Hitachi 42hyt42u Turns off after 3sec - Vestal 17IPS71, 17MB95M
  • reessi
    • Jan 2016
    • 327
    • uk
    This came to me with alot of water damage on the power supply board so I replaced that board from ebay.
    Now it powers on displaying the Hitachi logo then off. Can keep turning on like this.
    When first plugged the standby leds flash slowly red/blue and it displays the logo without me pressing the power button, then shuts down after 3 seconds and displays red led.
    Now if I press power button it will display logo again but this time when it shuts off the leds flash alternating really fast.
    I can keep turning on if I want but always shuts off.
    Anyone know what the led flashing means, are they error codes?
    I have checked the power supply caps/diodes with meter & esr meter, all seam fine. I have checked output voltages with the schematic. They seam to be correct.
    I would like some explanation though, the power supply seams to only have a 12v output and it always outputs even when off. Upon turn on there are no other voltages, it turns the leds on through a seperate connection.
    This is whats in the schematic as well. I am confused if the 12v is always on then what is the signal for standby-on for? There is a seperate signal for backlight on. Also what confuses me is when the board is removed and powered the standby signal is at 0v. But when in the set it is as 2.6v while off and then 0v when it turns on so does that mean its on when powered out of the set but again what is actually on as the 12v is always on anyway!!
    Thhe backlight on pin is at 0v and then 3.2v when leds light.
    The board according the schematics has another power block connecter and this has 24v but my connector is clearly marked as nothing connected to that pin.
    Many thanks.
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Hitachi 42hyt42u Turns off after 3sec - Vestal 17IPS71, 17MB95M
    Corrupted f/w, vestels are such utter turds!
    TELEFIX
    • reessi
      • Jan 2016
      • 327
      • uk
      Thats what I read in another thread on here!
      Can I re-flash do you think?
      Cheers.
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        on the back of the tv theres usually a white sticker saying what the lcd panel number is can you find it and let us know what it is
        • reessi
          • Jan 2016
          • 327
          • uk
          ves420undl-20-n03
          Cheers.
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            is there any other numbers on the mainboard usually on stickers as well
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              this is cheap but not sure if its a match
              http://www.ebay.co.uk/itm/MAIN-AV-BO...kAAOSwlaxWOL-I
              • reessi
                • Jan 2016
                • 327
                • uk
                Yes, alot, on a white one - 10093507 23225762 428 42" (one line),
                27334079 DIJ,
                362J5,
                Some more on a blue one half under the white one, do you need?
                Cheers.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  i have had a quick look for a eeprom or dump of it and cant find any im not sure if that mainboard will work and how many of the numbers need to match maybe Alastair E or reece can advise
                  • reessi
                    • Jan 2016
                    • 327
                    • uk
                    Yes I had a look earlier on ebay, Can you say from the symptoms that you would be pretty sure its a corrupted firmware? Do you know which is the important number to match. For instance if I bought a Digihome one what would be the problem, are we matching the exact model of panel to the firmware on the board or just the panel size? And can I re-flash this board?
                    Many thanks.
                    • reessi
                      • Jan 2016
                      • 327
                      • uk
                      Also do you know what causes the firmware to corrupt?
                      Cheers.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        if you say put a diffrent brand i guess on start up it will say digihome? ive not tried it have you got any freeze spray as sometimes you can get the eepronm cold it will start up ok as this sets water damaged you dont really no i guess what other faults it may have ie got on to tab bonds etc im still learning my self but i always match replacement mainboard to the panel sticker as people have issues with display being upside down etc
                        hopefully a more experienced member will advise what needs too be matched on this series mainboard
                        • reessi
                          • Jan 2016
                          • 327
                          • uk
                          The picture is fine for the 3 seconds its on, I checked the M/B under the microscope, no sign of water damage, could have been damaged I guess when he PSU blew, was no output from it when I got to it but alot of corrosion on psu. I havent got any freeze spray, I could get some tomorrow, why do you think that would help the Eprom? Are you thinking dry solder joints although dont people normally heat up for that?
                          Cheers.
                          • Alastair E
                            Chief Womble
                            • Mar 2013
                            • 1963
                            • U.K.
                            Whatever mainboard you get-- It Must be one that drives the same make and model of LCD panel. TV vendor name is immaterial...
                            Vestel used all sorts of make panels including their own on later ones....
                            TELEFIX
                            • reessi
                              • Jan 2016
                              • 327
                              • uk
                              So how can I be sure? Do you know which no's to match. On the ebay listing most of line one of the white label matches but not the last 3 no's before it states 42", and the second line does not match!
                              And could it be fixed if I find the firmware to flash, do you know how to flash, I assume we use the usb?
                              Cheers.
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                • uk
                                ive had a quick look cant see one that matches the panel number maybe send this company a email and see what they say send them the tv make/model number and the panel number there a good company a few of us use them.
                                this is your lcd panel number not all sellers put this info on the adds
                                ves420undl-20-n03
                                this seller does list the lcd panel number used (just for refrence)
                                https://www.piese-servicelcd.ro/www-...420UNDL-2D-N03
                                • reessi
                                  • Jan 2016
                                  • 327
                                  • uk
                                  So it cannot be worked out from the numbers on the mainboard? I'll message them. Cheers.
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    • uk
                                    ignore wrong link
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      • uk
                                      im not sure if that white sticker has something too do with it?
                                      • reessi
                                        • Jan 2016
                                        • 327
                                        • uk
                                        Thanks for your help, I will email a few of the sellers and see what they say. I will try and research about flashing as well, maybe someone else might see this thread and can advise.
                                        Good night.
                                        • Bazilwrc164
                                          Request: Firmware for Hitachi 42HXT12U (Vestel 17MB95M, VES420UNDL Panel)
                                          by Bazilwrc164
                                          I’m looking for a USB firmware file or EEPROM dump for a Hitachi 42HXT12U TV.
                                          The mainboard is a Vestel 17MB95M, and the screen panel is VES420UNDL.
                                          I recently replaced the mainboard with another 17MB95M, but it’s programmed for an LC420DUJ panel, and I’m getting no picture. I’d like to flash the correct firmware via USB or update the EEPROM if needed.
                                          If anyone can provide:
                                          • A working USB firmware file (like upgrade_loader.pkg or mb95_m.bin)
                                          • Or a compatible EEPROM dump
                                          07-23-2025, 12:15 PM
                                        • dragometin
                                          Hitachi 40HYC42
                                          by dragometin
                                          TV Model: Hitachi 40HYC42
                                          Power Supply: 17IPS71
                                          MainBoard: 17MB95M
                                          Panel: VES400UNDS-2D-NO3
                                          When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                                          I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                                          Is there any variants on 17IPS71 power supply's?
                                          UART output pins 10 and 12 on scart connector:
                                          Code:
                                          12:24:04.595
                                          08-08-2024, 05:53 AM
                                        • Jaime Morillo
                                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                          by Jaime Morillo
                                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                          The TV was stuck on the logo and I couldn't access the update menu.
                                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                          The image result was good, but the image is inverted.
                                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                          Yesterday, 11:38 AM
                                        • massimomax
                                          Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
                                          by massimomax
                                          Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
                                          spero che qualcuno può averlo per riprogrammare eprom. grazie
                                          Post in English !!!
                                          I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
                                          02-28-2025, 07:27 AM
                                        • sotodefonk
                                          Help finding the correct model of a T-Con board on my Hitachi TV
                                          by sotodefonk
                                          Hi, I have a Hitachi tv model L47V651, there is no image, but sound and backlights turn on, so I believe the issue is the tcon board.
                                          I opened the tv to access the board and took the shared pictures of the T-Con board.
                                          I saw a video from shopjimmy on how to detect the model number on tcon boards, but this doesn't have a sticker like how that video showed all boards.
                                          I searched the P/N number and got results with the same marking name and P/N my board has but they list other specific tv models like Vizio and Philips brand but not Hitachi.
                                          Inspecting...
                                          06-28-2024, 04:39 PM
