LG 42LD550 issues
  • Veeshun
    • Mar 2016
    • 10
    LG 42LD550 issues
    For the last couple of months I've been dealing with an issue that I cannot seem to find anyone else having. I bought the 42LD550 exactly 5 years ago, this TV is not in the living room so it does not get as much use as the other TV.
    The first time it did this was last winter (2014) but it only did it once and never again. About the middle November this issue started up again, I noticed it was always in the morning or at night when the TV would be off for awhile. I haven't been able to fully prove it but it seems to happen when the room is cold. I'll turn it on, it will be fine for about 5-10 minutes then about 95% of the screen will freeze, fade with lines on top and the image will refresh in which the process repeats again (see videos below for example). The top 5% of the screen is fine with no issues. The sound works fine. If I turn the TV off for a couple minutes (sometimes I can just turn it on and off) it will be fine with no issues at all for the rest of the night/day. Tonight was the first time I just left the issue alone, it landed up stopping after about 2-3 minutes and was fine. Some days it won't do it at all for a few days then it'll come back randomly.
    I also noticed after I power cycle it that sometimes it'll blink to a black screen very quickly about every 60-120 seconds. This will go on for about 5-10 minutes then stop. The blinking is very quick with no issues with the sound. Just like the issue above after it stops it doesn't come back.
    I've been searching weekly since November for answers, I've looked all over google and Youtube. I haven't found any pictures or videos that match my issue. I've also asked for help at other places with no luck. I just want to know if I can actually fix this or should I be shopping for a new TV (which I hope isn't the case )
    I've included pictures and below is two video links. The first was from last year and the second is from tonight.
    https://www.youtube.com/watch?v=lwxDI_EDL1s
    https://www.youtube.com/watch?v=GSJDm31i09s
  • sugar_ray
    • Dec 2012
    • 121
    Re: LG 42LD550 issues
    Well being an LCD this will be easier to diagnose then a plasma. From my experience this does NOT look like a bad or failing panel which is pretty much the kiss of death and replacement is cheaper then a panel!! That leaves us with
    -power supply
    -TCON board (timing control)
    -digital main board
    Best step for you at this point would be to unscrew the back cover and snap a few pics. Some knowledgable folks can chime in. Inspect the capacitors on the power supply board. Have any of them bulged or popped their tops? There is a very good chance this could be a TCON board that needs replaced. If that's the case, they are fairly cheap for this make/model.
    Does this symptom occur on all inputs? Aka: hdmi 1, hdmi 2 etc....
    Looks at times, out of sync to me, in which case the timing control board handles a lot of the processing
    Just my 2 cents
    • Veeshun
      • Mar 2016
      • 10
      -power supply
      -digital main board
      Just my 2 cents
      I worry that it's the tcon because if I'm not mistaken, it's attached to the panel and cannot be replaced . I also noticed that the parts for this TV are very hard to find and the ones I found have insane prices.
      It happens on all inputs. I will work on getting a picture with the back panel off.
      • CapLeaker
        Leaking Member
        • 8327
        reseat the LVDS cable and try the tab bonds.
        • sugar_ray
          • Dec 2012
          • 121
          Actually your partially right. The Tcon attaches to the panel through LVD cables as "cap leaker" mentioned!! Still.....very easy to replace!! 2small screws hold the TCON board in place, you simply lift the tabs up and the cables detach from the board. Very easy to replace!! As cap leaker mentioned being your problem is intermittent, it's worth a shot of undoing the cables and re-seating them
          Not an expensive board
          http://m.ebay.com/itm/TCON-BOARD-687...874?nav=SEARCH
          • aaronwt6
            • Apr 2013
            • 855
            • US
            In my opinion, the fact that there is a narrow strip at the top of the screen that looks relatively normal compared to the rest would lead me to believe it's a bad panel.
              Also what do you get if you have ribbon cables between the T-CON and the LCD panel connected one at a time?
              • CapLeaker
                Leaking Member
                • 8327
                The owner said: "I worry that it's the tcon because if I'm not mistaken, it's attached to the panel and cannot be replaced".
                I didn't see any at SJ.
                  If it uses the same panel as this one then it uses integrated T-CON.
                  https://www.badcaps.net/forum/showthread.php?t=34539
                  It is so important to provide the pictures so we do not to make a guess.
                  • Veeshun
                    • Mar 2016
                    • 10
                    I've looked up the model number and SVC number, I've read that the TCON is integrated. On SJ there's no TCON listed for parts.
                    I forgot to add info to my initial post:
                    Model: 42LD550-UB
                    SVC Code: 42LD550-UB.CUSTWLHO
                    Is it normal for it to be fine after a few minutes with no issues for the rest of the day? Some weeks it won't appear for 2-3 days then all of a sudden show up for 5-10 minutes then it's gone again. I think I'm just really hoping that this is not the case, took me awhile to find this TV and I really like it.
                    Sorry for the delay, had a very busy day at work. I will be removing the back panel this weekend and will take pictures to post on here.
                    • Veeshun
                      • Mar 2016
                      • 10
                      Sorry for the delay, been really busy with work. I don't have much experience but the only thing I really saw were two caps looked crooked in the last two pictures. Here are the pictures I promised:
                      • CapLeaker
                        Leaking Member
                        • 8327
                        Don't pay any attention to crooked standing or laying caps. They still function the same.
                        • Veeshun
                          • Mar 2016
                          • 10
                          Oh okay, just making sure. Does anyone have any idea what the problem might be? Like I said, this TV doesn't have the average amount of hours on it that the average 5 year old TV does. I just hope I can fix it, I really like this TV and researched it for awhile. It's just a shame that these things happen.
                          • Diah
                            • Feb 2013
                            • 6438
                            which version of Firmware you have on your TV. ?
                            42LD550 suffer from main board bad soldering, main control board Model EBT60955753 LG MAIN (3642-1052-0150)
                            baked the main board in the oven for about 10 minutes at around 385 °F and It will be fine
                            • Veeshun
                              • Mar 2016
                              • 10
                              My firmware version is 08.03.06. My main board model is EBT60955753 (3642-1092-0150 (1D)).
                              • Diah
                                • Feb 2013
                                • 6438
                                same source board , baked the main board in the oven never move it out until its cool down
                                • anthonya661
                                  • Apr 2015
                                  • 4
                                  • usa
                                  lol so I did what DIAH SAID TO DO AND IT WORKED REVIVED 2 BOARDS THANK YOU SO MUCH.
                                  • dabone
                                    • Aug 2010
                                    • 30
                                    I used my hotair rework station and just heated the chip along with it's heatsink nearest the lcd cables, I used 285c moving constantly around the heat sink, (I have a small nozzle installed currently)
                                    It's now working fine and if it fails again, I'll try to remember to post back here as to how long the repair lasted.
                                    • syaoran123
                                      • Jun 2014
                                      • 178
                                      I use 350C every time and while the heatsink is still on. No damages and no components falling off.
                                      • DqMagetz
                                        Acer Nitro 5 AN515-54. displays on the external monitor and works fine, the issue is NO display on the internal screen
                                        by DqMagetz
                                        Good day!
                                        I have a customer's laptop — Acer Nitro 5 AN515-54 (EH5VF - LA-H501P). It has a display on the external monitor and it's working fine, but the issue is NO display on the internal screen. I already replaced the eDP cable and checked the LCD connector pins.
                                        Here are the voltage readings:
                                        • Input – 19V (stable)
                                        • +LCDVDD – 3.3V briefly, then drops to 0V
                                        • EDP_HPD – 3.3V briefly, then drops to 0V
                                        • PCH_BKL_PWM – 2.2–5V briefly, then drops to 0V
                                        • EC BKOFF# – 1.8V briefly, then drops to 0V
                                        • PANEL_OD_EN – 0.3V
                                        Is it possible that the EC chip is corrupted or damag...
                                        07-12-2025, 09:37 PM
                                      • coasterghost
                                        Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                        by coasterghost
                                        For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                        Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                        Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                        System Hardware:
                                        Processor: AMD Ryzen 7 PRO 5850U
                                        Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                        09-08-2025, 10:46 PM
                                      • spice_disc
                                        Vizio TV M50-C1 reboot cycle and static on screen
                                        by spice_disc
                                        I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                                        The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                                        09-08-2024, 02:37 PM
                                      • SoulFreeze
                                        Audio Issues - Realtek ALC3306 - Lenovo Slim Pro 7 14ARP8 - Type 83AX
                                        by SoulFreeze
                                        Hi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
                                        After repairing the above issue, I realized the following remaining problem,
                                        Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
                                        The computer recognizes headphones are connected and displays a popup in windows
                                        Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer...
                                        06-21-2025, 09:53 AM
                                      • Gibon378
                                        Problem with stopping audio and video for no reason
                                        by Gibon378
                                        PC Specs:
                                        • CPU: Ryzen 5 1600
                                        • GPU: GTX 1080 Palit JetStream
                                        • MOBO: ASRock ab350 PRO4
                                        • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                        • PSU: XFX 650W (don't remember what model)
                                        • OS SSD: ADATA SP920
                                        • OS: Windows 10 21H2
                                        Problem description:
                                        Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                        11-19-2022, 09:41 AM
