BUSH-LED22982FHD-No STB-Fluctuating Voltage.
  • AlbertRoss
    • Jul 2012
    • 181
    • United Kingdom
    Hi, have this BUSH 22" TV that has no standby light, no image or sound. Have replaced bad diodes - D9, D25, D12 and D10 using UF5408, all new from same batch. Have 240.00 VDC coming in, fuse ok, 96.0 VDC across both sides of V1 (14N511K) Voltages stable (11.28 VDC) on D25, D12 and D10, voltage fluctuates on D9 - 24 VDC to 28 VDC? Checked caps in circuit with ESR, all seem ok?
    Not sure what to check next?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: BUSH-LED22982FHD-No STB-Fluctuating Voltage.
    Hmm so you still have no standby ? But you have 24v and 12v in out from the diodes ? Sounds like mobo problem to me.
    • AlbertRoss
      • Jul 2012
      • 181
      • United Kingdom
      Mobo, would that be the main board?
        • 31291
        check all the voltages first,
        i think they are printed under the board.
        • AlbertRoss
          • Jul 2012
          • 181
          • United Kingdom
          No numbers underneath any of the boards, I'll check some voltages.
          • steviewonder
            • Dec 2013
            • 183
            • england
            These power supplies are in a always-on state,So as reecyburger suggests,your mainboard is at fault.
            • multimeter
              • Jan 2011
              • 739
              • united kingdom
              does PS-ON signal fluctuate?,might indicate main board problem,as that signal is generated at the main board,disconnect main board ,voltage still fluctuating on psu?
              fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
              please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
              • AlbertRoss
                • Jul 2012
                • 181
                • United Kingdom
                So unless I can source a main board at a decent price, average on e-bay around £30.00, it's not viable. I presume if I was able to find a board, it would have to be exactly the same, i.e. numbers, screen size, make and model etc?
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Dam I have a board but its for the 24" version of your set and you cant just replace it with any old 17MB82 you need the EXACT one which matches your panel if not it wont work.
                  • AlbertRoss
                    • Jul 2012
                    • 181
                    • United Kingdom
                    Thanks for looking Reecey, love watching your videos.
                    Have disconnected the main board and voltages seem to have stabilized?
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      could it be a faulty eeprom? can you get a pre programmed one or a copy of the firmware?
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Haha no worries, deffo a mainboard fault. As Vince says my bet is probably firmware but again finding the exact flash is very hard.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          There is a bloke on here called Michael Dranfeild he has alot of Vestel firmwsre send him a Pm
                          • AlbertRoss
                            • Jul 2012
                            • 181
                            • United Kingdom
                            Will do, thanks.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              Also worth emailing ohms supplies and see if they have a pre programmed chip the downside is if it does not work its a waste of money, you could i guess wait for a cheap matching mainboard from ebay etc then copy the data to your old board and if works ok sell one board on to get some money back.
                              • Fernon@Repair
                                Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                                by Fernon@Repair
                                i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                                VCCIO voltage ok
                                VCCSA Voltage OK
                                VCCPLL Voltage OK
                                Ram Voltage ok
                                RamVTT OK
                                VPP 2.5 OK
                                But No Core Voltage
                                and i want to this vrm ic datasheet or pinout (ISL69269)
                                anyone have this ic pinout voltages?...
                                06-25-2025, 07:19 AM
                                Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                                by sam_sam_sam
                                I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                                The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                                Now...
                                06-09-2024, 10:57 AM
                                ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
                                3+1 Voltage Regulator for IMVP-7/VR12 CPUs
                                Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
                                core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
                                configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
                                serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
                                Based on Intersil's Robust Ripple Regulator...
                                11-05-2024, 03:24 PM
                              • ruletero
                                Acer a515-43 low battery charge voltage
                                by ruletero
                                Hi
                                Acer A515-43
                                LA-H801P
                                Fail: Does not charge battery, has low voltaje on connector.
                                Laptop didn't want to turn on, only charge led blinked.
                                I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                                I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                                Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                                10-24-2022, 02:31 PM
                                MEDION AKOYA S6421W-i5-1128 Notebook Specification for Upgrade or Repair
                                This specification for the MEDION AKOYA S6421W-i5-1128 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S6421W-i5-1128 boardview and S6421W-i5-1128 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                09-06-2024, 05:46 AM
