vestal help please
  • cossiejay
    • Nov 2010
    • 83
    vestal help please
    I have just been given 2 alba 32880hdf tvs on will only come on if warmed up with a hair drier on the power board I have replaced most caps but still needs warming up if left pluged in it will come straight on until it is unplugged the power board is a 17pw26-4
    the second even thought they are the same model have completely different boards this has a 17ips10-3 power board when plugged in the stand by light comes on when I hit power the light goes to blue and red flashing and I can do nothing with it until I turn it off and the mains both are English 240 volt tvs any help welcome
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: vestal help please
    As you have said you have replaced most of the capacitors did you do the start up capacitors on this psu if your not sure up load a clear picture and we can point them out. The second board im not sure on have you tested all the diodes etc.
      • 31293
      startup caps are small ones.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Here is how to fix them:
        17PW26,
        Very common issue is bad capacitors please check the fourm for how to diagnose badcaps. The smaller ones and the ones in a group of 3 under the main mother board plug should be changed.
        17IPS19-3,
        Common issue with these is blown output diodes which when failed wont let the Tv turn on (protection circut engaged) you will need a DMM to test have you got one ? Or the software for the Tv has corrupt meaning mainboard fault you will need to re-flash the firmware if so.
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          https://www.badcaps.net/forum/showth...ight=17ips10-3
          • cossiejay
            • Nov 2010
            • 83
            just had a look at the start up caps they apper good but tomorrow I will change them anyway I have had ones before that look ok but are not if it is left plugged in its fine but if unplugged I have to get the hair drier out again to get it to come on
            • cossiejay
              • Nov 2010
              • 83
              changed all but one a 2700uf as I don't have any and no change when pluged in it takes 10 mins before standby light comes on then another 5 mines to turn on
              • cossiejay
                • Nov 2010
                • 83
                tested all diodes removed one leg and tested none shorted out
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Does heating the psu make it turn on faster ?
                  • cossiejay
                    • Nov 2010
                    • 83
                    yes it does make it turn on faster if warmed up
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      • uk
                      can you try heating a certain area a time to narrow down the area that makes it turn on faster, with this fault i use a empty cardboard kitchen roll tube and aim the hot air down it so i can heat little areas at a time.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Why didn't you change the 2700uf thats the bloody 5vstby cap lol and you say you have checked the rst esr wise I willing to put a bet you have a bad cap problem here.
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          I repaired a 17PW26-3 last night. Bulging 2700uf cap along with others. As Reecey says, replace it. Often caps in the Vestel PSUs aren't visably failed but have a high enough esr to cause issues.
                          • cossiejay
                            • Nov 2010
                            • 83
                            the 2700uf as not been changed as I have none to change it with so I have ordered some
                            • Dannyx
                              Dead hand drier autopsy - motor discussion
                              by Dannyx
                              Good day folks. A few days ago I had the misfortune to be assigned a hand drier, the vertical type with a slot at the top where you insert your hands and a jet of air on either side blasts away the water. This thing was a nightmare to work on and it's stuff like this that makes me hate my job: very dirty, disgusting ! They didn't even have the courtesy to let it dry before plopping it on my desk....dirty water dripping out of it, mixed with bits of dust, hairs and dirt, limescale everywhere, a pungent moisture smell....horrible experience ! The type of thing you would only give to a greenhorn...
                              06-05-2019, 01:04 PM
                            • crt man
                              Vestal backlight strip 7020pkg 72ea
                              by crt man
                              Hi
                              Has anyone got the above backlight strip that is for parts or failed,
                              I am after the socket for them as the one on the board I am trying to
                              repair has suffered irreparable damage.
                              Alan.
                              09-01-2018, 03:40 AM
                            • AquaSonic
                              Dell U2718Q MStar controller overheating
                              by AquaSonic
                              Hello to the forum!
                              I am currently troubleshooting the Dell U2718Q monitor, which will work perfectly until it randomly shuts down and after a number of minutes will power on and work again, until it randomly (but quicker) shuts down again.
                              After some investigating i came to the conclusion that this is due to the Mstar MST9U37Q1 controller overheating, causing the monitor to shut down. When the controller is cool enough it will start working again. The power supply voltages at all times seem normal, nothing else feels hot on the board and by using a hair drier to...
                              07-14-2022, 12:39 PM
                            • reessi
                              Hitachi 42hyt42u Turns off after 3sec - Vestal 17IPS71, 17MB95M
                              by reessi
                              This came to me with alot of water damage on the power supply board so I replaced that board from ebay.
                              Now it powers on displaying the Hitachi logo then off. Can keep turning on like this.
                              When first plugged the standby leds flash slowly red/blue and it displays the logo without me pressing the power button, then shuts down after 3 seconds and displays red led.
                              Now if I press power button it will display logo again but this time when it shuts off the leds flash alternating...
                              01-27-2017, 03:16 PM
                            • perette
                              Panasonic TX-65x700 start problem
                              by perette
                              Hello everyone.
                              A friend of mine has a Panasonic TX-65x700.
                              Since yesterday it shows the Following symptoms.
                              Cold start, black screen, backlight works
                              Restart, blue and black vertical bands ( always the same scheme), sound OK, no osd (see picture)
                              Next restart, ok image and sound, stable.
                              It looks like somethingnneeds to be a bit more heated to run properly.
                              I was thinking to open the back, and heat with an hair drier one board after another to find the faulty one.
                              Any idea or favorite place to...
                              12-04-2021, 09:51 AM
