Proscan PLED4274A-B
  • smuddge
    • Feb 2012
    • 96
    Proscan PLED4274A-B
    I was given this and another LG tv that I also posted about to repair for a relative.
    This Proscan PLED4274A-B turns on, backlight lights up fine but there is no picture at all.
    No visible damage to any of the board with this one either.
    I don't want to spend 80$+ US for a new mainboard if this is some problem with the boards that run along the top that are tab bonded to the panel.
    any images needed just let me know and I will post them up.
    thanks in advance for any guidance.
    Re: Proscan PLED4274A-B
    We do need the pictures so we can see if it has Stand alone T-con or LCD panel with integrated T-con.
    You will need to check if the T-con is getting the switched dcV feeding from the main board or not.
    • smuddge
      • Feb 2012
      • 96
      it has an integrated tcon.
      sorry pic of whole tv attached.
      is there a fuse I could replace or jump just to see if it is that causing the problem?
      I haven't seen one with in integrated tcon before and by the sounds of it this tv is scrap if thats the case correct?
        The fuse will be on that long T-CON board in the panel.
        • multimeter
          • Jan 2011
          • 739
          • united kingdom
          unusual for a 42" to have intergrated T-CON?,i thought these had standalone t-con
          fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
          please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
            They are trying to make it as cheap as possible and less serviceable.
              Please take good clear closed up pictures around the LVDS connector, the fuse should be closed by the connector.
              • smuddge
                • Feb 2012
                • 96
                here is the requested pic. the fuse is the one with the K on it? if so i tested it with multimeter and it shows to be fine.
                is there anything else i can look at on this integrated tcon that could be the problem and could be replaced inexpensively.
                • Diah
                  • Feb 2013
                  • 6376
                  it has being repaired or tried to repair.. its crap... sorry..
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    yes thats the fuse what dc voltage do you get on each side of the fuse
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      I bet you the fuse tests good and all the other voltages do. I had same panel with shorted tab bond driver causing no image at if thats the case not fixable Pure modern junk !
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        As the tab bonds are at bottom i guess someone could of used cleaner on the screen which has ran down and damaged the tabs with corrosion etc we have saw a few on the site in the past or as you say a shorted tab bond driver causing it.
                        • smuddge
                          • Feb 2012
                          • 96
                          upon further inspection i noticed a small burn mark on the plastic beneath the power supply above a fet listed as LP18n20 1211.
                          could this be the problem here?
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            Can you check the resistance of the Mosfet. It looks as though it may well be damaged.
                            • smuddge
                              • Feb 2012
                              • 96
                              sorry not really adept at this stuff yet. still learning. how to do i check resistance of the fet? I have meter set to 200k ohms and it shows 10 from the 2 sides. is this correct?
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                https://www.youtube.com/watch?v=RBJGOOTEwfU
                                • smuddge
                                  • Feb 2012
                                  • 96
                                  ya i don't think my multimeter works right then. set it to diode.
                                  shorted all pins and followed the video. I get nothing showing with any combination of source gate or drain on any mosfets on this board.
                                  my multimeter just shows a 1
                                  • smuddge
                                    • Feb 2012
                                    • 96
                                    i would settle for just ordering one and trying it.
                                    i looked on digikey for this part and i find nothing.
                                    is the part no LP18N20? or is there another option that i could use in its place?
                                    any info would be great.
                                      You can find out if that MOSFET is functioning or not in the circuit by checking the DCV on each pin of the MOSFET when TV is off and when power switch is activated.
                                      • smuddge
                                        • Feb 2012
                                        • 96
                                        just wanted to update this for anyone else with this tv. it was the mosfet. changed it and it is working great. thanks for all the help here.
                                        will post again soon. i have a few more tv's to look at.
                                        again great forum great users and extremely helpful and friendly.
                                        love this place
                                        • x_orange90_x
                                          TCL 50S535 bad tcon or panel issue?
                                          by x_orange90_x
                                          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                          03-29-2025, 11:02 PM
                                        • advant
                                          by advant
                                          02-03-2020, 12:25 AM
                                        • Hakuu
                                          by Hakuu
                                          Hi There,
                                          More Details
                                          TV Model - LG OLED77G1PUA
                                          07-12-2023, 02:37 PM
                                        • Daren87
                                          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                          by Daren87
                                          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                          08-13-2023, 03:25 PM
                                        • alltvrepairs
                                          Lg TCon test pins for screen test
                                          by alltvrepairs
                                          i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                                          Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                                          Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                                          Appreciate your help....
                                          06-13-2025, 06:33 AM
