Toshiba 55ZV650U REGZA sound but no picture
  • eztiger12
    • Apr 2016
    • 44
    Re: Toshiba 55ZV650U REGZA sound but no picture
    Originally posted by Joseph cauchi
    Becareful when you check the filter caps because these are at the hot side of the PSU.Check with your multimeter on DC black to - and red to+
    Sorry guys Im not following .....you got to help me out on the last two post. What do I need to go exactly?
    • eztiger12
      • Apr 2016
      • 44
      Originally posted by budm
      Well the Voltages seem to be present.
      So as capleaker suggested, now you need an Oscilloscope to see if the signals from the main board are being fed to the T-CON or not.
      Have no idea what an oscilloscope is.........sorry please help me out
        https://en.wikipedia.org/wiki/Oscilloscope
        • eztiger12
          • Apr 2016
          • 44
          The chances of getting my hands on an Oscilloscope is probably next to none .......Have I just hit a dead end? or is there another path I can take to resolve the problem. Either way my friends I appreciate the time and patience that you people have put in so far.....
          • CapLeaker
            Leaking Member
            • 8325
            CapLeaker that was purely chinese to me ........I really have no idea what your saying. Please help me out........tell me what to do and I ll post the results.
            Thanks .......sorry but I am far from being a pro..
            No problem. Many moons ago, I started out as noob too and had no idea. However, at this point I would really like to see if the main board is putting out the Low Voltage Differential Signal (LVDS). That is on that ribbon cable from the main to the Tcon board. Since you don't have an oscilloscope, maybe a replacement main board is on order. I am out of ideas for now. Unless Budm has another trick up his sleeve, he is really good.
            • eztiger12
              • Apr 2016
              • 44
              Thanks a lot CapLeaker .........Lets hope Budm still has an "Ace" up his sleeve.
                What is the model number of the LCD panel?
                • eztiger12
                  • Apr 2016
                  • 44
                  Would this be what you are looking for?
                  LC550WUD
                  (SB) (M2)
                  LG Display
                  code Bar reads55099P1838952831B
                  Got this off a sticker on the chassis of the TV.
                  • eztiger12
                    • Apr 2016
                    • 44
                    I feel abandoned ........lol
                    anyone out there
                      Found the spec sheet for the panel but there no way to put the panel into self test.
                      https://cdn.badcaps-static.com/pdfs/...0fc1501c4a.pdf
                      So it is a matter of trying out the new main board since you do not have the equipment to look for the signal outputs of the main board.
                      The main board also has the FRC (Frame Rate Conversion for doing such thing as 120Hz frame rate) circuits so the problem can be in that section.
                      • eztiger12
                        • Apr 2016
                        • 44
                        Wondering if this could shine any light on the matter on hand. I disconnected the wired connection (the metal one with a bunch of wires) on the bottom of T-com one at the time. When I disconnect the bigger of the two the whole screen goes black as if the TV is off and when I do the smaller one the is no change to the screen as if its on but no image.
                        I will ask around to see if I can borrow that special tool.
                        Hope this can help if I dont find the tool needed.
                        Budm .....do you think by replacing the main board it will resolve my problem?
                        Do you thick my power supply is good or do you think I have several problems .....power supply, main board and possibly other pieces?
                        Looks like your my only life line.....and I am hanging on for dear life.
                        Thanks again
                        • CapLeaker
                          Leaking Member
                          • 8325
                          Without checking the LVDS with the oscilloscope, we can't proof that there is actual a signal coming out of the main board. After that we can only guess to take a chance or not replacing the main board. To tell you the truth, I'd be lost without my 100Mhz oscilloscope, because it would limit me quite a bit on stuff I would be able to repair.
                          So if the replacement main board is cheap, go ahead and see what happens. But to be 100% certain we need to scope that LVDS, there is no other way around. Either take a chance on a new main board, or borrow a oscilloscope, then we can say if the main board is 100% bad or not.
                          • eztiger12
                            • Apr 2016
                            • 44
                            I found two oscilloscopes for sale locally .....would either one of these do the job?
                            The first one is:
                            Hung Chang 20 Mhz dual Trace oscilloscope Model: OS-620
                            The second one is:
                            Oscilloscope Tektronix 564B Storage
                            seems to be a 10MHZ
                            • Diah
                              • Feb 2013
                              • 6435
                              LOL are you going to buy oscilloscope to repair your TV ?
                              at your pervious posts you wrote you can see TOSHIBA logo sign.. when you push the tv to start many time... is this sign logo of Toshiba show on the LCD ? and i think yes its,, then no need to oscilloscope.
                              change the main boards instead you buy oscilloscope
                              • eztiger12
                                • Apr 2016
                                • 44
                                No the Toshiba sign right under the LCD lights up but nothing on the screen.
                                • Diah
                                  • Feb 2013
                                  • 6435
                                  i see. .... sorry
                                  • eztiger12
                                    • Apr 2016
                                    • 44
                                    i see. .... sorry
                                    Not a problem.......any input is better than none at all.
                                    • Malachi
                                      • Dec 2015
                                      • 1077
                                      • Usa
                                      #78
                                      I know this is off topic but is this an ok oscilloscope for $20?
                                      http://columbus.craigslist.org/ele/5572570513.html
                                      • eztiger12
                                        • Apr 2016
                                        • 44
                                        I probably is but the shipping to Canada will cost a fortune........thx for the heads up
                                        • Malachi
                                          • Dec 2015
                                          • 1077
                                          • Usa
                                          #80
                                          I meant for me to buy. Lol. Is it a good brand? Should it do what the pros here ask for when they aske if one has an oscilloscope?
                                          • jord4231
                                            Toshiba 37AV500A Regza TV good power supply no sound no picture
                                            by jord4231
                                            Hi Everyone,
                                            I'm working on a Toshiba 37AV500A Regza TV.
                                            The issue:
                                            TV was working picture and sound went out. Green stand by light stayed on, It will respond to the power button being pressed (goes in and out of standby)
                                            The TV will very intermittently work for around 40 mins then stop. This doesn't seem to matter if its hot/cold unplugged for a while etc.
                                            I checked the PSU voltages and everything looked good.
                                            No bulging caps or signs of heat.
                                            24v aud = 24.41v
                                            12v = 11.98v
                                            5v = 5.062
                                            p_o/f = Goes high...
                                            03-29-2022, 09:21 PM
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • Ierwin
                                            by Ierwin
                                            05-13-2025, 03:31 PM
                                          • jchang
                                            Samsung UN70NU6900F no picture and no sound
                                            by jchang
                                            Hi all
                                            I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                            Symptom:
                                            No picture no sound.
                                            When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                            No sound at all.
                                            What I tried:
                                            1. I tried unplugging the left or right ribbon...
                                            01-09-2023, 06:28 PM
