MPF6908 No 5V on pin 6 to A Board
  • LITEZONER
    GO BOLTS!
    • Mar 2010
    • 223
    hello all, need some help with this issue TV Model is TC-50PX34 Manufactured in 2011, this unit used the Power supply MPF6908 stock image included, My issue is dead, no power, no standby lights, nothing, No click and powering up power supply, no 5V out to pin 6 of the A board. Took some readings and only getting 1.2V AC into the bridge rectifier, any help on where to test next would be very helpful, Thank you very much .
    39 Soldering Iron burns And Counting
  • LITEZONER
    GO BOLTS!
    • Mar 2010
    • 223
    Re: MPF6908 No 5V on pin 6 to A Board
    another picture
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Have you checked both fuses?
      • R_J
        • 9588
        I would check the fuses and then check the standby circuit, thats where your standby voltage comes from, if you post a good picture of the back of the board that would help in troubleshooting
        • LITEZONER
          GO BOLTS!
          • Mar 2010
          • 223
          Thank you, fuses are good, here is some pictures of the back of the board
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            I see there is a ceramic resistor (tall white). Have you checked that. If the fuses are not blown then there is every likelihood you have an open circuit somewhere along the path from the mains input connector to the bridge rectifier. The dc voltage written on the side of the capacitors is a good indication of what voltage you should read across it.
            • LITEZONER
              GO BOLTS!
              • Mar 2010
              • 223
              checked that 10 Ohm resistor tested good, so plug it in and test the voltage across the 4 caps (black rectangle plastic) ? The schematic is annoying or I am just not up to par on reading it, the numbers on the board do not correspond to the numbers in the schematic at all, also i believe i found what i think is several what i think are Zener diodes that measure both ways, if i am not mistaken they are the small peach colored diodes with a white stripe. check out this schematic, it doesn't give values only proprietary part numbers, and again the location does not line up with the numbers on the board. also it is barely legible in the block diagrams
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                I cannot see a reason then why you do not have a reasonable AC voltage across two legs of the bridge rectifier. Have you measured the voltage with the meter set to ac range with the meter probes on the ~ symbols (of the rectifier) and next measure the dc voltage with the meter set to dc with the probes on the bridge rec terminals marked with the + and - symbols.
                • LITEZONER
                  GO BOLTS!
                  • Mar 2010
                  • 223
                  Me neither, has to be either the wire wound Transformer or one of the varisistors I'm guessing. anyone who wants to chime in?, Incidentally i did find a blown fuse, I see now that it is blowing the outer most fuse when i power it on, that condition must have been present when i posted this issue.
                    You are not not going to get any AC at the two inner pin of the main bridge until the main board sends out the relay signal to turn on the power relay RL001, 002.
                    The STBY SMPS is running off the half wave rectifier D006 (WHEN tv IS IN STANDBY MODE), the B+ output (Cathode) is fed through the Thermistor NTC001, the out put of the thermistor is then feed the filter cap C102, so you should have about 160`170VDC bteween the two legs of the C102.
                    SMSP IC101 is for driving the power MOSFET Q101 which drives the standby power supply transformer T101 primary winding pin 5 & 6.
                    You need to check the fusible resistor R112, 125, 126. Check thermsitor NTC001 and the D006 if you do not have DCV on C102.
                    BTW: Incidentally i did find a blown fuse, I see now that it is blowing the outer most fuse when i power it on, that condition must have been present when i posted this issue. You mean the 6.3A main fuse is blown the minute you apply the AC to the board?If that is the case, then you need to check the resistance of the MOV Z001, 002, and 003.
                    Pictures are provided by SHOPJIMMY.
                    • LITEZONER
                      GO BOLTS!
                      • Mar 2010
                      • 223
                      these 3 MOV or varisistors? Thank you very much for the information.
                        They are MOVs which are the same as Varsitors.
                        the key point is that if you just power up the power supply board by itself without having other boards connected, it should not blow the fuse.
                        • LITEZONER
                          GO BOLTS!
                          • Mar 2010
                          • 223
                          hey, thank you, is the red one NTC001 a varisistor as well?
                            NTC001 is not MOV, it is Thermistor (it is used for inrush current limiting) which should show low resistance, if it shows open circuit then it is bad.
                            So is the fuse still blowing?
                            • LITEZONER
                              GO BOLTS!
                              • Mar 2010
                              • 223
                              I need to look up how to test these items, I replaced D006 with a rectifier diode, Not half wave, and replaced NTC001 after it blew up with ZNR V14621U also need to try and find part numbers that are not proprietary on these.
                              • LITEZONER
                                GO BOLTS!
                                • Mar 2010
                                • 223
                                I believe the NTC001 is a 600V MOV?
                                  Doo6 is setup as half wave rectifier circuit, full wave will be more than one diode.
                                  "ZNR V14621U" Where is this part? it is not shown in the circuit for the STBY SMPS section.
                                  NTC is NOT MOV, it is connected in series with the load, MOV is connected in parallel with the laod, completely different function from NTC.
                                  How what resistance did you get on the NTC?
                                  http://www.ametherm.com/inrush-current/
                                  MOV (VARISTOR):
                                  http://www.littelfuse.com/varistor
                                  Half wave rectification:
                                  http://www.electronics-tutorials.ws/diode/diode_5.html
                                  • LITEZONER
                                    GO BOLTS!
                                    • Mar 2010
                                    • 223
                                    shows open no resistance. NTC001 do you know what the correct part number is for the NTC? this part was used to replace NTC ZNR V14621U
                                    • LITEZONER
                                      GO BOLTS!
                                      • Mar 2010
                                      • 223
                                      ERZV10D621 Varistors 620V 2500A ZNR SUR ABSORBER 10MM
                                        Since NTC is in series with the load, so if the load, in this case that will be the MOSFET that drive the power transformer will be the first suspect, is shorted out then the NTC will blow up.
                                        Where did you get the 'ZNR V14621U' from? Was it printed on the body of the NTC001?
                                        That ZNR is NOT NTC, it is MOV (vARISTOR, SURGE SUPRESSOR).
                                        As you can see how the desinator for the component are.
                                        Z001 for the MOV (Varistor, surge suppressor). bad MOV will show really LOW RESISTANCE, good MOV will show very very high resistance (open circuit).
                                        NTC001 = NTC for inrush protection.
                                        Look at the conection, the CATHODE of D006 is connected to the one leg of the NTC001, the output leg of the NTC001 is connected to filter cap C102 positive leg. which is connected to the Transformer pin 6 primary winding.
                                        I do not believe you are understanding how the circuit functions and how the components are used in the circuit.
                                        They do not put MOV in series with the load.
                                        • Soulzink
                                          Samsug washing machine. Power supply DC41-00189a board issue
                                          by Soulzink
                                          I am trying to fix a samsung washinmachine power supply main board.
                                          I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                          Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                          The power supply board reference is the following: DC41-00189a
                                          I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                          04-19-2025, 06:26 AM
                                        • Asraf Atb
                                          by Asraf Atb
                                          01-27-2025, 05:02 PM
                                        • Stephen
                                          A2991 Logic Board issue, 20volts 0 amps help!
                                          by Stephen
                                          Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
                                          09-10-2025, 03:16 PM
                                        • Stephen
                                          A2991 logic board issue, 20volts 0 amps help!
                                          by Stephen
                                          09-10-2025, 03:15 PM
                                        • notallbad
                                          TCL 55RP620K power board issue
                                          by notallbad
                                          Originally the tv arrived with dimmed backlights (not failed leds) but everything else worked ok. Adjusting backlight in menu did nothing but voltage changed on dimming control pins,
                                          0% p_dim at 1.65v and a_dim at 1v
                                          50% p_dim at 3.3v and a_dim at 1.65v
                                          100% p_dim at 3.3v and a_dim at 2.88v
                                          Changed backlight leds anyway as always like to have complete peace of mind they wont fail shortly after selling the tv. No change as expected!
                                          Leds are 2 rows of 15 6v leds.
                                          On inspection of the power board found diode MBR3200 shorted so replaced with...
                                          07-12-2025, 05:45 AM
