Sony KDL-40V3000 distorted picture
  • PowerAmpFreak
    • 977
    • Sweden
    This Sony KDL-40V3000 has a distorted picture. Looks saturated.
    Worst from coldstart, better when warm but not OK.
    Panel or T-con should be the options here?
  • PowerAmpFreak
    • 977
    • Sweden
    Re: Sony KDL-40V3000 distorted picture
    Don't you think this is actually related to T-con failure?
    It's possible to see the picture distortion changes as it heats up during the first 30 seconds of operation.
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      I'll try a T-CON for starters.
        Check the GAMMA Voltages on test points on the T-CON board. Did you reseat the cables already?
        • PowerAmpFreak
          • 977
          • Sweden
          Budm, what should the gamma voltages read if OK?
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            GAMMA Voltages If from ! to 14 they should increase or decrease uniformly. Do as BUDM said measure the voltages and post then we can determine a fault.
            • vinceroger69
              • Mar 2012
              • 6714
              This thread may help you by budm regarding gamma voltages post 13 shows one test results (which are bad)
              https://www.badcaps.net/forum/showth...gamma+voltages
              • PowerAmpFreak
                • 977
                • Sweden
                Here's the Gamma voltages:
                VGMA1: 15,44
                VGMA2: 15,07
                VGMA3: 14,93
                VGMA4: 12,60
                VGMA5: 11,61
                VGMA6: 10,62
                VGMA7: 6,71
                VGMA8: 4,83
                VGMA9: 7,66
                VGMA10: 7,90
                VGMA11: 7,89
                VGMA12: 7,10
                VGMA13: 5,30
                VGMA14: 5,30
                VGMA15: 5,30
                VGMA16: 6,30
                VGMA17: 8,51
                VGMA18: 5,60
                VGMA19: 3,10
                VGMA20: 0,456
                VGMA21: 0,299
                VGMA22: 0,214
                VCOM: 6,68
                AVDD: 15,42
                (V)
                Does the low reading on gamma 20-22 indicate a fault?
                • vinceroger69
                  • Mar 2012
                  • 6714
                  A lot of those readings look bad from what i understand it should be a steady gradual voltage drop im sure someone more experienced will comfirm
                    Yes, it is bad.
                      Gradual voltage drop or increase, but only ever moving in one direction (Monotonic function)
