Sharp LCD TV LC-32L50M blinking red light 5X
    I had problems with Sharp LCD TV LC-32L50M, current conditions, if I turn it on the LED indicator green and red flashing alternately several times, after that only a red LED that flashes 5x, when the red light flashing, all the buttons does not work.
    according to my analysis, this tv failed to start because of a protected, I've tried to go to service mode with Vol - and TV / Video and plug the power, but the tv screen was still dark, there is no display anything on the screen. and LED indicators remain blinking as described above.
    I've tested the voltage in the power supply. everything is ok.
    1. BU1.8V ok
    2. BU2.5V oK
    3. BU3.3V OK
    4. BU5V OK
    5. BU12V OK
    6. DC 14V / 24V OK
    anyone can help me? whether about the problem?
    Re: Sharp LCD TV LC-32L50M blinking red light 5X
    Can you please upload the whole service manual so I can look through it?
      hallo
      try to measure voltages on pic and tell us your readings .
      thanks
        Thankyou for the response, here i attach the manual service for your reference
        thank you before.
          Originally posted by fredaelsadany View Post
          hallo
          thanks
          Here I attach the results of testing the voltage on the main power unit.
          1. When i press the power button the PFC output voltage is 390Vdc. but after about 6 seconds, the voltage dropped to 312Vdc.
          2. STBY_CONTROL is 0Vdc.
          3. All Pin 4 Optocopler is 1.8Vdc.
          4. Pin 6 NCP 1337 (IC 7201) is 1.8Vdc.
          thank's before.
            hallo
            that is good .
            the main board not working good .
            please good photo to MB . TO COMPLETE SEARCH .
            THANKS
              hallo
              that is good .
              THANKS
              This is a photo of the mainboard. and I also attach the schema for this mainboard. please check, if incomplete please let me know.
              Thank You
                hallo
                that is good .
                THANKS
                Hi Fredaelsadany
                Are you sure the problem is on the mainboard? if I replace the main board this issue will be resolved?
                Please help,
                thank you before.
                  hallo
                  please Try to reset your tv as follow :
                  1. Turn off the TV.
                  2. Unplug the power cord of the TV from the electrical outlet.
                  3. Let the TV remain without power for 2 minites
                  4. put it to power press power sw
                  measure on/off voltage when you power on tv .
                  thanks
