Toshiba 55ZV650U REGZA sound but no picture
Re: Toshiba 55ZV650U REGZA sound but no picture
Have no idea what an oscilloscope is.........sorry please help me outComment
The chances of getting my hands on an Oscilloscope is probably next to none .......Have I just hit a dead end? or is there another path I can take to resolve the problem. Either way my friends I appreciate the time and patience that you people have put in so far.....Comment
No problem. Many moons ago, I started out as noob too and had no idea. However, at this point I would really like to see if the main board is putting out the Low Voltage Differential Signal (LVDS). That is on that ribbon cable from the main to the Tcon board. Since you don't have an oscilloscope, maybe a replacement main board is on order. I am out of ideas for now. Unless Budm has another trick up his sleeve, he is really good.Last edited by CapLeaker; 05-11-2016, 07:19 PM.Comment
No problem. Many moons ago, I started out as noob too and had no idea. However, at this point I would really like to see if the main board is putting out the Low Voltage Differential Signal (LVDS). That is on that ribbon cable from the main to the Tcon board. Since you don't have an oscilloscope, maybe a replacement main board is on order. I am out of ideas for now. Unless Budm has another trick up his sleeve, he is really good.Comment
What is the model number of the LCD panel?Never stop learning
Found the spec sheet for the panel but there no way to put the panel into self test.
https://cdn.badcaps-static.com/pdfs/...0fc1501c4a.pdf
So it is a matter of trying out the new main board since you do not have the equipment to look for the signal outputs of the main board.
The main board also has the FRC (Frame Rate Conversion for doing such thing as 120Hz frame rate) circuits so the problem can be in that section.Last edited by budm; 05-13-2016, 09:04 PM.Never stop learning
I will ask around to see if I can borrow that special tool.
Hope this can help if I dont find the tool needed.
Budm .....do you think by replacing the main board it will resolve my problem?
Do you thick my power supply is good or do you think I have several problems .....power supply, main board and possibly other pieces?
Looks like your my only life line.....and I am hanging on for dear life.
Thanks againComment
Without checking the LVDS with the oscilloscope, we can't proof that there is actual a signal coming out of the main board. After that we can only guess to take a chance or not replacing the main board. To tell you the truth, I'd be lost without my 100Mhz oscilloscope, because it would limit me quite a bit on stuff I would be able to repair.
So if the replacement main board is cheap, go ahead and see what happens. But to be 100% certain we need to scope that LVDS, there is no other way around. Either take a chance on a new main board, or borrow a oscilloscope, then we can say if the main board is 100% bad or not.Comment
LOL are you going to buy oscilloscope to repair your TV ?
at your pervious posts you wrote you can see TOSHIBA logo sign.. when you push the tv to start many time... is this sign logo of Toshiba show on the LCD ? and i think yes its,, then no need to oscilloscope.
change the main boards instead you buy oscilloscopeComment
I know this is off topic but is this an ok oscilloscope for $20?
http://columbus.craigslist.org/ele/5572570513.htmlComment
by jord4231Hi Everyone,
I'm working on a Toshiba 37AV500A Regza TV.
The issue:
TV was working picture and sound went out. Green stand by light stayed on, It will respond to the power button being pressed (goes in and out of standby)
The TV will very intermittently work for around 40 mins then stop. This doesn't seem to matter if its hot/cold unplugged for a while etc.
I checked the PSU voltages and everything looked good.
No bulging caps or signs of heat.
24v aud = 24.41v
12v = 11.98v
5v = 5.062
p_o/f = Goes high... -
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... -
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... -
by IerwinHello everyone,
Anyway I still fully expect that there has been something seriously damaged... -
by jchangHi all
I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
Symptom:
No picture no sound.
When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
No sound at all.
What I tried:
1. I tried unplugging the left or right ribbon... - Loading...
