Logik L40DIGB20 Lcd tv Wont Power on just red standby Led on
  • matyka
    • Jan 2015
    • 179
    • Uk
    Hello,I have this Logik model: L40DIGB20 and it wont power on .
    I have just the red standby light ,When try to power up the tv from remote and side buttons nothing happens
    The power supply model: MLT668TL
    I have only 2 reading from the power supply picture attached with this readings.
    Should I have the two 12v pin going to the main board some power ?
    Any help would be much appreciated .
    Re: Logik L40DIGB20 Lcd tv Wont Power on just red standby Led on
    The power supply board has to receive the PS-ON (Power supply ON signal) to turn on the 12V/24V SMPS power supply section to get the 12V for the main baord and the 24V for the inverter board but for that to happen, the PFC Voltage booster has to function first.
    Per your picture, you do have 2.719vdc at the PS-ON (STB) pin, so you need to check the DCV between the two legs of the main filter cap (450VDC CAP) see if you do have close to 400VDC on the two legs of that filter cap or not.
    Is this the exact match of your MLT668TL (top and bottom side)?
    Pictures provided by shopjimmy.
    • matyka
      • Jan 2015
      • 179
      • Uk
      Hello and thanks,I have between the two legs of the main filter cap (450VDC CAP) 392VDC on the two legs of that filter cap.
      Sometimes will drop to 385VDC .
      What would be the next step ?
      Yes the picture are the same top and bottom side (MLT668TL )
      • finntricky
        • Jan 2014
        • 449
        • uk
        i had the same problem, on the same set last week, and after spending some time checking voltages, all i had was standby and no power from 12v 0r 24v, removed connections from power supply, just leave mains cable turn on and test 12v and 24v, if you now have the correct readings, connect all the plugs back in, but unplug the inverter plugs from inverter, and test 12v and 24 again, if all is well, the tv will boot. but no back lights.
        in my case it was the inverter shorting that shut down all power from the power supply
        • michael dranfield
          • Jan 2016
          • 232
          • England
          Common fault on these sets is a short FET on the inverter board part no A04614
            Originally posted by finntricky
            i had the same problem, on the same set last week, and after spending some time checking voltages, all i had was standby and no power from 12v 0r 24v, removed connections from power supply, just leave mains cable turn on and test 12v and 24v, if you now have the correct readings, connect all the plugs back in, but unplug the inverter plugs from inverter, and test 12v and 24 again, if all is well, the tv will boot. But no back lights.
            In my case it was the inverter shorting that shut down all power from the power supply
            +1
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              https://www.badcaps.net/forum/showth...=SSI_400_14a01
              Check out my thread not as simple as just replacing the fets you will need the whole controller too.
              • matyka
                • Jan 2015
                • 179
                • Uk
                Thanks for all your help ,I have checked and yes on SSI_400_14A01 inverter has 3 fets shorted .
                I have attached some photos to see the damage on the back .
                I order 3 fets and ReeceyBurger123 advice to replace the IC SEM2107
                I will let you know when the parts will arrive .
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Nice one also I really urgue you to resolder ALL the little SMD resistors and jumpers buddy if they become lose they can cause the fets to blow. Also replace the caps too, with brand new ones like rubycon ZLJ or Panasonic the caps can be affected when the fets short.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    You also have some resistors to replace that are in front of the fets. The attachment I have of them wont bloody upload
                    • matyka
                      • Jan 2015
                      • 179
                      • Uk
                      Hello,I have fix this tv after changing 3 fets part no A04614 and 2 10kohm resistor .Tv been running now for 3 days and still working.
                      Thank you for all your help.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Awesome, just be careful if it does blow up again you have another issue. Let us know if you need help again
                        • GLISIT
                          by GLISIT
                          01-16-2025, 02:29 PM
                          03-31-2024, 02:12 PM
                        • SkishyIshy
                          Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
                          by SkishyIshy
                          Hey All,
                          I have a Sony 65x900f that I purchased cheap because of a no-power issue.
                          I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
                          I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
                          03-17-2021, 11:44 AM
                        • AleMonti
                          LG 55EG910V - no power and no standby light
                          by AleMonti
                          I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                          I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                          The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                          After checking the basics I did the following:
                          • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                          11-04-2024, 05:02 PM
                        • redbaron1007
                          Yamaha HTR-3065 No power/No Standby
                          by redbaron1007
                          I got a Yamaha HTR-3065 on the bench currently that's got a no power/ no standby issue.When I plug it in it draws 0.01A from the wall, the relay for the ac transformer never clicks, there are no standby lights on the front, and pressing the power button does nothing. The fuse was not blown but upon measuring the voltages on the power low voltage power supply board (labeled operation 3 pg 89 in the schematic) they do not match what the schematic says they should be.
                          S9 13.7V
                          Pwr Ry 0V
                          AC Det 9.1V
                          Mgnd 0V GND
                          The two pins on the transformer for the operation...
                          09-12-2024, 03:04 PM
