Element Elchw321 will not turn on
  • Herbssat
    • Sep 2011
    • 194
    Have been working on this set off and on for about 2 months. After it came in stuck on standby I decided to immediately jump the power supply bypassing the mainboard. All voltages checked are spot on. However I noticed that the backlights would not turn on and if you were lucky you might get a sputter from one or more of the bulbs. Just to be sure I ordered more inverters from China as the originals were out of the 3 percent tolerance. Got the inverters and put them in finding 2 bad bulbs in the lower quadrant of the screen. I found this by using Bud's Cfl method. Have progressed to this point but cannot get the backlights to stay on even with all new cfl bulbs soldered to the inverters. Even tried to simulate the dim control with an AA battery to no avail. I will worry about the mainboard signals after I can get the backlights to stay on. Will definitely need some help on this. Thanks.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Element Elchw321 will not turn on
    Have you images of the boards used please ?
    • Herbssat
      • Sep 2011
      • 194
      Sorry Reecey. Somehow my initial thread got double posted. There is another thread that contains a picture of one board. I will try to get more pictures up asap. Thanks for the response.
      • Herbssat
        • Sep 2011
        • 194
        Here are some pics. SW voltage is still at 3.0 when backlights shut off and the backlight inverter ic is the Fan 7313. All inverters have been checked for tolerance.
        • Herbssat
          • Sep 2011
          • 194
          Still need some suggestions . Anybody? Thanks.
          • Herbssat
            • Sep 2011
            • 194
            Still need some help on this set. Whatever you guys can suggest is greatly appreciated. The board model is RSAG7.820.1459. Thanks.
            • CapLeaker
              Leaking Member
              • 8126
              maybe the inverter shuts down because of too much current being drawn (bad CCFLs), or it thinks there is too much current being drawn from the inverter?
              Maybe bypass the protection circuit on the inverter?
              • Herbssat
                • Sep 2011
                • 194
                Thanks for the response Capleaker. Will try to see if I can bypass the protection momentarily to see if I can keep the backlights on. Going to lookup the datasheet of the backlight ic.
                • zape
                  • Jul 2017
                  • 176
                  Did you figure it out?
                  I'm working on the same board which also has no backlight.
                  Identified and replaced one dead FETs (V803 on schematic) driving the Backlight transformer but still nothing. The replacement has two times less RDS on though, not sure if it may be a problem
                  Never worked with CFL inverter before. Any help or links to troubleshooting methods appreciated.
                  The schematic is attached.
                  • CapLeaker
                    Leaking Member
                    • 8126
                    Are you saying you have ZERO back lights, or do they come on for 2 seconds and disappear?
                    • zape
                      • Jul 2017
                      • 176
                      Zero backlight. Everything else works - I can see the menu with a flashlight test.
                      • R_J
                        • 9535
                        What was wrong with the fet? if all leads were shorted, there is likely damage to the gate drive components.
                        • zape
                          • Jul 2017
                          • 176
                          Not all, but D-S Vdrop shows 0.15v both ways
                          I did not find any damaged components on the gate side
                          • CapLeaker
                            Leaking Member
                            • 8126
                            Check the BLon signal from the main board to the PSU, maybe it is missing. If it is missing it MAY be an EEPROM problem.
                            Try forcing the PSU and the back lights on, with the main board unhooked. You need two 1k ohm resistors. Take one resistor and jump STBY to PSon. Take the other resistor and jump STBY to BLon. Plug the set in and the PSU should be on and the back lights on.
                            https://www.shopjimmy.com/element-e0...rom-only-1.htm
                            • R_J
                              • 9535
                              Was it showing D-S short in circuit or out of circuit? The reason I ask is that is unlikely the fet was shorted and the main fuse did not blow also, If you charged the gate with your meter during testing it would have turned the fet ON, so it would have tested short between D-S.
                              • zape
                                • Jul 2017
                                • 176
                                Both in circuit and out. I'm aware of the FET charging.
                                Some strange things happened now. I was about to check the SW ON signal and it turned on and backlight works now.
                                No idea why it did not work the first time.
                                Could be some sort of intermittent problem still present.
                                • R_J
                                  • 9535
                                  Check for poor solder connections on any components on heatsinks and also transformer connections
                                  • zape
                                    • Jul 2017
                                    • 176
                                    Could this be the fact that I put in a different FET? So it is disbalanced now?
                                    Original was FDPF7N50U and I used 2SK3569 which I randomly scavenged off some other board.
                                    • R_J
                                      • 9535
                                      That could be.
                                      • zape
                                        • Jul 2017
                                        • 176
                                        Can't turn it on again. It was just once when the backlight turned on.
                                        • pajdek
                                          Lenovo Y700-17ISK turn on and off
                                          by pajdek
                                          Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                          09-20-2023, 02:49 AM
                                        • RdeveLabs
                                          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                          by RdeveLabs
                                          To all the members here...
                                          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                          05-05-2025, 04:59 AM
                                        • robante15
                                          Acer Aspire 4520 won't turn on after reboot
                                          by robante15
                                          Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                                          It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                                          The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                                          If I remove the...
                                          04-06-2024, 06:50 PM
                                        • masoksian
                                          Dell latitude e7470 not turn on .power buton on off and Run Power problem
                                          by masoksian
                                          I am dealing with the problem of turning on and off my Dell e7470 notebook.
                                          The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                                          The system does not turn on, there is no post.
                                          I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                                          The problem continues in the same way.
                                          I tried to turn on the Fn key, nothing came to the screen....
                                          02-15-2025, 12:08 PM
                                        • dqtech
                                          lenovo x240 nm-a091 wont turn on
                                          by dqtech
                                          i got this laptop with no power issue....i flashed the bios and laptop can turn on and use normally....but when i shut it down and rest for few minute (2-3 minutes), it wont turn on....i have to flash bios again...any idea what is the problem?...when i shutdown and suddenly press power button to turn on, it will turn on normally....problem happen when i rest the laptop 2-3 minutes after shutdown, it will not turn on....i need to flash bios again
                                          board number VIUX1 NM-A091 REV:1.0...
                                          02-07-2024, 01:57 AM
