MPF6908 No 5V on pin 6 to A Board
  • LITEZONER
    GO BOLTS!
    • Mar 2010
    • 223
    Re: MPF6908 No 5V on pin 6 to A Board
    Is this the one you mean Sir?
    39 Soldering Iron burns And Counting
    • LITEZONER
      GO BOLTS!
      • Mar 2010
      • 223
      4.80K Ohms one way ad open the other other way, if we are talking about this chip, Is this a digital Mosfet?
        It is just a diode for the negative power supply section. So it is OK.
        You should try new startup/running cap I mention in the earlier post next.
        • LITEZONER
          GO BOLTS!
          • Mar 2010
          • 223
          will do, Thank you
          • LITEZONER
            GO BOLTS!
            • Mar 2010
            • 223
            replaced C117 cap today, still same erradic reading on all pins of IC101, thinking bad IC101? won't start? what do you think next step is. Thank you
            • LITEZONER
              GO BOLTS!
              • Mar 2010
              • 223
              stay with me budm, need your help brother. thank you.
              • tw2005
                • Oct 2011
                • 6458
                Originally posted by budm
                Fa5528.
                You need to check the resistance between GND pin 4 against all other pins to see what you get and report the reading.
                Then you will take the DCV reding between GND Ppin 4 and the VCC pin 6 to see what you get.
                the IC needs VCC 15VDC typ Voltage for it to start (range is 13.2~16.8VDC).
                Too low to start, see post 44.
                That means it is trying to run, so it can be due to bad start up cap, or there is problem in the secondary side so it is in start/stop mode. I would verify that the rectifier in the secondary side are good, you also try putting in new start up/running cap.
                In the datasheet I see it says recommended Vcc is 10V min, Typ 18V, max 28V
                Is this TV being tested with the Sc and SS boards connected? either of those shorted can may present a No LED, No blink. Might be worth checking just in case
                I'm not sure if this info applies to US models, you don't have green LED on start up, just red.
                • LITEZONER
                  GO BOLTS!
                  • Mar 2010
                  • 223
                  Testing bare board, no standby 5V at pin 6
                  • tw2005
                    • Oct 2011
                    • 6458
                    Ok, No worries I had to ask just in case.
                    • richie83
                      • Jun 2016
                      I am having the same problem with my power board there is no dc volts at c102. i get 5 v and it fluctuates but when i remove the ic101 the voltage slowly increases
                      • Kamranali
                        • May 2018
                        • 10
                        • Malaysia
                        #71
                        Hi can i get help to fix my panasonic p50x30k
                        My tv dont have power and light
                        And no standby volt also
                        When i press relay oo2 then i have 5v standby
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          #72
                          Can you start a new post with model number, pictures of you circuit boards and voltages at the connectors.
                          • Kamranali
                            • May 2018
                            • 10
                            • Malaysia
                            #73
                            Thanks Willing
                            I m new here not so familiar with this website to start new post
                            • Soulzink
                              Samsug washing machine. Power supply DC41-00189a board issue
                              by Soulzink
                              I am trying to fix a samsung washinmachine power supply main board.
                              I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                              Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                              The power supply board reference is the following: DC41-00189a
                              I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                              04-19-2025, 06:26 AM
                            • Asraf Atb
                              by Asraf Atb
                              01-27-2025, 05:02 PM
                            • Stephen
                              A2991 Logic Board issue, 20volts 0 amps help!
                              by Stephen
                              Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
                              09-10-2025, 03:16 PM
                            • Stephen
                              A2991 logic board issue, 20volts 0 amps help!
                              by Stephen
                              09-10-2025, 03:15 PM
                            • notallbad
                              TCL 55RP620K power board issue
                              by notallbad
                              Originally the tv arrived with dimmed backlights (not failed leds) but everything else worked ok. Adjusting backlight in menu did nothing but voltage changed on dimming control pins,
                              0% p_dim at 1.65v and a_dim at 1v
                              50% p_dim at 3.3v and a_dim at 1.65v
                              100% p_dim at 3.3v and a_dim at 2.88v
                              Changed backlight leds anyway as always like to have complete peace of mind they wont fail shortly after selling the tv. No change as expected!
                              Leds are 2 rows of 15 6v leds.
                              On inspection of the power board found diode MBR3200 shorted so replaced with...
                              07-12-2025, 05:45 AM
