BUSH-LED22982FHD-No STB-Fluctuating Voltage.
  • AlbertRoss
    • Jul 2012
    • 181
    • United Kingdom
    Hi, have this BUSH 22" TV that has no standby light, no image or sound. Have replaced bad diodes - D9, D25, D12 and D10 using UF5408, all new from same batch. Have 240.00 VDC coming in, fuse ok, 96.0 VDC across both sides of V1 (14N511K) Voltages stable (11.28 VDC) on D25, D12 and D10, voltage fluctuates on D9 - 24 VDC to 28 VDC? Checked caps in circuit with ESR, all seem ok?
    Not sure what to check next?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: BUSH-LED22982FHD-No STB-Fluctuating Voltage.
    Hmm so you still have no standby ? But you have 24v and 12v in out from the diodes ? Sounds like mobo problem to me.
    • AlbertRoss
      • Jul 2012
      • 181
      • United Kingdom
      Mobo, would that be the main board?
        • 31020
        check all the voltages first,
        i think they are printed under the board.
        • AlbertRoss
          • Jul 2012
          • 181
          • United Kingdom
          No numbers underneath any of the boards, I'll check some voltages.
          • steviewonder
            • Dec 2013
            • 183
            • england
            These power supplies are in a always-on state,So as reecyburger suggests,your mainboard is at fault.
            • multimeter
              • Jan 2011
              • 739
              • united kingdom
              does PS-ON signal fluctuate?,might indicate main board problem,as that signal is generated at the main board,disconnect main board ,voltage still fluctuating on psu?
              fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
              please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
              • AlbertRoss
                • Jul 2012
                • 181
                • United Kingdom
                So unless I can source a main board at a decent price, average on e-bay around £30.00, it's not viable. I presume if I was able to find a board, it would have to be exactly the same, i.e. numbers, screen size, make and model etc?
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Dam I have a board but its for the 24" version of your set and you cant just replace it with any old 17MB82 you need the EXACT one which matches your panel if not it wont work.
                  • AlbertRoss
                    • Jul 2012
                    • 181
                    • United Kingdom
                    Thanks for looking Reecey, love watching your videos.
                    Have disconnected the main board and voltages seem to have stabilized?
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      could it be a faulty eeprom? can you get a pre programmed one or a copy of the firmware?
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Haha no worries, deffo a mainboard fault. As Vince says my bet is probably firmware but again finding the exact flash is very hard.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          There is a bloke on here called Michael Dranfeild he has alot of Vestel firmwsre send him a Pm
                          • AlbertRoss
                            • Jul 2012
                            • 181
                            • United Kingdom
                            Will do, thanks.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              Also worth emailing ohms supplies and see if they have a pre programmed chip the downside is if it does not work its a waste of money, you could i guess wait for a cheap matching mainboard from ebay etc then copy the data to your old board and if works ok sell one board on to get some money back.
                              • mkdj
                                MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
                                by mkdj
                                About me, my goal and the equipment I (don't) have:
                                I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
                                About my issue and my goal:
                                A friend of mine has a MacBook Air M1 A2337 that does not...
                                04-03-2025, 08:28 AM
                              • rddube
                                Lenovo L490 Ram voltage circuit malfunction
                                by rddube
                                Hello friends,
                                Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
                                I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
                                07-15-2025, 04:41 PM
                              • Fernon@Repair
                                Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                                by Fernon@Repair
                                i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                                VCCIO voltage ok
                                VCCSA Voltage OK
                                VCCPLL Voltage OK
                                Ram Voltage ok
                                RamVTT OK
                                VPP 2.5 OK
                                But No Core Voltage
                                and i want to this vrm ic datasheet or pinout (ISL69269)
                                anyone have this ic pinout voltages?...
                                06-25-2025, 07:19 AM
                              • electron_jj
                                Panasonic TH-L42D25A checking the PSU output voltage
                                by electron_jj
                                Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                                I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                                08-29-2021, 08:13 AM
                                Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                                by sam_sam_sam
                                I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                                The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                                Now...
                                06-09-2024, 10:57 AM
