Dell U2718Q MStar controller overheating
  • AquaSonic
    • Dec 2010
    • 13
    Hello to the forum!
    I am currently troubleshooting the Dell U2718Q monitor, which will work perfectly until it randomly shuts down and after a number of minutes will power on and work again, until it randomly (but quicker) shuts down again.
    After some investigating i came to the conclusion that this is due to the Mstar MST9U37Q1 controller overheating, causing the monitor to shut down. When the controller is cool enough it will start working again. The power supply voltages at all times seem normal, nothing else feels hot on the board and by using a hair drier to play with the temperature it seems that this is the culprit. The controller has a soldered on heatsink which had a very bad application of thermal paste underneath. Replacing the thermal paste did nothing but to prolong the usage of the monitor.
    Searching for datasheets or schematics for the ic and monitor showed nothing. Has anybody any clue to the solution of this problem?
    Thanks a lot!
  • SeSeBe
    • Apr 2020
    Re: Dell U2718Q MStar controller overheating
    Check the voltage of Mstar MST9U37Q1 with a scope. It's possible to have high ripple on some rails.
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • DanPoka
      by DanPoka
      02-15-2025, 05:05 AM
      by momaka
      03-15-2023, 10:17 PM
    • NotEnough
      Seeking Dell G15 Motherboard ICs for Embedded LED Controller (UEL1 and UEL2)
      by NotEnough
      I'm working on a repair for my Dell G15 motherboard (model GDL5L) and need two specific ICs to restore the functionality of the Embedded LED Controller (ELC). The missing components are labeled as UEL1 and UEL2 in the schematic, and they're both critical for LED control and system signaling. Here are the details:
      1. UEL1
      • Part Number: SA0000AWJ70
      • Model: STM32F070CBT6TR_LQFP48_7X7
      • Function: This microcontroller manages system signaling, power management, and SPI...
      10-28-2024, 01:44 PM
    • Jesus Coder
      Issues Reviving Old Dell 2408WFPb Monitor
      by Jesus Coder
      I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
      06-25-2023, 02:33 PM
