Toshiba 55ZV650U REGZA sound but no picture
  • eztiger12
    • Apr 2016
    • 44
    Re: Toshiba 55ZV650U REGZA sound but no picture
    Originally posted by Malachi
    I meant for me to buy. Lol. Is it a good brand? Should it do what the pros here ask for when they aske if one has an oscilloscope?
    Yup your totally right.........
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8352
      I know this is off topic but is this an ok oscilloscope for $20?
      http://columbus.craigslist.org/ele/5572570513.html
      No. only 5MHZ bandwidth... you want something like at 100Mhz.
      • Malachi
        • Dec 2015
        • 1077
        • Usa
        #83
        Ok thanks.
        • eztiger12
          • Apr 2016
          • 44
          Greeting CapLeaker
          Concerning my problem ......would the two oscilloscopes that I posted be good enough to check my many board?
          If not mistaken on is a 10 and the other a 20 Mhz.
          It would probably be the only time I use it. I ll even offer if he would rent it to me for a couple of days.
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8352
            If you only to use it once, don't bother buying one. Then I'd take the risk buying a new board at a decent outfit. Don't buy at Ebay at a seller you can't return nothing. One guy here got hosed with a bad board on a thread I am working on. I get my stuff at SJ (ShopJimmy). You want to order that TCon as well. Not that if you do need it later and then waiting, extra shipping etc... So that is what I would do in your case. SJ, order main and Tcon.
              You will still have to learn how to use it first, then you will have to know what you see on the screen and what it means.
              • jord4231
                Toshiba 37AV500A Regza TV good power supply no sound no picture
                by jord4231
                Hi Everyone,
                I'm working on a Toshiba 37AV500A Regza TV.
                The issue:
                TV was working picture and sound went out. Green stand by light stayed on, It will respond to the power button being pressed (goes in and out of standby)
                The TV will very intermittently work for around 40 mins then stop. This doesn't seem to matter if its hot/cold unplugged for a while etc.
                I checked the PSU voltages and everything looked good.
                No bulging caps or signs of heat.
                24v aud = 24.41v
                12v = 11.98v
                5v = 5.062
                p_o/f = Goes high...
                03-29-2022, 09:21 PM
              • TR103
                by TR103
                - it keeps rebooting
                01-22-2025, 04:12 PM
              • Mgiffune
                by Mgiffune
                06-09-2024, 10:28 AM
              • Ierwin
                by Ierwin
                05-13-2025, 03:31 PM
              • jchang
                Samsung UN70NU6900F no picture and no sound
                by jchang
                Hi all
                I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                Symptom:
                No picture no sound.
                When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                No sound at all.
                What I tried:
                1. I tried unplugging the left or right ribbon...
                01-09-2023, 06:28 PM
