Sharp LCD TV LC-32L50M blinking red light 5X
  • bangjay
    • Apr 2016
    • 23
    • indonesia
    I had problems with Sharp LCD TV LC-32L50M, current conditions, if I turn it on the LED indicator green and red flashing alternately several times, after that only a red LED that flashes 5x, when the red light flashing, all the buttons does not work.
    according to my analysis, this tv failed to start because of a protected, I've tried to go to service mode with Vol - and TV / Video and plug the power, but the tv screen was still dark, there is no display anything on the screen. and LED indicators remain blinking as described above.
    I've tested the voltage in the power supply. everything is ok.
    1. BU1.8V ok
    2. BU2.5V oK
    3. BU3.3V OK
    4. BU5V OK
    5. BU12V OK
    6. DC 14V / 24V OK
    anyone can help me? whether about the problem?
    Re: Sharp LCD TV LC-32L50M blinking red light 5X
    Can you please upload the whole service manual so I can look through it?
    • fredaelsadany
      • Jan 2016
      • 66
      • EGYPT
      hallo
      try to measure voltages on pic and tell us your readings .
      thanks
      • bangjay
        • Apr 2016
        • 23
        • indonesia
        Thankyou for the response, here i attach the manual service for your reference
        thank you before.
        • bangjay
          • Apr 2016
          • 23
          • indonesia
          Originally posted by fredaelsadany
          hallo
          thanks
          Here I attach the results of testing the voltage on the main power unit.
          1. When i press the power button the PFC output voltage is 390Vdc. but after about 6 seconds, the voltage dropped to 312Vdc.
          2. STBY_CONTROL is 0Vdc.
          3. All Pin 4 Optocopler is 1.8Vdc.
          4. Pin 6 NCP 1337 (IC 7201) is 1.8Vdc.
          thank's before.
          • fredaelsadany
            • Jan 2016
            • 66
            • EGYPT
            hallo
            that is good .
            the main board not working good .
            please good photo to MB . TO COMPLETE SEARCH .
            THANKS
            • bangjay
              • Apr 2016
              • 23
              • indonesia
              hallo
              that is good .
              THANKS
              This is a photo of the mainboard. and I also attach the schema for this mainboard. please check, if incomplete please let me know.
              Thank You
              • bangjay
                • Apr 2016
                • 23
                • indonesia
                hallo
                that is good .
                THANKS
                Hi Fredaelsadany
                Are you sure the problem is on the mainboard? if I replace the main board this issue will be resolved?
                Please help,
                thank you before.
                • fredaelsadany
                  • Jan 2016
                  • 66
                  • EGYPT
                  hallo
                  please Try to reset your tv as follow :
                  1. Turn off the TV.
                  2. Unplug the power cord of the TV from the electrical outlet.
                  3. Let the TV remain without power for 2 minites
                  4. put it to power press power sw
                  measure on/off voltage when you power on tv .
                  thanks
                  • esqmooo
                    HP Elitebook 845 G8 dead, only caps lock flashing 7 times. Charging light always on
                    by esqmooo
                    Hello everyone.
                    This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
                    Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
                    Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
                    I tried long pressing on the power button, after several seconds it would go off then when the button is released...
                    03-11-2025, 03:57 PM
                  • YasaCh
                    Sony kdl 40p5500 red light keeps blinking 3 times
                    by YasaCh
                    Hello...
                    my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                    i opened the back cover no sign of damage on the powery suply or motherboard
                    when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                    another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                    07-07-2025, 11:53 AM
                  • learnmore
                    Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
                    by learnmore
                    Hello Community!
                    CASE DETAILS
                    Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
                    13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
                    Tried inserting firmware on USB and left it in for a few hours, but no change
                    03-03-2024, 09:49 AM
                  • kyho
                    Sharp LC-46D85U green power light & OPC flashing
                    by kyho
                    I have 46" Sharp TV LC-46D85U, recently it doesn't power on. It gives flashing one power light and OPC light together then flashing one on power light, then repeat the flashing pattern, I checked the forum and the error code for this pattern, it indicates the power supply board is faulty. I am not sure it is the power supply board or other boards. I measured the voltage on the PD connector, I have +2.99 DCV on pin 8 (AC_DET) and +5.01 DCV on pin 12 (BU5V), other pins and LB1, PL, LB2, LA connectors has 0 volt. I removed the power board and connected with BU 5V + 490 ohm resistor to pin 9...
                    08-16-2020, 03:16 PM
                  • CraigR
                    Hp Spectra x360 Power light flashing, component id
                    by CraigR
                    Working on a hp x360 15-eb1043dx that will not turn on and the power light just flashes. It pulls 700ma when flashing. Under the thermocam I found a component I am unable to id that light up. If someone can help would be appreciated. I put the number that are on it in better test....
                    05-07-2025, 11:06 AM
