Samsung UN55B6000VFXZA bad panel?
  • mattpd
    • Oct 2012
    • 301
    I put some pressure with a pencil eraser on the panels tab bonds and on the TCON bonds but it did not make any change.
    Is it worth trying a new TCON or is this another crapped out Samsung panel?
  • ryanfan03
    • Apr 2014
    • 45
    Re: Samsung UN55B6000VFXZA bad panel?
    the way it is rippling out from a central point (at least thats what i think i see) makes it seem like something either hit the screen or bumped into it.
    Doing this on the side to make some extra money for my daughters dance competition.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Hmm thats odd however I would probably say bad panel.
      • mattpd
        • Oct 2012
        • 301
        I think that is being caused by the Windows 7 background. I should have set it as a solid color.
        • CapLeaker
          Leaking Member
          • 8184
          odd indeed... x2 looks like solarized a bit though...
          • Shinju
            • Mar 2014
            • 1239
            Bad panel and bad t-con, notice black horizontal lines in photo two are very common in B series LED Samsung panels and there is no fix or no known cause as to why they happen.
            Sometimes they cover full screen or most common is left to middle and dither out on the right side
            If the t-con is cheap you can try to see if it remedies the solarazation issue but those lines will probably stay.
            • Shinju
              • Mar 2014
              • 1239
              One other thing you can try before spending money on parts is to access the service menu and locate the test patterns and see of those lines persist post t-Con or pre t-con.
                09-07-2024, 05:50 AM
              • x_orange90_x
                TCL 50S535 bad tcon or panel issue?
                by x_orange90_x
                Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                03-29-2025, 11:02 PM
              • advant
                by advant
                02-03-2020, 12:25 AM
              • NWArkGuy
                Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
                by NWArkGuy
                Well, I will be the first to admit that I screwed up...
                In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
                I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
                I have 2 that I have found and have in my possession. ...
                10-12-2023, 10:13 PM
              • KYBOSH
                Samsung UN50TU8000 - Dead Panel Forensic Questions
                by KYBOSH
                I came across a 50inch TU8000 that wouldnt start up properly (blinking stand-by light, backlights would cycle on and off).
                When i opened it up and removed the power to the mainboard the backlights powered up and everything looked uniform.
                When reconnected the mainboard but disconnected the flex cable to the panel i heard the TV startup with the intro sound.
                Later I checked for shorts on the panel PCB boards but could not find anything.
                When I took a look with the FLIR i noticed the 2 resistors...
                08-10-2024, 08:39 AM
