Re: PHILIPS 26 PFL3403/10 slow start up
Guys please ! This is a panel fault, what screen is used ? Guessing a V260B1 from Cmo ?
change all caps near the white socket photo 1Leave a comment:
Check your 24V/6A, 12V/4A supplies and see if one of them is low and rising while warming up.Leave a comment:
PFL series suffer with bad secondary caps with out the obvious sign,gluxen caps if memory serves me right,replace on sight and test again,
the 12v to the main could be low causing the lines,does the on screen menu show when the lines are there?,it could be a main board issue ,use a hair drier to heat the power board at first startup and note if the tv corrects itself faster,then try with the main board,which would indicate capacitor issue,though i think this is maybe a main board issueLeave a comment:
its not Voltage, he will find the 12 Volts, but this 12 V hat less currents where it should be 4ALeave a comment:
Measure your power supply voltages and see if there is a problem.
Service manual available for download:-
take photo to the power supply, its bad capacitor at the line to provide the main board with VDCLeave a comment:
i have this TV PHILIPS 26 PFL3403/10 and after a time when is turned off or unpluged i have some problem. When i power it on shows a slowly changing pattern of coloured vertical lines for about 10 minutes before the TV image appears. Than work perfect.
I opened it to check if there are any blown caps, but they looks okey, i think. Any ideas how to remove that, because it is annoying to wait sometimes 10 min to tv turn on.Tags: None
by CornitoHello Team,
New issue on LCD panel where I need to find out the cause and the potential solution.
This is on the Philips 50PUH6400, the LCD panel is an INNOLUX V500dk2 xrs1.
I have image, on the right side, the image is more or less normal even if there is a small blur on edge, on the left there is an issue.
When moving up and down in the menu on the right the image is slow to disappear, and is darker, like red/brown.
I've checked voltages, no issue found comparing right and left side of the panel driver.
VHG VGL CKV... are the sames on... -
by G33RTPhilips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
It does power up when pressing the power button.
I already try the power button while plugin the plug with no result.
Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
Could this be an PSU or eMMC issue ? -
by gjlpereiraHi forum.
I'm working on a macbook pro, model a1708, that is running extremely slow.
Everything on it seams to work just fine, it just works extremely slow; painfully slow; especially running macos (windows and linux actually run OKish on it, slow, but usable).
One other symptom of the problem with the machine is that the fan is always running at full speed.
This machine has been worked on by someone else previously; they tried to repair it, but with no success. The motherboard does have sings of being worked on, but it all looks good/OK; like... -
by janos6662000Hi
I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
When i applied cable signal to check image, i had normal picture, but TV was restarting.
I downloaded original firmware and applied the update, but the problem remained.
From a colleague i received a "factory package software" which is a lot bigger.
I made another firmware update, but still did not solve the problem.
Somewhere on the way the error got worse, because at the moment the... -
by aidanmoHello,
I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
I thought maybe the speakers got damaged, so I replaced them - no dice.- Using the internal speakers, it always happens.
- Using the headphone jack, it never happens.
- Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
- Loading...
