samsung 40 in lcd can i ruin panel???
  • mattstolte
    • Dec 2013
    • 612
    • usa
    I recived this lcd and the color was messed up so I ordered a new chip that was on ebay for this tcon well I tried to solder it and messed it up, then I ordered another tcon and whole screen is white now. wondering is it possible I could of damaged the panel? then I put the other tcon back in and I seen alittle color but was white also, but seen some color but the tcon I got off ebay no color
    Re: samsung 40 in lcd can i ruin panel???
    There is the chance, but it is unlikely.
    • steviewonder
      • Dec 2013
      • 183
      • england
      probably a duff board you have been sold..notably the as15f ic..if this gets hot rather quickly,then there's the fault.
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        with the new tcon in have you tested the gamma voltages are they good or bad?
        • mattstolte
          • Dec 2013
          • 612
          • usa
          i dont know how to test them could you guide me with this please? would help for future reference i have been learning alot lately, and would like to know how to do this because i been been running into errors miss diagnosing tvs because of this, thanks
            There are guides all over this forum - you just need to locate the gamma points (VG#, GAMA#, etc.) and test them. Report the readings you get.
            • mattstolte
              • Dec 2013
              • 612
              • usa
              tom I see vgma1-vgma22 I need to test all these? and how can I find out on my own for future reference on the readings? I will I know if there good or not? basically im asking what all do I need to know how to test a tcon?
                Example:
                https://www.badcaps.net/forum/showth...gamma+voltages
                https://www.badcaps.net/forum/showth...ht=LN40B530P7N
                  Basic principle with gamma voltage curves is "monotonicity". The voltages should go either up or down, but not both. i.e. not up, down then up again, that is a fail. Almost all bad ICs fail this test.
                  They also should range from 0 to about 15V, sometimes a little lower or higher, but no lower than 14V or higher than 18V. Some bad ICs will get have half the voltages low, other half good. That means the IC is bad and needs to be replaced.
                  More complicated test is symmetry. The voltages should mirror themselves around the centre point of half the highest voltage. i.e. if the highest voltage is 15V, then you should be able to draw a virtual mirror around 7.5V and the voltages will be in the same "curve". Excel helps here!
                    09-07-2024, 05:50 AM
                  • netgearnetgear
                    TCL 43S423 TCON OR PANEL FAULTY???
                    by netgearnetgear
                    Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                    08-20-2025, 06:04 PM
                  • x_orange90_x
                    TCL 50S535 bad tcon or panel issue?
                    by x_orange90_x
                    Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                    03-29-2025, 11:02 PM
                  • NWArkGuy
                    Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
                    by NWArkGuy
                    Well, I will be the first to admit that I screwed up...
                    In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
                    I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
                    I have 2 that I have found and have in my possession. ...
                    10-12-2023, 10:13 PM
                  • rimwall
                    Sony KD-65x7500D - double image - Tcon or Panel?
                    by rimwall
                    This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                    I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                    11-18-2025, 02:09 AM
