vestal help please
    vestal help please
    I have just been given 2 alba 32880hdf tvs on will only come on if warmed up with a hair drier on the power board I have replaced most caps but still needs warming up if left pluged in it will come straight on until it is unplugged the power board is a 17pw26-4
    the second even thought they are the same model have completely different boards this has a 17ips10-3 power board when plugged in the stand by light comes on when I hit power the light goes to blue and red flashing and I can do nothing with it until I turn it off and the mains both are English 240 volt tvs any help welcome
    Re: vestal help please
    As you have said you have replaced most of the capacitors did you do the start up capacitors on this psu if your not sure up load a clear picture and we can point them out. The second board im not sure on have you tested all the diodes etc.
      startup caps are small ones.
        Here is how to fix them:
        17PW26,
        Very common issue is bad capacitors please check the fourm for how to diagnose badcaps. The smaller ones and the ones in a group of 3 under the main mother board plug should be changed.
        17IPS19-3,
        Common issue with these is blown output diodes which when failed wont let the Tv turn on (protection circut engaged) you will need a DMM to test have you got one ? Or the software for the Tv has corrupt meaning mainboard fault you will need to re-flash the firmware if so.
          https://www.badcaps.net/forum/showth...ight=17ips10-3
            just had a look at the start up caps they apper good but tomorrow I will change them anyway I have had ones before that look ok but are not if it is left plugged in its fine but if unplugged I have to get the hair drier out again to get it to come on
              changed all but one a 2700uf as I don't have any and no change when pluged in it takes 10 mins before standby light comes on then another 5 mines to turn on
                tested all diodes removed one leg and tested none shorted out
                  Does heating the psu make it turn on faster ?
                    yes it does make it turn on faster if warmed up
                      can you try heating a certain area a time to narrow down the area that makes it turn on faster, with this fault i use a empty cardboard kitchen roll tube and aim the hot air down it so i can heat little areas at a time.
                        Why didn't you change the 2700uf thats the bloody 5vstby cap lol and you say you have checked the rst esr wise I willing to put a bet you have a bad cap problem here.
                          I repaired a 17PW26-3 last night. Bulging 2700uf cap along with others. As Reecey says, replace it. Often caps in the Vestel PSUs aren't visably failed but have a high enough esr to cause issues.
                            the 2700uf as not been changed as I have none to change it with so I have ordered some
