Sony KDL-32EX500 almost dead
  • CraigR
    • Dec 2013
    • 959
    Sony KDL-32EX500 no lights or sounds when plugged in and turned on. All caps look ok. removed and tested mosfets. The only voltage I have is 3.1v on standby and 1.3v on BL_ERR the rest of the stuff is zero or less than .4v fuses all are good also.
    Re: Sony KDL-32EX500 almost dead
    You do not see blinking LED error codes at all?
    • CraigR
      • Dec 2013
      • 959
      No lights at all.
        download that training manual and take some Voltage readings see page 12.
        • CraigR
          • Dec 2013
          • 959
          Following that I'm to replace the board.
          • CraigR
            • Dec 2013
            • 959
            Any other thoughts before I trash the set?
              • 31020
              replace the small startup caps
              • CraigR
                • Dec 2013
                • 959
                Just replaced the 4 smallest caps and no help.
                • scottmet
                  • Jan 2015
                  • 38
                  If someone else is having this same problem disconnect the IR sensor from main video board and your TV should work. Hope this helps someone out.
                  • Audeze
                    Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                    by Audeze
                    I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                    Does...
                    10-06-2024, 08:54 PM
                  • thstuff
                    Sony OLED XR-77A80J - Initially dead, now 4 Flashes
                    by thstuff
                    A) TV initially dead
                    B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
                    C) Was able to perform a Reset from Settings menu and completed out of box configuration.
                    D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
                    E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical...
                    12-26-2024, 09:10 PM
                  • bohaboha
                    SONY KDL-46R473A ALMOST DEAD NO STB
                    by bohaboha
                    Hello to everyone in this wonderful forum.
                    I have this SONY LCD TV KDL_46R473a
                    PSU GL5 APS350 :1-888-122- 12
                    MAINBOARD FY13_EU IP-012C101-4010
                    black screen ,no STB no life almost death.
                    on PS all the required volts are present 394V on the main cap and those on cold side 12.41V,3.45 and 3.45 are on
                    Also 3,5,and 12v are on.
                    nothing happens if i disconnect the PSU from the mainboard as on Samsung because here i think the mainboard gives the signal to the ps.
                    don't know what to do next all suggestions and advice are very welcome​...
                    04-24-2025, 04:40 PM
                  • michalk3777@gmail.com
                    Sony XBR65X810C - Completely Dead - no lights.
                    by michalk3777@gmail.com
                    Hello
                    Hope everyone enjoyed their holidays.
                    I realized I did not follow all the instructions for posting, so trying to do it right this time.
                    Previous post: Interpreting Service Manual Troubleshooting Steps.
                    TV is completely dead, no lights,
                    It has a bottom centre white stdby light, it does not come on, the optical socket does not light up. when I insert a usb stick with LED it does not light up.
                    I tried reset by unpluging an holding vol.- button.
                    Pictures of boards included.
                    Power board seems to be providing...
                    12-29-2020, 10:03 AM
                  • Talyn
                    Sony 55W905 dead
                    by Talyn
                    My Sony W905 started to turn itself off an on every few minutes and blinking 8 times red in standby. A few minutes later the tv was completely dead.
                    I can only hear the click of the PSU when attaching/detaching the power cable. No standby LED.
                    Any advice? Thanks!
                    04-15-2024, 08:14 AM
