Sony KDL-65W850A Dead
  • kevinm34232
    • May 2012
    • 1884
    I'm following SM flow chart, and have found the 3.3v standby power is present. Next step is asking to check the DC/DC converter. Note the "SLxxxx" in the photos.. I don't understand what they are asking to check, there is nothing there where the arrows are pointing. What does "SL" mean?
    I attached a photo of one example looking for SL9111 close to F9105. I put a red dot where the arrow points. There is nothing on the other side either..
  • Diah
    • Feb 2013
    • 6610
    Re: Sony KDL-65W850A Dead
    i think 65W85 are same as 65W95 forget the SM, and told us the stroy of the faults just dead !! how about your volts measure at main boards
    • R_J
      • 9624
      They are dc-dc converters, the ic's take one voltage in and convert it to another I'm not sure what voltage they are supplied but each will output the corresponding voltage listed in the chart 5v 3.3 1.5 1.8, if the output voltage is not there, check the fuses which seem to be on the inputs of the dc-dc ic's. sl9109 must be ic9109
      Like the above poster, what is the actual problem with the tv?
      • kevinm34232
        • May 2012
        • 1884
        I understand the DC/DC process, I just don't understand why they wouldn't ask to check voltage at the fuse, but a different point at the board, where there is nothing really there and no "SL9111".
        The fuses test good but I am not seeing any voltage there. The only voltage I can find is the 3.3V standby at the corresponding main board test point.
        • R_J
          • 9624
          I suspect the fuses are on all the inputs and common to all the ic's so checking the voltage on one of them would be the same as the others. you would need to find the output of the ic's and check that voltage, what they are saying is if a particular voltage (1.5, 1.8 etc.) is missing then check the corresponding fuse. as there is no voltage on the fuses I would check were there source voltage (to the fuses) comes from.
          Maybe the voltage supplying the fuses only happens when the tv turns on (not in standby)
          • kevinm34232
            • May 2012
            • 1884
            I think voltages are supposed to be there since, the flow chart is for "No Power".. I'll have to look at it closer, I just want to know where they are actually saying to check it..
            The check for standby 3.3v was a coil on the main board and was correctly shown..
            • kevinm34232
              • May 2012
              • 1884
              The first fuse on the main board is tied to the REG+12V line, which is not being supplied by the power supply during standby. Is it supposed to be?? All the checks for "No Power" in the SM seem to point to that voltage being there when troubleshooting..
              • R_J
                • 9624
                I don't know, I don't have the schematic for this model, Check back to where the +12 is supplied from and see if looks like its always supplied by the power supply or there could be a transistor (or other semi) acting like a switch to turn on the +12 after the power button is pressed. check the cable between the main board and power supply there could be a pin marked as ps-on that turns the +12 on.
                • kevinm34232
                  • May 2012
                  • 1884
                  Yes there is a PS-ON, but I don't know if it 12V is part of that.. Here's some more photos if it helps. There are 2 power boards but it looks like the 2nd one is mostly for the backlights..
                  The REG+12V pins on that connector go back to the 2 diodes and 3 caps I marked.
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    When you power up, what DC voltage do you have on AC_Off-Det and the Power_On pins ?
                    • kevinm34232
                      • May 2012
                      • 1884
                      3.3V at AC_Off-Det, and 0v at PS-ON. I jumped PS-ON from the 3.3STBY, and then the REG+12V comes up. I still can't figure out where the test points are for DC/DC converter on the main board, but all the fuses are good and have either 12v or 5v.
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        So it looks like your power supply is not the problem
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          The 1110021 is the regulator (SN1110021PWP). Measure the dc voltages on the pins.
                          • kevinm34232
                            • May 2012
                            • 1884
                            Ya and the main caps come up to 400VDC.
                            But I was not able to jump the backlights on, I tried applying 3.3v to BL_ON along with PS_ON but nothing. It actually drags the 3.3v down. Notg sure if this is the correct process on this TV.
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              Did you use a resistor to jumper the Backlights On from the 3.3V. Resistor value of 500 -1000 Ohms?
                              • kevinm34232
                                • May 2012
                                • 1884
                                I have 12V on pins 8 & 9 and pretty much 0v everywhere else.
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  12V should come up on six pins as shown in the legend and STB3.3V on one pin?
                                  • kevinm34232
                                    • May 2012
                                    • 1884
                                    Where is the pin out legend that you are looking at?
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      One of the photo's you provided. Post #9, SAM_2818.JPG (3 of 3)
                                      • kevinm34232
                                        • May 2012
                                        • 1884
                                        I did not use a resistor. I want to make sure the backlights come on to confirm the main board. Should I just be able to jump the PS-ON and BL_ON? Use a resistor for the BL_ON only?
                                        • thstuff
                                          Sony OLED XR-77A80J - Initially dead, now 4 Flashes
                                          by thstuff
                                          A) TV initially dead
                                          B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
                                          C) Was able to perform a Reset from Settings menu and completed out of box configuration.
                                          D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
                                          E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical...
                                          12-26-2024, 09:10 PM
                                        • bohaboha
                                          SONY KDL-46R473A ALMOST DEAD NO STB
                                          by bohaboha
                                          Hello to everyone in this wonderful forum.
                                          I have this SONY LCD TV KDL_46R473a
                                          PSU GL5 APS350 :1-888-122- 12
                                          MAINBOARD FY13_EU IP-012C101-4010
                                          black screen ,no STB no life almost death.
                                          on PS all the required volts are present 394V on the main cap and those on cold side 12.41V,3.45 and 3.45 are on
                                          Also 3,5,and 12v are on.
                                          nothing happens if i disconnect the PSU from the mainboard as on Samsung because here i think the mainboard gives the signal to the ps.
                                          don't know what to do next all suggestions and advice are very welcome​...
                                          04-24-2025, 04:40 PM
                                        • Talyn
                                          Sony 55W905 dead
                                          by Talyn
                                          My Sony W905 started to turn itself off an on every few minutes and blinking 8 times red in standby. A few minutes later the tv was completely dead.
                                          I can only hear the click of the PSU when attaching/detaching the power cable. No standby LED.
                                          Any advice? Thanks!
                                          04-15-2024, 08:14 AM
                                        • mrsith
                                          Sony KDL-55W755C - Dead
                                          by mrsith
                                          Hello again lifesavers.
                                          I have a KDL-55W755c that came in dead - not even standby light going on. Tested the power supply - all correct. Tested the output pins on the Led driver board (in which the power cord plugs in) - all seemed fine.
                                          I got a service manual for this model and tested the DC/DC converter by checking voltages on selected components. Every voltage was present where it should be. Service manual says that in this case a "Muffin" replacement is needed. This is the moment where I got stuck as I wasn't able to Google my way through it - till this day I...
                                          11-28-2022, 12:42 PM
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
