Toshiba 42rv530u wont power on
  • bleed4me
    • Nov 2015
    • 122
    Picked this TV up with symptoms of not powering on, standby light works and is red but unit wont power on. First thing I checked was the fuses and sure enough one was bad. Replaced the 2.5A fuse and the second I powered it on it blew. The first by the AC plugin is just fine. Any insight and help with this would be much appreciated. Sorry for the poor quality picture. As for a fair warning im new testing rectifiers and mosfets so if that is what is causing the issue please be patient with me.
  • CapLeaker
    Leaking Member
    • 8352
    Re: Toshiba 42rv530u wont power on
    Right next to that fuse is that long heat sink with 2 mosfets and a diode. Check if those are shorted with your DMM in diode mode. If they are shorted, they are bad.
    Maybe you want to youtube on how to test bridge rectifier, diodes and mosfets. Lots of info there.
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Check with your meter set to ohms to see if there is a short circuit (0 ohms) on the left hand side or right hand side of the fuse as shown in the picture.
      If it's the left side then it looks like the IC with many legs as shown in the block.
      If there's a short on the right side then the mosfet (Q821) or the diode (D821) or both are short circuit.
      Connect black lead to negative pin of C820 and red lead to check each side of the fuse holder with no fuse in place and power disconnected from the mains.
      • bleed4me
        • Nov 2015
        • 122
        Thanks Dick barton and CapLeaker. If I position the board like the picture you provided and test for a short circuit on the fuse holder I get a constant 16.6 on the left hand side and something weird happens on the right side. For the most part it starts at 26.6 and slowly goes down and on a few occasions it jumps to 29.4 real fast then goes to 0.L, I dont understand what that means. Also while doing this test I noticed something else on T821 pin 4 has no solder on it at all just want to confirm if this is normal or not.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          That non connection is fine. The pin is not used so no connection.
          What are the numbers given on the 3 devices, i.e. diode, mosfet and multipin IC all shown in the above picture.
          When you gave the above readings what was you meter set to.
          • vinceroger69
            • Mar 2012
            • 6714
            what is the power supply board number?
            • CapLeaker
              Leaking Member
              • 8352
              pe0546
              • vinceroger69
                • Mar 2012
                • 6714
                in the repair kits for this fault looks like just two parts
                Fuse F820
                PFC driver IC Q860A maybe worth checking these first is this also the fuse that blows?
                • bleed4me
                  • Nov 2015
                  • 122
                  dick_barton- Crazy as it sounds the DMM was on ohms, I even changed the battery to see if that was the issue. I just rechecked those readings and the same thing happens, first attempt if jumps to 39 then to O.L and second try it starts at 28 and counts down slowly. As for the numbers they are as followed
                  Q860A- STR-Z2589 8208
                  D821- N2206 8205
                  Q821- FM J07 FCPF 11N60T
                  Q820- FM J07 FCPF 11N60T
                  vinceroger69- The fuse the keeps blowing is indeed F820, and how would one test the PFC driver IC? As for the board number like CapLeaker said is PE0546 and according to shopjimmy the part number is 75010942
                    So the readings you are getting is in OHMS. K OHMS, or M OHMS?
                    • bleed4me
                      • Nov 2015
                      • 122
                      Sorry M OHMS , keep forgetting to look at that
                        If you have shorted/bad devices, it will be very very low Ohms range.
                        So are you sure that you tested the correct devices? There has to be shorted circuit to blow fuse that size.
                        • bleed4me
                          • Nov 2015
                          • 122
                          That test was C820 to either side of the fuse holder...
                            OK, the only load for that F820 fuse is that STR-Z25XX series, so the internal short may be half of the bridge drive power MOSFETs may be shorted out.
                            You need to check the resistance between pin 5 and pin 1 (for the upper MOSFET), then pin 1 and pin 21 for the lower MOSFET to see if one of them is shorted out or has very low resistance. Make sure you count the pin correctly.
                            PDF of the power supply PE5046, there are two revisions.
                            • bleed4me
                              • Nov 2015
                              • 122
                              Thanks budm for the PDFs, but I will be honest with you and that is more or less a foreign language to me. I hope one day I will be able to understand all that. In the mean time I will study it and try and make some sense of it all. As for pin 5 and 1 I get a resistance of 3.9 ohms and pin 1 and 21 I get 12.8 ohms.
                                That means when you read 5 and 21 is should show around 16 Ohms, which you should also see that when you test between the Negative leg of the main filter cap and the output side of the fuse.
                                • bleed4me
                                  • Nov 2015
                                  • 122
                                  So the constant 16.6 on the left side makes sense and the right side is the issue, meaning the mosfets and diodes? grrrrrr....
                                    Sop it is 16.6 Ohms, not 16.6 M Ohms then.
                                    You need new IC.
                                    • bleed4me
                                      • Nov 2015
                                      • 122
                                      The left side of F820 is ohms and the right side is the M ohm. Yes when I tested 1-5 and 1-21 that is in ohms not M ohms.
                                      • bleed4me
                                        • Nov 2015
                                        • 122
                                        Yes when I test pin 5 and 21 I do get 16Ohms and I also get 16Ohms between the Negative leg of the main filter cap and the output (left side) of the fuse. Wouldnt a higher Ohm suggest it was good or do I have that backwards?
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • beetle1303
                                          Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                          by beetle1303
                                          I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                          On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                          01-13-2025, 08:49 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
