Dim Bulb Tester
    Re: Dim Bulb Tester
    You're literally just wiring it in series with Vs, so cut the Vs wire on the harness and put it in series between the cut wires. Make sure to break all Vs wires, no point having any connected to bypass the bulb.
    • budwich
      • Jul 2015
      • 3097
      Re: Dim Bulb Tester
      I think in most cases, your want lower wattage bulbs as opposed to higher wattage. Something like two 40 watts in series would be good as the higher resistance will keep the current down and likely save components. Chandelier bulbs at 25 watts would be even better.
        Re: Dim Bulb Tester
        More or less true, but it's also important that the bulb is big enough to allow the board to be tested. A 60 or 100W bulb is reasonable, as it allows enough current to drive the panel from the Z-sus, if only weakly with a maldischarged image, but still it shows partial functionality.
        • tech2014
          • Aug 2014
          • 807
          Re: Dim Bulb Tester
          thanks for the info. So whats the easiest way to connect 2 bulbs in series? Less wires the better.
          • tech2014
            • Aug 2014
            • 807
            Re: Dim Bulb Tester
            I found this on eBay. Its a 200W 230V bulb. Will this work to test the VS?
            http://www.ebay.ca/itm/6-Osram-200-W...sAAOSwu4BVoDW0
            • budwich
              • Jul 2015
              • 3097
              Re: Dim Bulb Tester
              go to your local home depot, get two sockets and join the wires for a series connection, screw in the two bulbs and your done... probably for a total of $10.
                Re: Dim Bulb Tester
                I will go with two lamps in series so you can easily use two lamps with the same Wattage, I.E two 100W, or when working on lower power units then you can use two 75W, etc.
                • tech2014
                  • Aug 2014
                  • 807
                  Re: Dim Bulb Tester
                  ok. This may seem like a stupid question, but how do I connect them in series correctly. Using google I see contradictory info. There is the hot(black wire) ,white(neutral) and ground(green) for polarized plug. How do I connect these wires to the second bulb?
                    Re: Dim Bulb Tester
                    In the same way as you'd make any series circuit...by wiring neutral of one bulb to live of the other. So the bulbs are electrically "one after another" so to speak.
                    • tech2014
                      • Aug 2014
                      • 807
                      Re: Dim Bulb Tester
                      Thats what I thought. Thanks for the reply tom.
                      So when I want to test the VS line, I just connect the neutral and hot wire into the VS line after removing the VS from the connector. I already have a connector with the VS line wires cut, so I can connect the bulb wires in.
                        Re: Dim Bulb Tester
                        Yep, but all other wires (GND, 5V, 15V, Va, etc.) need to be connected as usual.
                        • tech2014
                          • Aug 2014
                          • 807
                          Re: Dim Bulb Tester
                          OK I am now ready to test the TV with my dim build tester. The XSUS board keeps shorting out and blowing a bunch of IGBTs, the VS line shorts out. To prevent blowing the parts again after repair, I am doing the following:
                          I cut the VS wires going from the YSUS to the XSUS. Now I want to put my two 70W bulbs in series with the VS line. I will connect wires from both bulbs into the connector with the VS lines cut. One bulb wire will be on VS line from power supply and the other will be connected to the connector for VS line on XSUS board.
                          Can someone look and tell me if I am doing this right?
                          See pics below.
                            • 31199
                            Re: Dim Bulb Tester
                            that's wrong.
                            wire them like christmas-tree lights.
                            [source]------------[lamp1]----[lamp2]-------------[destination]
                            • tech2014
                              • Aug 2014
                              • 807
                              Re: Dim Bulb Tester
                              So the bulbs are connected wrong? I have the neutral of the first bulb going to the live of the second bulb, is that not in series?
                              Can someone explain to me what to do? I have never done this before.
                              • martino
                                Not so "senior"
                                • Aug 2013
                                • 997
                                • canada
                                #35
                                Re: Dim Bulb Tester
                                That looks like a Samsung pn51? If you get in a pickle and need board I believe I got a few sets of boards for these.
                                Proud owner of dozens of broken TV's and many,many,many boards.
                                Our website and passion:http://hollenhundshepherds.com/
                                • repair-it
                                  TOSHIBA DLP 52HM95 How to reset timer module on bulb
                                  by repair-it
                                  I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
                                  Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
                                  10-11-2023, 07:18 PM
                                • nubinator
                                  how can i test individual leds without tester
                                  by nubinator
                                  Hello I have TCL 65S4 and it has no backlight, seems common problem on this tv to have bad LED's. I have no tester though I thought I could just test each LED with 2xAA batteries for 3v but it doesnt light up at all?
                                  I saw a vid with LED tester on this TV and it had 130v for 1 good line which is 24 LEDs does that mean it needs around 5.5v per LED?
                                  10-25-2022, 11:05 PM
                                • ezenia
                                  LUMIMAN Smart Bulb IC ID?
                                  by ezenia
                                  I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
                                  In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
                                  04-28-2025, 05:56 PM
                                • JoelJ
                                  Ampeg PF-350 bass amplifier head repair
                                  by JoelJ
                                  Hello everyone!
                                  I recently bought a broken Ampeg Portaflex PF-350 bass amplifier head in unknown condition. As it turns out, it's completely dead. Tried powering it on with the dim bulb tester, dead short.
                                  I have attached the schematic below.
                                  What I found:
                                  TH1 is cracked visibly but measures 6 ohms. Will replace it but should be okay for testing for now.
                                  Either Q1 or Q2 was dead shorted. Don't remember which one but one of them. Both are FQPF12N60C. I replaced both with SiHP18N50C to test as I had these on hand. They are the same package, pinout, mosfet type....
                                  09-09-2025, 08:37 AM
                                • chth96
                                  How Can I test PWM DM0365R?
                                  by chth96
                                  Hello
                                  I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                                  So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                                  I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                                  I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                                  06-18-2025, 04:14 PM
