lightning
  • JDRiv
    • Jul 2016
    • 7
    Hey everyone, I was hoping someone with a big brain could lend me a minute. I have a dps-183bp-4 a board (runtka798wjn1) that took a lightning strike. well.. the transformer on the pole did, blew it up, blew up my outdoor heat pump.. and my tv. So I am looking to change out my exploded ic7905 chip and the related resisters etc. The problem is, is that i can not find a repair kit for my model of board, does anyone know if the Sharp RDENCA336WJQZ (DPS-286AP) Power Supply Component Repair Kit will work?
    https://www.shopjimmy.com/sharp-rden...repair-kit.htm
    Making the assumption that my problem lies within ic7905 because it is burnt and the plastic is broken off...so a small explosion took place at a fast rate lol. TV has no power, does not respond to remote or buttons. I have verified that the fuse (f7001) is closed with no voltage change across it, so figured I should just start with the obvious and troubleshoot from there if it does not solve the problem.
    I have visited all of the local tv repair shops in my area to see if they sell parts and the only thing they will do is charge me to search for a new power board, then charge me for the board plus mark up, but can not or will not sell board parts to solder in.. anyway, any help is appreciated.
  • canadaboy25
    What is normal?
    • May 2013
    • 509
    Re: Sharp LC-60LE832U Burnt 5v Standyby... lightning
    I'm assuming you don't know the actual numbers on the chip?
    canadaboy25
    -Sometimes the light at the end of a tunnel is an on-coming train
    • JDRiv
      • Jul 2016
      • 7
      Your assumptions are correct, I can't make out what the numbers are due to the shard of plastic that's missing from the chip.
      • canadaboy25
        What is normal?
        • May 2013
        • 509
        Ah I see. Well if it were me I'd think that the kit would work because power supplies usually don't change drastically between models. But if your resistor and diode are both fine, 15 bucks for a chip is a lot. I'll have a look around and see if I can't find the chip number.
        canadaboy25
        • fzabkar
          • Mar 2009
          • 772
          Have you checked the service manual?
          http://elektrotanya.com/?q=showresul...at2=schematics
          FWIW, this service manual appears to have some references to IC7905:
          EDIT:
          The Sharp Aquos LC32D43U has a TNY268PN standby power IC at location IC7905. Looks plausible ...
          • JDRiv
            • Jul 2016
            • 7
            I have searched through the manual, perhaps I keep missing it? Have yet to find what the ic part code is.. actually I can't find any information on the board itself.
            • canadaboy25
              What is normal?
              • May 2013
              • 509
              That chip is $3 from China -->http://www.ebay.ca/itm/5pcs-TNY268PN...kAAOSwDk5T7hWb It is so cheap you wouldn't be out anything if it didn't work.. except the month you'd have to wait for China shipping.
              EDIT: Found one for cheaper -->http://www.ebay.ca/itm/1pcs-TNY268PN...4AAMXQO21RqVrl but you only get one instead of five.
              EDIT2: It was on page 124 of the second link fzabkar posted.
              canadaboy25
              • JDRiv
                • Jul 2016
                • 7
                I have ordered a couple tny268 chips (just in case i wreck one soldering it in). Thanks for the input and in a month when I get the chip in ill update lol. may need to look into diodes and resistors but crossing fingers this is the only thing the power surge popped
                  Is the Fusible R7914 OK? When that IC blew up, it may have taken out the fusible resistor also, you may want to look for other similar resistors to see if they are OK too.
                  • culcuhain
                    • May 2016
                    • 186
                    • U$@
                    Mouser has the chips too. $1.71 each. $8 shipping and have it in a few days. Waiting on stuff from China will try your patience. I am waiting on some mosfets. I need one. Can't find them in the US. Got 20 for $6.01... ordered almost a month ago....
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      Try Coppell who have a repair kit that may have the components you are looking for or perhaps you could ask them.
                      Kit:
                      Replacement components for IC7905, R7914, R7918 and D7908.
                      http://www.coppelltvrepair.com/p/119...tandby-voltage
                      • JDRiv
                        • Jul 2016
                        • 7
                        Thanks everyone for the sources, I have ordered the fusible resistors that feed the chip as well. Because its so cost effective, I figured it would be smart to get it coming anyway.. just in case. Some parts are coming from the US... some from china, so hopefully the wait isn't too long. Thanks again for everyone's input, made the search a lot easier for parts. Go into an electronics store, they basically say flush off. Come here, you guys do all but the work; appreciate it for sure.
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          Hope it solves your problem. Come back and let us know.
                          • electomech-fixer
                            First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
                            by electomech-fixer
                            I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
                            I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
                            09-15-2025, 01:42 AM
                          • dicky96
                            Zotac GTX 260 burnt component - can anyone identify?
                            by dicky96
                            Hi guys
                            This Zotac GTX 260 had a high side MOFET on one Vcore VRM phase short circuit Drain to Gate (Not short Drain to Source)
                            This has burnt out the drive IC L3E (ADP3110A) and also an SOT-23 device very close to the driver IC. According to the PCB markings 'Dxxx' this is likely to be a diode.
                            Basically the VRM has 4 phases, two powered from one 6 way connector and two powered from the other 6 way
                            I would assume each pair of phases are basically identical, the burnt out phase has SOT-23 devices WW1 plus the burnt one.
                            The good phase...
                            12-01-2021, 01:02 PM
                          • swimllamaswim
                            Precision 5550 LA-J191P No Power, Burnt ISL9538
                            by swimllamaswim
                            I picked up this Precision 5550 to fix up recently, and found that the ISL9538 chip was burnt on pin 14 (CSIN). The two left side Type C ports negotiate at 20v, and the right side one only negotiates at 5v. I also found the EMI protection diode, DT35, was burnt on that side. I pulled the ISL9538 off, checked for any other obvious shorts, repaired the pad, and put a new one on. Now, I still do not get power, and there is a rapid clicking sound from somewhere on the board that I can't pinpoint.
                            Here are the voltages measured at that chip:
                            To note, DCIN at Pin 17 is low,...
                            09-21-2025, 12:26 PM
                          • mferna14
                            Apple MacBook Pro A2338 820-02773-A AON Rail burnt
                            by mferna14
                            Hi Dear Friend., I am working on a Apple MacBook Pro A2338 820-02773-A. The history was that the AON Rail on the Trackpad connector JT400 was burnt. After I removed the burnt connector, I tested with the meter & no shorts. Connected the USB C power & all booted fine, no problems at all. I soldered a New TP connector put in the old trackpad with a brand new Flex cable. The laptop beeped in the start but no display. I removed the connector & the display was fine again. USED a known good Trackpad & a Flex cable, even with this still the same problem. I checked the connector whether...
                            06-25-2025, 11:26 AM
                          • advant
                            by advant
                            02-03-2020, 12:25 AM
