Bn41-00813 issues
  • Rickig
    • Mar 2015
    • 112
    • England
    Bn41-00813 issues
    Hi folks
    I've come across this fault several times before but never found a resolve, I know it's been spoke of on here before just wondered if a solution has been found.
    The fault is that the set will cycle , it will come on and work fine for 15seconds or so then power off and straight back on for another 15 secs and so on.
    I've replaced EEPROMs which hadn't cured it.
  • Nick's Tvs
    • Jan 2014
    • 621
    Re: Bn41-00813 issues
    Post the part number of the board BN94-
    also if you could post a picture of the board that would also help us.
    Try re-flowing the main IC
      Did you already try heating the board with hair dryer, especially under that big metal shield?
      B?, D?, E?
      Samsung BN94-01178B (BN41-00813B) Main Board.
      Samsung BN94-01121S (BN41-00813D) Main Board.
      Samsung BN94-01472M (BN41-00813E) Main Board.
      Picture provided by shopjimmy.
      • CapLeaker
        Leaking Member
        • 8214
        x2 what budm said.
        • popzeggey
          Dell Latitude E7450 Power issues and fault
          by popzeggey
          I have a dell e7450 that shuts down abruptly when on and tries to restart. When the laptop attempts to restart, the hdd and wifi led is solid but power/battery led blinking hdd. Fault Description The memory modules are detected but encountered an error.
          I have tried all basic troubleshooting steps like removing the battery and pressing power button for 30secs but issue persists. I have tried different fully working rams but issue persists. Any help would be much appreciated
          01-16-2025, 04:31 PM
        • fluzocapacitor
          Touchscreen Issues on Samsung Galaxy Tab A: Replacement Problems or Hardware Fault?
          by fluzocapacitor
          The touchscreen of my tablet started malfunctioning in a strip about one centimeter wide that stretched across the screen, approximately 5 centimeters from the top edge of the tablet.
          I bought another touchscreen and replaced it. The issue with the strip disappeared, but on this new screen, the bottom area didn't work, up to about 6 centimeters from the bottom edge of the tablet. The malfunction was quite strange because it only occurred when the first touch was made in that area. In other words, if you touched an area outside the faulty zone and then dragged into...
          01-01-2025, 03:56 AM
        • Rictech
          Panasonic SA-MAX770PU SMPSU board fault....
          by Rictech
          Hello everyone. 😀
          As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
          Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
          Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
          This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
          There are no devices that have exploded or otherwise show signs...
          08-26-2024, 01:05 AM
        • howardc64
          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
          by howardc64
          • Prior owner tried a replacement main board. No difference.
          • Samsung 2x red blinking standby LED = panel fault
          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
          07-19-2025, 10:54 PM
          ESR meter came to the rescue again today with a PLC I/O card fault
          by sam_sam_sam
          I have been having a fun time at work with two pieces of equipment that had shorted components or shorted component cables to machine frame
          I would check what my multi meter was telling me about how many ohms I getting with the multi meter was telling versus the ESR was telling me about weather or not it really was a short to machine ground or not
          One note at first we thought that it might be a bad I/O card or a malfunction PLC including me as well but I thought I would try and see if removing the I/O cables would make a difference or not and this time it did make a difference...
          12-18-2023, 08:17 PM
