Dead hand drier autopsy - motor discussion
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks. A few days ago I had the misfortune to be assigned a hand drier, the vertical type with a slot at the top where you insert your hands and a jet of air on either side blasts away the water. This thing was a nightmare to work on and it's stuff like this that makes me hate my job: very dirty, disgusting ! They didn't even have the courtesy to let it dry before plopping it on my desk....dirty water dripping out of it, mixed with bits of dust, hairs and dirt, limescale everywhere, a pungent moisture smell....horrible experience ! The type of thing you would only give to a greenhorn to work on when you don't feel like doing dirty work...most annoying ! Adding to the frustration was that many of the screws were rusty and stuck in place, so just opening up the thing was not enjoyable in the slightest...
    Getting past the ugly nature of the job, the actual problem came down to the motor itself which is far past f***ed (see the picture): moisture got sucked up through the bottom, into the whole machine, causing many of the metal parts to rust, including the impeller blades and part of the motor housing as you can see. The expansion of the rust actually caused the impeller to weld itself to the inside lip of the cover there ! I have no idea how it could've possibly ended up SO bad inside - you wouldn't think leftover water on hands can do this sort of damage, especially since it's (SHOULD BE !) designed to be immune to moisture...it's like they left it out in the rain on purpose just to screw with me...
    It's also one of the most overkill and over engineered things I've ever seen...just look at that control board ! Was this really necessary ? It's a hand drier - you just run a motor ! Why do you need a computer in there ?! Amazingly, the board works and was perplexingly the driest part in the whole machine, despite that box just having a POS metal lid with no gasket and no screws whatsoever that was all bent and not fitting properly, because the thing was kicked or knocked somewhere in a bottom corner and a lot of things no longer fit or close properly...*ARRRGHH !! * Stuff like this just made it more and more annoying the more I dug into it and I would love to beat the crap out of that thing with a sledgehammer just because it's such a humongous piece of garbage stinking up my shop and soiling my hands and desk and wasting my time ! !
    *RANT OVER*
    When I turned it on, I could hear the rising frequency sweep vibrating the motor windings in the audible range, but it quickly shut back down and returned an error code (yeah, it's got a display at the top - did I mention "overkill" ?). I got the motor out and found THAT....game over, since there's no way you're restoring that, not with the rock bottom equipment we have here. Still, the motor's pretty interesting: it's got 8 wires going into it ! 3 fat ones and 5 thinner ones. In the picture of the control box, the first three are the black, white and red in the bottom-left corner and just above that terminal block there's the other 5...what is this motor ? Is it a three phase VFD-driven motor ? Why all the wires then ? There's a bridge rectifier, two large caps, 6 IRFP460 FETs and a handful of other small components, so it must be a VFD....STILL overkill IMO. Would it be possible to find a replacement for such a seemingly dedicated motor ? Swapping it would be a nightmare, since those wires pass through a moulded plug in the housing so I'd have to cut each one then individually solder them back onto the new motor, plus just the idea of working any further on this thing makes me sick...cheers guys
    Wattevah...
  • Retro-Hipster
    Tinkerer
    • Apr 2019
    • 125
    Re: Dead hand drier autopsy - motor discussion
    Nice. LOL
    Does the motor have any identifying marks or labels? Also, I might suspect that it is a standard AC motor, but with something like a rotory encoder/an array of hall effect sensors inside. If my guess is correct, you should most likely find all three of the large ones can be ohmed out and have some continuity to each other, but that the other smaller wires would have no connectivity to the big three.. Well, that is my guess anyways.
    Could be some sort of starter windings I suppose, but yes. Are those 6 fets on the board in two parallel sets? If so, are two of the 3 wires on that motor connected to the source or drain on the fets? Right now I'm kind of suspecting that the motor is a two pole ac motor. You would have one winding connected to one of the legs of the mains (probably through that relay) and then the other two would be connected to the 2 sets of mosfets. This would create the two phases for the ac motor. Then the 5 other windings would be something like a rotary encoder to give the mcu information on where the motor is so it can sync the phases. An advantage to this would be that you can control the speed/make the device work the same in both 240v 50hz and 120 60hz AC countries I suppose..
    And I suppose the last thing I could say is that you may be able to save the blower assembly/motor. You might try grabbing something like a thing of Tupperware and then just submerge the rusted to shit part with some vinegar. (You could also use hydrochloric acid or something commercial like Evaporust. ) You'd be amazed what about 24 hours of white vinegar will do to the rust. haha
    That motor kind of looks like the ones you'd find in vacuum cleaners actually...
    “Men always seem to think about their
    past before they die, as though they were
    frantically searching for proof that they
    truly lived.”
    – Jet (Cowboy Bebop) -
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      Sadly no, at least not ones that I could use - just an assembly date or something irrelevant.
      WHY would it have encoders and the likes ? I too thought of that, but it wouldn't quite make sense...
      Are those 6 fets on the board in two parrelel sets?
      Don't know - haven't measured them TBH.
      Probably. If it were mine or got it for free for the purpose of installing it at home or something, I would probably put in some elbow grease and would eventually get it going again since it IS pretty expensive indeed when new...this would require a lot of scrubbing, heavy duty detergent, wire brushes, hot running water, clothes I don't mind ruining and an outdoors space to work in...that should just about cut it
      Correct - I too had hoped it would be a vac motor, just in an extra plastic jacket to make it more water resistant, but what put me off was the multitude of wires. An "universal" async motor like that would only require 2 wires going to it.
      Wattevah...
      • R_J
        • 9514
        This might be the motor? http://www.czowo.com/sale-10257912-d...and-dryer.html
        It might not be the exact motor but the wiring might be the same
        • Retro-Hipster
          Tinkerer
          • Apr 2019
          • 125
          Every time you post R_J, I am impressed. lol That sure looks like the motor to me. hahaha
          truly lived.”
          • Retro-Hipster
            Tinkerer
            • Apr 2019
            • 125
            Oh, I noticed that the opening on the blower cage seems a bit different/more narrow on the opening.. Also, I feel silly not thinking it was a brushless dc motor.. ^^;; That just makes more sense. That definitely looks practically identical to me though.
            truly lived.”
            • redwire
              • 3900
              AK2006H AIKE hand dryer, from the PCB number.
              I don't see an SMPS transformer, so the H-bridge must be using rectified mains voltage.
              I wouldn't warranty the repair because of the water and corrosion. It's supposed to have a intake air filter, lol.
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                • Romania
                It's actually a "Jofel" but no doubt could be rebranded under many other names whilst still using the same chassis and parts.
                Correct. There IS a small SMPS there for various signals and stuff, but it's driven from a separate small transformer, tucked under that bundle of wires coming into the control box. You can just about see the yellow top there.
                It does - all clogged and dirty and sopping wet
                The motor, although similar in concept, is unlikely to be an exact match.
                Wattevah...
                  • 30927
                  is it a Dyson Air-Blade???
                  you could strip the motor, shotblast the rust off and replace the bearings - if you worked somewhere else!
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    • Romania
                    Nope - a "Jofel" like I said, though yes - the concept is the same as that one. We have those Dysons in one of our malls here
                    True - a job is made a thousand times less appealing when you realise you have insufficient tools and work for a place that doesn't give a damn. If I had proper tools and work conditions, I would be able to tackle even the dirtiest of jobs with enjoyment....*SIGH*
                    Wattevah...
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      redwire got it, Aike are OEM/ODM manafacturers and according to their website make 40% of the worlds hand dryers. I would think their motors are fairly universal.
                      • redwire
                        • 3900
                        Rusty brushless motors, I find the magnets and hall sensors can get covered in iron dust and not work. The hall sensor does not get good flux signal.
                        Use sticky masking tape to clean that up.
                        spelling is "dryer" not "drier" so searches might be giving bad results.
                        I wonder what the hand dryer seller would charge for the same repair, a new motor seems hard to find.
                        • Dannyx
                          CertifiedAxhole
                          • Aug 2016
                          • 3912
                          • Romania
                          Pfft....yeah, epic fail for someone who has a degree in this sort of stuff >_> Hey, I'm only human - I'm allowed a "your vs. you're" every now and then
                          Wattevah...
                          • redwire
                            • 3900
                            I mention it only to help search for a motor. Once you have the keyword, it's easy to find things but man, spell it wrong and no hits.
                            • kaboom
                              "Oh, Grouchy!"
                              • Jan 2011
                              • 2507
                              Just like pickup coils for automotive ABS "speed sensors."
                              White vinegar, heated near boiling, does a great job on limescale and is not like handling hydrochloric acid.
                              Dannyx, put some in a glass container (pickle jar?) & heat in a microwave oven. Try to soak/pour it over the nut holding the impeller.
                              If there's enough slack in the wires, immerse the entire volute/impeller assembly in hot vinegar.
                              The round volute/cone thing enclosing the impeller should eventually pry off the baseplate/static vanes, if it's anything like a vacuum motor.
                              My temptation would be to EOL it. Good luck.
                              "pokemon go... to hell!"
                              EOL it...
                              All style and no substance.
                              guilty,guilty,guilty,guilty!
                              guilty of being cheap-made!
                              • Dannyx
                                CertifiedAxhole
                                • Aug 2016
                                • 3912
                                • Romania
                                Update: my dear ol' colleague apparently wanted to give it a shot, since I saw it strewn all over his bench the other day...as if there wasn't enough stuff on there already Knowing the ol' fart, he will scrub that rust with his fingernails, he will use his own toothbrush on it, he will even sleep with the thing at night....anything to show off, rub it in my face and prove that he's better than me. I often do this sort of stuff on purpose: leave stuff I don't want to bother with for him to struggle with
                                Wattevah...
                                • seanc
                                  • Nov 2008
                                  • 1319
                                  http://aikehanddryer.sell.everychina...and-dryer.html
                                  • Dannyx
                                    CertifiedAxhole
                                    • Aug 2016
                                    • 3912
                                    • Romania
                                    Yeah, that's the one.
                                    Wattevah...
                                    • redwire
                                      • 3900
                                      It needs a new blower motor and all that labour to try fix it- it won't make any warranty period and end up being back in the shop soon.
                                      I liked it when other techs took over on a repair job. I would play dumb, like I don't know what's wrong or how to fix it.
                                      Supertech would take the work, blame me for all the things that were wrong, every missing screw. But it's his baby now
                                      • Dannyx
                                        CertifiedAxhole
                                        • Aug 2016
                                        • 3912
                                        • Romania
                                        Right, right and right some more !
                                        Wattevah...
                                        • juergenb
                                          Nescafe Aeroccino, still fails with new Motor (red flashes only once)
                                          by juergenb
                                          i am asking for some Help.
                                          I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
                                          The Motor didn´t start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
                                          So i got a few of these from Banggood.
                                          I swapped the motor and now i have a new fault condition.
                                          In a working Frother you would press the start button, it will light red and work for a few minutes.
                                          If you press longer it will light blue and just mixup the milk.
                                          With the new Motor it just starts...
                                          03-23-2021, 11:24 AM
                                        • sbt123
                                          charnwood w821 mini wood lathe motor problem
                                          by sbt123
                                          hi there,im having a look at repairing a wood lathe for my dad,(charnwood w821)the problem is when turning up the variable speed control,the motor starts to stop and start by itself,if i continue to turn up the speed it will trip the mcb in the consumer unit,there is also a slight smell of burning from the speed controll box.,Another strange symptom is the lathe can be unplugged from the mains after switching it off and the motor will spin a couple of times by itself,so far ive put a new speed controll potentiometer on and new motor brushes,ive also tested the motor windings and everything looks...
                                          10-27-2024, 03:43 AM
                                        • Per Hansson
                                          Motor run capacitor physical size vs voltage rating & measurements?
                                          by Per Hansson
                                          (TL;DR skip the first paragraph)
                                          I encountered my first dead motor run capacitor at a customer this week.
                                          For some fields I guess it is a very common occurrence but the usual way for industrial machines here is to use 3-phase motors.
                                          (Unless a servo motor makes more sense that is).
                                          But for some reason this 3-phase machine uses a 1-phase motor for its liquid coolant pump.
                                          The pump would run but sometimes trip the 10A breaker.
                                          I monitored it starting and stopping for over an hour until it finally stopped in a specific spot between its windings:
                                          Then it could...
                                          09-20-2020, 06:32 AM
                                        • mikey5791
                                          Help identify this motor
                                          by mikey5791
                                          Hi all forum members,
                                          Found this unknown motor discarded in a junk yard and took home for learning experience. By the look of it, I suspect it is taken out from a type of air blower probably running on ac power. I used digital multimeter on ohm/resistance scale and it doesn't read anything on those 2 black wires. So, this motor is not shorted and should be good to run.
                                          Correct me if i am wrong on the initial test.
                                          Can anyone kindly advice on how to test run this motor based on visible external two black wires. Fyi, i don't see any marking on the motor body nor smell anything...
                                          11-24-2023, 07:54 PM
                                        • cjard
                                          A motor controller is a power supply, right?
                                          by cjard
                                          Hoping someone here will be able to provide a few pointers with this. I've got a motor controller board for a device that moves a caravan. A DC motor on each wheel is supplied with 12v DC or -12V DC depending on whether the remote control is pushed in "forward" or "backward" mode. The control is arranged by having 2 relays per motor that, at rest, are all connected to the negative.. If the motor is to go forwards, then relay 1 activates meaning the motor sees "positive negative" on its terminals 1 and 2. If the motor is to go backwards then relay 2 activates meaning...
                                          10-14-2020, 01:24 PM
