LG 47LN5790 badly burnt out LEDs
  • Pipolups
    Corsair K70 LUX RGB dying LEDs
    by Pipolups
    Hi there !
    I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
    Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
    10-08-2024, 11:58 AM
  • dicky96
    Zotac GTX 260 burnt component - can anyone identify?
    by dicky96
    Hi guys
    This Zotac GTX 260 had a high side MOFET on one Vcore VRM phase short circuit Drain to Gate (Not short Drain to Source)
    This has burnt out the drive IC L3E (ADP3110A) and also an SOT-23 device very close to the driver IC. According to the PCB markings 'Dxxx' this is likely to be a diode.
    Basically the VRM has 4 phases, two powered from one 6 way connector and two powered from the other 6 way
    I would assume each pair of phases are basically identical, the burnt out phase has SOT-23 devices WW1 plus the burnt one.
    The good phase...
    12-01-2021, 01:02 PM
  • THE GTC
    Insignia NS-37D20SNA14 intermittent LEDs
    by THE GTC
    So I use this TV daily as a second monitor for my PC or my Playstation - at one point a few months back I tried to fix the problem - but in the process, I figured out something that works so I haven't posted this for awhile. It is an annoying trick to have to do though, so I decided to post about it to see if anyone could spot what's wrong. It baffles me because it works on it's own half the time.
    When I first got this TV, I was told it wouldn't turn on, and of course I did the flashlight test, and the image was there. Also, the red LED on the front indicated that it had power (it...
    11-03-2020, 02:40 AM
  • mferna14
    Apple MacBook Pro A2338 820-02773-A AON Rail burnt
    by mferna14
    Hi Dear Friend., I am working on a Apple MacBook Pro A2338 820-02773-A. The history was that the AON Rail on the Trackpad connector JT400 was burnt. After I removed the burnt connector, I tested with the meter & no shorts. Connected the USB C power & all booted fine, no problems at all. I soldered a New TP connector put in the old trackpad with a brand new Flex cable. The laptop beeped in the start but no display. I removed the connector & the display was fine again. USED a known good Trackpad & a Flex cable, even with this still the same problem. I checked the connector whether...
    06-25-2025, 11:26 AM
  • NeedsMoreFlux
    New T.V.!!! $60 60inch Vizio Smart T.V. Burnt LEDs, Easy Fix!!!
    by NeedsMoreFlux
    Sup Bros!(PewDiePie voice) Just picked up a 60 inch Toshiba E60-C3. I has bright spots, so I could tell that it had Bad LEDs. The pictures on Craigslist and the previous owners description made it sound like a bad LED driver.
    I opened up the TV and Tested the LEDs by trying to use what looked like test points near the LEDs... But those were connected to nothing!!!
    So after scratching the solder mask between each LED I found out that only 10 of the LEDs were burned, out of 12 strips, with 8 LEDs each=96 LEDs!!!
    Fortunately I will only need 10 LEDs. ...
    11-27-2017, 08:55 AM
